My Front Diff Hex Bolt is all Chewed up! - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 05-24-2006, 10:58 AM   #1
JoeNobody
My Rig: 2002 Silverado 4x2
Unhappy My Front Diff Hex Bolt is all Chewed up!
In my multiple attempts to remove the front 10mm Hex bolt drain plug from the front diff on my 2000 Taco 4x4 I have stripped the bolt up.
I am almost certain that the fluid has never been changed given the condition of the rear and transfer case fluid when I changed them. When it came time to remove the front drain plug I could not get it to come off. Using my huge breaker bar and lots of liquid wrench the drain plug refused to break loose. And after applying enough force I eventually stripped the nut up.
My question is how should I go about removing the drain plug now that itís stripped up? If it was a regular socket bolt I could use a "bolt out" style bolt remover except this is a hex nut style bolt. Do they make removal tools to use in these style nuts?
JoeNobody is offline   Reply With Quote
Old 05-24-2006, 11:00 AM   #2
elliot_irwin
elliot_irwin's Avatar
My Rig: Is that appropriate
Default
righty tighty lefty loosey
elliot_irwin is offline   Reply With Quote
Old 05-24-2006, 11:13 AM   #3
JoeNobody
Default
I wish it was that simple.
anyone?
Old 05-24-2006, 11:36 AM   #4
brendog84cj8
Bocephus For President
brendog84cj8's Avatar
Default
Weld a old lug nut or something you can get a socket on to the plug. I have a diff sittting on my bench right now with that same problem and am going to get a buddy to weld something to it so I can remove the plug with a socket.
95.5 Black extended cab Taco 2.7 4x4 Manual Hub
SAW's
Alcan Six leaf with Overload Bil 5125's
4.30's Non TRD
33x10.5 BFG AT's on 15x7 Stock Wheels
CBI Front Bumper
brendog84cj8 is offline   Reply With Quote
Old 05-24-2006, 11:42 AM   #5
Interex
Interex's Avatar
Send a message via AIM to Interex
Default
If worse comes to worse, you can pull the diff out and empty it through the CV sockets.
Harold
'07 Tundra Double Cab Limited 5.7L
'94 Toyota Supra Turbo PT76-GTS, Auto->6 speed
4X4 Conversion Thread
Interex is offline   Reply With Quote
Old 05-24-2006, 11:48 AM   #6
prezidentredz
prezidentredz's Avatar
Send a message via AIM to prezidentredz
Default
They they make a hex type of remover for stiped bolts. Im not sure who i knw snap-on makes them.
Uncivilized Creations. Anything Else Would be Civilized.
2000 Tacoma Xtracab TRD 2.7 5sp, LC Engineering Under Drive Crank Pully. 31x12.50x16 Superswamper SSR Radials. Front OME 882 Coils and HD Shocks,Rear Allpro Leafs and Downey Shackles. Allpro Skids + a Custom T-Case Skid. K&N Intake.
prezidentredz is offline   Reply With Quote
Old 05-24-2006, 11:59 AM   #7
96Toy
Default
I hammered a torx socket into mine worked awsome, i cant remember the size, use a size slightly bigger than the hole. but it beats welding to it.
96 Taco with 3 inch revtek lift. Custom homemade rear bumper, 3 inch pa bodylift and new 33x13.5r15 Intero LTB's
96Toy is offline   Reply With Quote
Old 05-24-2006, 12:03 PM   #8
tcmaboy
Glass is for sissies
tcmaboy's Avatar
Default
You can use a reverse twist extractor bit.
Please wheel responsibly.
Tread Lightly! Tread Trainer
tcmaboy is offline   Reply With Quote
Old 05-24-2006, 12:04 PM   #9
SCTaco
SCTaco's Avatar
Default
That sucks. I bruised my hand last time I removed my front diff plug. A real bitch. Try the weld method detailed above.
Taco 99' 4x4 Xtra Cab 4cl 2.7L, 6" FabTech, 35" ProComp MT, 5.29's, ARB front & rear locked down - ARB bumper w/Warn M8000, BudBuilt skid, All Pro sliders springs, 5150's, dual battery's etc...
SCTaco is offline   Reply With Quote
Old 05-24-2006, 12:12 PM   #10
JoeNobody
Default
thanks for the replys, i think i'll try a hex nut removal tool first, (if i can find one in town) then go to the welding idea.
does anyone know where to get a replacement 10 mm toyota diff drain plug at? If i get this old one out, i can stick a generic bolt it its place until i get a real replacement.
thanks
Old 05-24-2006, 12:15 PM   #11
PaulH
Default
You can also try to heat up the area around the bolt before you try to loosen.
