Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 02-11-2010, 07:52 AM   #241
xcmountain80
xcmountain80's Avatar
Send a message via AIM to xcmountain80
Default
I won't be 100% until I drain the fluid and look for metal, then pull the 3rd member and inspect for damage. It bucks lightly when under load and through conrners upon takeoff. We were just at the dealer and hade the 100k tranny flushed and there wasnt anything in the tranny filter so we ruled the tranny out of the equation.
Aaron
02 4-Runner
xcmountain80 is offline   Reply With Quote
Old 02-11-2010, 07:34 PM   #242
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Aaron
that assumes they didn't fark up the tranny
if you've blown a rear diff, bucking is not a symptom. BANG! BANG! BANG! with that buck IS a symptom that would be a broken tooth or two.
bad bearings make all kinds of racket...impossible to miss.
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 04-20-2010, 06:39 PM   #243
isthatahemi
Default
Too lazy to type twice.
2010 TRD OR- 18000kms
Stock everything except BFG AT's
Broke in soft mud, sheared 6 ring teeth, pinion damaged.
Looks like Toyota is covering it.
http://www.tacomaworld.com/forum/2nd...impressed.html
GONE! OCT19 - 2009 4X4 AC 5 SPD Magnetic Grey, Infinity Basslink, Hoppys brake controller.
ARRIVING OCT 28 - 2010 4X4 TRD OFF ROAD w/BFG AT's
isthatahemi is offline   Reply With Quote
Old 05-07-2010, 10:59 AM   #244
BirdTRD
BirdTRD's Avatar
Default
1. 2009 Tacoma DC TRD Off Road
2. 285/75/16 Goodyear Duratracs
3. 12,000ish
4. I was driving up a big, rutted, sandstone hill in 4lo. It was a difficult hill but nothing that should have grenaded the diff. I had ATRAC on but the locker was not engaged. One big loud pop and that was it. Clunk, clunk, clunk when driving a few feet to test it out. Removed the rear drive shaft to get it back to the road. It continued to clunk. Had it towed to the dealership.
Toyota replaced it under warranty. No questions asked. Good guys at my local dealership.
09, 4dr TRD OR, Tacoma. Lifted, locked, and armored.
BirdTRD is offline   Reply With Quote
Old 05-24-2010, 08:16 PM   #245
spenny
Default
I just got an '06 TRD off-road manual with 60,000kms.. I've notice a lot of wheel hop and some ticking (not sure if its from the engine or not). The differential also seems to have a lot of slack, maybe around 15degrees when parked? Is this something I should be worried about?
spenny is offline   Reply With Quote
Old 06-29-2010, 06:45 PM   #246
puptent
puptent's Avatar
My Rig: 2008 Tacoma
Default
Finally getting a new third member after 3 trips to the dealer over a one year period. 2008 regular cab, 55k. Noticed the grinding since the truck had 400 miles on it
Gardener from hell
puptent is offline   Reply With Quote
Old 08-10-2010, 06:42 PM   #247
no mods
Default
2005 trd offroad
52,000 miles
33in tires Elocked diff
trail - Steep, uphill loose rock with small shelves encouraging the rear to popup a few times.
no mods is offline   Reply With Quote
Old 08-12-2010, 01:19 AM   #248
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Originally Posted by no mods View Post
2005 trd offroad
52,000 miles
you're still under the 60k powertrain warranty...they might cover it.
Old 09-02-2010, 02:41 PM   #249
Chickenmunga
Chickenmunga's Avatar
Default
Not sure if this is the same issue?
2008 TRD OR
Stock BFG Rugged Trails
OME 3", 885 springs, TSB leafs with Wheeler's Offroad AAL, driveline spacer
30K miles
lots of normal driving, but I've gone to Brown's Camp a few times (mostly stuff like Cedar Tree, hardest was upper part of FB5 in the rocky area... and I crawl like a senior citizen)
Nothing actually exploded on me, I've just been having
-shudder at acceleration once I get to 10mph
-WUD WUD WUD sound between 55-65 (no steering vibes)
It's in the shop now, mechanic said it had the bearings go out. New rear diff being put in under warranty
2008 Tacoma 4x4 DC TRD Offroad
OME lift
Relentless Fabrication front plate bumper and hybrid tube sliders
285/75/16 Maxxis Bighorns
Chickenmunga is offline   Reply With Quote
Old 09-02-2010, 06:04 PM   #250
xcmountain80
Default
Well $1750 later, a rebuilt tranny we are back in business. Gears 1,2, and 5 were virtually gone and the torq converted was fawked.