PaulH is offline   Reply With Quote
Old 05-24-2006, 12:22 PM   #12
AZTaco
AZTaco's Avatar
Default
I'm thinking of getting one of these. Many here have recommended them.
http://frontrangeoffroadfab.com/nfos...b88bf2880930bc
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken.
2002 Toyota Tacoma, V6 4x4 w/ TRD
All-Pro coilovers, upper control arms and rear leafs, Bilstein 5125's (170/60), 32" Yokohama Geolander AT + II's
AZTaco is offline   Reply With Quote
Old 05-24-2006, 12:29 PM   #13
porkysan
Default
Marlin carries a magnetic one as well....very inexpensive.
porkysan is offline   Reply With Quote
Old 05-24-2006, 12:34 PM   #14
Kaistie
Desert Turtle
Kaistie's Avatar
Default
I agree with the welding idea. I have done this several times and it works great. Be cautious heating the plug up not to melt anything inside, or ignite the gear oil. Chances of this happening are pretty slim, but just be careful. I have personally experienced gear oil igniting in a diff and it's an ugly scene, smelly and messy too.
Pictures:
Kaistie is offline   Reply With Quote
Old 05-24-2006, 01:18 PM   #15
pat161
Default
You could also use a hammer and small chisel and knock it loose. I had the same issue on my 00 Runner and I ended up letting Toyota do it and they just knocked it loose w/ an air chisel.
pat161 is offline   Reply With Quote
Old 05-24-2006, 10:14 PM   #16
grillmasterp
Deal Master
grillmasterp's Avatar
Default
http://www.tacomaterritory.com/forum...58&postcount=3
Pg 77 (1999 Owner's Manual)
(!) Brake System Warning Light
This light has the following functions:
-Parking Brake Reminder
-Low Brake Fluid level Warning
grillmasterp is offline   Reply With Quote
Old 05-24-2006, 10:23 PM   #17
not2XS
Default
Mine is the same way. I gave up on it and bought a $10 oil suction thing to put through the fill hole. It got out about as much oil as I had put in before (I measured it), so it seems a good option, and it only took 1 or 2 strokes if I remember.
One thing to watch out for if you buy a replacement plug - the front diff drain is a bigger diameter than all the other drain & fill plugs, even though the front diff fill is the same size as the others.
not2XS is offline   Reply With Quote
Old 05-25-2006, 11:22 AM   #18
AfterShock
AfterShock's Avatar
Wink
thanks
The Toyota dealer
I had to replace the rear diff plug on mine, was 3 or 4 bucks. But it wasn't in stock so I had to wait a few days for it to be delivered.
AfterShock is offline   Reply With Quote
Old 05-25-2006, 12:45 PM   #19
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
I finally welded a 3/4" nut to the sucker...should have done this a long time ago, LOL It was pretty easy to do. just get a couple solid tacks on it, remove and finish welding. then clean it up so the nut doesn't have any weld boogers to get in the way of a socket.
I tacked the nut on using a 1/2" bolt to hold it on to the plug then touched up spots with a file and Dremel with a grinding wheel so my wench would fit on easily.
Then finish welding and file or grind off the excess on the nut faces
makes things much easier to work with...wrench or socket
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 05-25-2006, 03:00 PM   #20
gsgallant
Default
That's a good idea for getting the plug out when it's stuck / stripped, but be careful if you're planning on leaving this "modified" plug on your truck (especially if it's on your drain plugs). One reason that these plugs are designed to be flush with the diff casing when they're installed is to minimize the chance of them getting caught on a rock or something when you're off-roading and having them ripped out of the diff, leaving you stranded. The front diff is not bad, but the transfer case and more so the rear diff drain plugs are quite exposed.
2002, 4Runner, Auto, 3.4L, 5VZ-FE
Mobil 1 Synthetic Oil / K&N Oil Filter - Mobil 1 75W90 Synthetic gear oil in Front, Rear and Transfer, Extended rear diff breather, Westin Step Bars, "4-air" system for airing up/down tires, Deckplate Mod,
Andymod, Dual battery setup with Optima blue top deep cycle auxiliary battery
Mods to Come:
Auxiliary fuse box,
Full time power to aux power plugs from aux fuse box
gsgallant is offline   Reply With Quote
Old 05-25-2006, 03:20 PM   #21
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Umm, it would be nearly impossible to rip that front diff plug off, LOL
as for the rear, it is already a hex bolt, not an allen.
same with the tranny and tcase.
most of us have beefy skids under everything vital anyways
Old 05-25-2006, 03:27 PM   #22
Miguel
Miguel's Avatar
Send a message via AIM to Miguel Send a message via MSN to Miguel
Default
Awwww...you didn't stay with metric!? What kind of Toyota owner ARE you???