A
02 4-Runner
Old 09-07-2010, 10:49 AM   #251
Chickenmunga
Default
Right, so I got the truck back Friday. Brand new rear diff.
The invoice says, "excessive clearance in front pinion causing damage to ring gear op #410101 T-1-91 T-2-43=2.4 test drive OK"
While I was there, I noticed that the Tualatin Valley Fire & Rescue had their FJC in for the same repairs. Theirs had actually gone in for the issue once before in Utah, but Utah did a shoddy job (didn' put things together well, used slilicon instead of gaskets) and this time it grenaded.
Anyway, I drove my truck from the dealer to the highway and went 4 miles. I noticed that the same issues came back, but were a bit muted.
I drove straight back and dropped the truck off for the weekend. Got a call back today, they say that they noticed the same. They disconnected the rear diff and put it in 4WD (essentially making it a front wheel drive) and said that the vibes go away.
I guess we chalk the rest of this up to the lift? I had the driveline spacers since day 1 of the lift.
OME lift
Old 09-07-2010, 11:14 AM   #252
doramider7
Default
Originally Posted by Dick Foster View Post
This is a good idea. I think it's restricted to the E lockers though.
Thanks Tim for starting this thread. It will be good info for when I go to arbitration, now that they've accepted my case.
1. 05 TRD Offroad (SR5) w/E-Locker VIN: 5TELU42N45Z052966, 02/05 CA
2. 285/75/R16 BFG A/Ts
3. 15,931 mi
3. Normal driving when breakage occured
ps3 downloads
ps3 game downloads
doramider7 is offline   Reply With Quote
Old 09-16-2010, 10:02 AM   #253
y2kbaja
y2kbaja's Avatar
Default
2nd rear end failiure.
Pre-ran for over 200 miles then drove home 250 miles. My daughter was driving home from school 2-days later and bang, 2 missing teeth on ring gear.
2005 Tacoma 4-door, Total Chaos LT front end, Deavers rear, Fox Shox, bed cage built by Richer Racing.
y2kbaja is offline   Reply With Quote
Old 09-19-2010, 09:16 PM   #254
carson
Default
1. 2005 TRD Sport
2 33's
3. 102,xxx
3. Wheeling
carson is offline   Reply With Quote
Old 09-19-2010, 11:23 PM   #255
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Originally Posted by carson View Post
1. 2005 TRD Sport
2 33's
3. 102,xxx
3. Wheeling
hard to call that one part of this issue...no offense
Old 09-30-2010, 10:03 PM   #256
RJS
Default
Howdy folks, I haven't been here in a while, but after catching up on this thread, I'm disappointed. Am I correct in understanding that the TRD OR rear ends are breaking in EVERY late-model Taco, not just the 05's? I came back cuz I was getting the trigger ready to pull to replace my 99 Taco with an 07-09.
Any help appreciated, thanks!
RJ
RJS is offline   Reply With Quote
Old 10-03-2010, 01:03 PM   #257
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
RJ
No, the issue was just with a small # of '05s with the elocker
Old 10-04-2010, 05:59 AM   #258
RJS
Default
OK, thanks! So the other year models mentioned in this thread were fluke failures, not a trend like those 05's? I definitely want the elocker for "those times when you need it", but I don't want to be pulling driveshafts and arguing with Toyota service. I don't expect to be doing a lot of off-roading. This truck will be a pavement-pounding daily driver with frequent forays onto dry, muddy, or snowy forest service/logging roads.
Thanks!
Old 10-04-2010, 04:57 PM   #259
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Thanks!
correct.
but...these trucks are not as tough as some of the commercials suggest so don't expect to do a scene from "Mr. Majestic" in your truck. (I'll let you google that one )
Old 10-04-2010, 08:10 PM   #260
RJS
Default
correct.
OK, thanks!
Old 10-04-2010, 08:14 PM   #261
rippinred
Default
I'm waiting for my rear axle to fail, 37's are taxing but so far so good. As long as it lasts till the rockjock 60 gets here. Any thing possible to extend the life of the rear end?
rippinred is offline   Reply With Quote
Old 10-04-2010, 08:19 PM   #262
S.B.
S.B.'s Avatar
Location: From San Diego, CA; Now in Colorado Springs, CO
Default
Don't beat it up.
2008 Tacoma 4X4 TRD Rugged Trail
SAWS 2.0 front
Toyforda springs in rear
255/85/16 Cooper ST's,
cheap Harbor Freight 6" lights with HIDs,
KC slim lights with HIDs
home made On Board Air
CBI Sliders
Built Right UCAs
ATO Front Skid
S.B. is offline   Reply With Quote
Old 10-04-2010, 08:55 PM   #263
rippinred
Default
well thats no fun, lol. You are right thou. If I break mine I'll let you guys know.
Old 10-05-2010, 12:06 AM   #264
taco4x4rar
taco4x4rar's Avatar
My Rig: 06 Tacoma
Send a message via AIM to taco4x4rar
Default
have the whole thing cryo/heat treated. It will buy you some time on 37s but not much, the real answer is a 1 ton rear.
Originally Posted by Jomentum View Post
I drink everclear for the flavor.
Originally Posted by Spacecwboy View Post
I'm still a homo!
http://toyotaoff-road.com/
Randy
2006 Tacoma x-cab 12" bobbed bed and the usual 3" lift with a locked rear and a lot of broken parts. Dana 44 soon
1992 Chevy C-1500 swapped D60/14bolt 454 and th400 (wrecked it)
taco4x4rar is offline   Reply With Quote
Old 10-05-2010, 07:28 AM   #265
RJS
Default
Originally Posted by S.B. View Post
Don't beat it up.
S.B.,
What is the "TRD Rugged Trail" - is that some TRD equipment, or do you mean the tires are BFG Rugged Trails?
Old 10-05-2010, 01:42 PM   #266
rippinred
Default
replacement axle has been ordered for mine. Choice was either a 1 ton axle or a hybrid 1 ton axle. I ended up ordering a fully built Currie rockjock 60 with an arb locker. Gonna keep the drum brakes, prefer them to discs for certain reasons, biggest reason was I have plenty of brakes even with 37's so I saw no point to spend the extra cash. This should end my axle worries. cheers
Old 10-08-2010, 02:47 PM   #267
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
That's what Dick wound up doing after blowing 3 R&Ps in a row...on 35s
different locker though...
Old 10-08-2010, 02:59 PM   #268
Chickenmunga
Default
S.B.,
Rugged Trail edition was a trim package.
-Black Baja rims
-Front skid
-Rubber all-weather mats
-Change to the TRD sticker
-black flares
OME lift
Old 10-08-2010, 05:31 PM   #269
RJS
Default
-Black Baja rims
-Front skid
-black flares
Thanks!
Sorry to be off topic, but I'm getting ready to shop for 07-09's. Want a DC Off Road. Never seen a Rugged Trail, it's not in my 07 full Tacoma brochure or 2010 Access Cab eBrochure. What year(s) was the RT package available, and was it only on top of an OR, or did it come on Sports also?
TIA, RJ
1999 PreRunner V6 X-Cab
<insert DC TRD OR soon>
Old 10-08-2010, 06:17 PM   #270
Chickenmunga
Default
Thanks!
TIA, RJ
It was released in 2008, very limited run because it wasn't very popular. I think it was almost limited to access cab, too.
If you have to compare years, I'd say go with a 2009 or above so you can get the ATRAC.
If you want to talk more, send PMs.
OME lift
You may not post new threads
You may not post replies
Forum Jump
rear tacoma wheel studs up front shiprekd1 Tires/Wheels 3 03-19-2006 06:40 PM
Rear end temp?? Jesters_taco Early Tacoma Tech 15 06-27-2005 01:27 AM
TRD Rear end..Complete.. TacoCrazy Parts/Electronics/Wheels & Tires For Sale 7 04-28-2005 06:37 AM
Rear end problems!! Ripcurlsurfin96 Early Tacoma Tech 22 04-01-2005 12:40 PM
Synthetic rear end from factory? smokintacoma Early Tacoma Tech 1 01-26-2005 12:48 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