~Miguel
Miguel is offline   Reply With Quote
Old 05-25-2006, 03:43 PM   #23
tbst
Default
Wont a reverse bolt out work? Die set? Just dont use your hundred dollar set.
1997 2.7L Tacoma 4x4
tbst is offline   Reply With Quote
Old 05-26-2006, 06:04 PM   #24
shovelhead
shovelhead's Avatar
Default Stripped drain plugs
If you strike the plugs sharply with a hammer before you try to remove them, I've found they come out easily (don't murder it with the hammer)
03 ,ex cab taco, TRD ,auto 3.4 with an ARE cap (with enough time and enough money ya can fix anything)
shovelhead is offline   Reply With Quote
Old 05-26-2006, 07:48 PM   #25
JoeNobody
Talking
I'm likin' the welding idea. Today i did the super fast, get it done right now option, and that was to pump out the old crap through the fill plug and replace the fluid.
I'll break out the mig welder this weekend and weld a bolt onto it and pull that bastard out!
Old 05-26-2006, 11:19 PM   #26
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
~Miguel
actually it is a 19mm
that better?
Old 05-26-2006, 11:19 PM   #27
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
just make sure to get it centered
Old 04-13-2007, 09:49 PM   #28
wradar
wradar's Avatar
My Rig: 2002 4WD DC Tacoma
Default
I'm having the same problem with mine (stripped front diff drain plug). Is this the extractor you're talking about: http://buy1.snapon.com/catalog/item....re&dir=catalog. It's 13/32", which is slightly bigger than 10mm, so it should be fine, right?
If this doesn't work, I might go the storz route. If not that, then weld. (Dealership wants $95/hr to do the job themselves. AAAAAH!!! Hawaii sucks sometimes!)
Thanks,
-Radar
2002 Tacoma Double Cab 4WD TRD. Grey wire mod, Donahoe Extended-travel Coilovers, Camburg UCAs, OME Dakar Leaf Springs, Donahoe Rear-reservoir Shocks, Goodrich front & rear brake lines, Tundra front brakes, ARB bull bar, IPF 968cs driving lights, Delta bed box, Warn M8000 winch, Demello rock crusher sliders, Safari snorkel, TRD supercharger, Viair constant duty compressor & tank kit, Demello hybrid rear bumper, CS-144 alternator, CB radio, lots of other goodies.
My other ride hovers.
wradar is offline   Reply With Quote
Old 04-14-2007, 10:16 AM   #29
mojavehanna
mojavehanna's Avatar
Default
I agree, this works excellent.
mojavehanna is offline   Reply With Quote
Old 04-14-2007, 10:35 AM   #30
bigblacktoy03
bigblacktoy03's Avatar
Default
I had the same thing happen to mine. It had never been off and my truck only had 15K miles. that bitch would not come out and I stripped it.. I used a reverse tap out. Then i went to the stealership and paid like 8 bucks for a new one.
http://www.cardomain.com/ride/643603 03 ext.cab SR5 TRD V-6 supercharged/urd fuel mods 6inch fabtech lift+1inch RB, custom radflo coilovers, 4.88's, 35 12.5 BFG AT, 15x10 Micky Thompson classic ii beadlock black, stubbs sliders rhino lining, custom sound system, etc, etc, etc
bigblacktoy03 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
4.10 ADD front diff and rear 4.10 gears redneck Parts/Electronics/Wheels/Tires 6 04-23-2007 09:14 AM
Front Diff oil Seal ???? Toyotajoe Early Tacoma Tech 3 05-19-2006 08:29 PM
Aussie locker or Lock right for front diff? BigMudTruk Early Tacoma Tech 37 05-11-2006 10:31 AM
alignment? drive shaft? front diff? KevT Early Tacoma Tech 31 11-23-2005 03:10 PM
Front diff R&R with 4" ProComp lift? SgtMunger Early Tacoma Tech 9 11-16-2005 12:08 PM
