Sponsored Ad
Go Back   TTORA Forum > General Tech > Cheap Tricks
Thread Tools Display Modes
Old 12-06-2004, 11:25 PM   #1
Brain
Brain's Avatar
Send a message via AIM to Brain
Default Cheap and easy spare tire holder mod
While my bedbar only has 1 thing going across, I recommend 2 spaced about 6" apart to minimize tire wobble-age while wheeling. I did this because I was tired of my spare doing whatever the hell it wanted to, plus I can still slide things underneath the tire.
-The Brain
Brain is offline   Reply With Quote
Old 12-07-2004, 07:06 AM   #2
Valkyrie
Cracker
Valkyrie's Avatar
Default
What makes this a great mod is the re-use of the old tire winch. I would have never thought of it! Good job...
Valkyrie is offline   Reply With Quote
Old 12-07-2004, 09:54 AM   #3
jjrambo
Send a message via Yahoo to jjrambo
Default
Instead of adding a second bar I would say to add under the bar a spacer of about 4 inches or so. That way you can have easier access to the crank portion of the winch with the tire iron. at the bottom of the 4 inch spacer a flat plate.
or with the double bar setup just put some 4 inch lower extensions on there and run a plate inbetween.
just my
85Yota ExtCab Dlx BLEW UP
03Chevy S10 Xtreme ExCab 4.3L 5spd FOR SALE
Buying 05 Taco some day
Rambo Inc. NEW ITEMS LISTED
Forum.Drag FL.com
jjrambo is offline   Reply With Quote
Old 12-07-2004, 03:07 PM   #4
4xClover
4xClover's Avatar
Default
Hmmmm.....I remember seeing that in Moab!
'98 SAS on 37's
4xClover is offline   Reply With Quote
Old 12-07-2004, 03:08 PM   #5
Brain
Brain's Avatar
Default
Did you see my tire flopping around?? LOL
-The Brain
Old 12-07-2004, 03:10 PM   #6
Brain
Brain's Avatar
Default
Thanks Chris, there were just a few things I would've rather done. I think when I make a new bedbar, it'll be a double round tube one.
-The Brain
Old 12-07-2004, 03:11 PM   #7
Brain
Brain's Avatar
Default
just my
I don't even use the stock crank that came with the truck, a screwdriver works fine!
-The Brain
Old 12-07-2004, 03:26 PM   #8
jjrambo
Default
good point I guess, but that's just how i would do it. I do like the idea none the less. But seeing as I am more apt to have a lowerd truck I'll never be diong something like that unless I finally start making the cash I want to and can afford to have more than one good toy.
Forum.Drag FL.com
Old 12-07-2004, 03:40 PM   #9
Zackattak
norcal n00b
Zackattak's Avatar
Send a message via AIM to Zackattak
Default
Hey that looks great! thats cool how you used the stock spare hanger thing.
Zack
Zackattak is offline   Reply With Quote
Old 12-07-2004, 03:42 PM   #10
Brain
Brain's Avatar
Default
Zack
Thanks Zack!
-The Brain
Old 12-07-2004, 04:14 PM   #11
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
hmmmmm.....I'll have to remember that when I finish the bed cage for a second spare mount!!!
FAUX X 4 is offline   Reply With Quote
Old 12-07-2004, 05:32 PM   #12
4xClover
4xClover's Avatar
Default
Yep! Remember that too!!!
'98 SAS on 37's
Old 12-07-2004, 05:33 PM   #13
4xClover
4xClover's Avatar
Default
POSTWHORE!!!
'98 SAS on 37's
Old 12-07-2004, 11:18 PM   #14
Brain
Brain's Avatar
Default
POSTWHORE!!!
Hahaha we are all post whores...I mean...yeah and stuff
-The Brain
Old 12-08-2004, 10:42 AM   #15
Zzyzx
Zzyzx's Avatar
Send a message via AIM to Zzyzx
Default
Sweet little trick Brian. How far off the bed is the tire?
I know, I know, postwhore!
-James
Zzyzx is offline   Reply With Quote
Old 12-08-2004, 04:53 PM   #16
Brain
Brain's Avatar
Default
James, the tire is about 10" off the bed. Not a lot of room but still enough to get things underneath
-The Brain
Old 12-08-2004, 05:19 PM   #17
KStacoma
KStacoma's Avatar
Send a message via AIM to KStacoma
Default
That is an awesome idea! does it put stress on the bed rails though when the tire moves around?
KStacoma is offline   Reply With Quote
Old 12-08-2004, 07:13 PM   #18
RaideRNatioN
SPEAK ENGLISH!
RaideRNatioN's Avatar
Send a message via AIM to RaideRNatioN
Default
Very cool. I like the use of the stock tire winch.
RaideRNatioN is offline   Reply With Quote
Old 12-09-2004, 12:21 AM   #19
YUNADERIS
YUNADERIS's Avatar
Send a message via AIM to YUNADERIS Send a message via Yahoo to YUNADERIS
Default
sweet
where is the panhard?
YUNADERIS is offline   Reply With Quote
Old 12-09-2004, 01:38 AM   #20
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
slick idea
I would still come up with something under the tire to keep it tight to the bed or you may wind up ripping that bed bar right off during some crazy wheeling
(not that you drive like Dale or anything
hytenor is offline   Reply With Quote
Old 12-09-2004, 02:44 AM   #21
Brain
Brain's Avatar
Default
Thanks! It doesn't really put stress on the bed rails. Once I get off my lazy ass and buy more steel, I'll report back and let you guys know how my double round tube bed bar/tire holder works out.
-The Brain
Old 12-09-2004, 02:45 AM   #22
Brain
Brain's Avatar
Default
Originally Posted by YUNADERIS
sweet
I think on Friday I'm gonna start building one. I hope my Ferd shock towers aren't in the way of mounting the frame mount for the panhard...
-The Brain
Old 12-09-2004, 02:49 AM   #23
Brain
Brain's Avatar
Default
Originally Posted by hytenor
slick idea
Thanks Chris!! I think if I were to put something under the tire, it would ruin the space that could be used so I figure if I made a double tube bed bar with them spaced apart, it might solve the problem. Dean also came up with the idea to just bend some tube and weld it parallel to the bedbar but sticking out over the tire so it doesn't bounce around. I think it would still bounce around a bit with that, with 2 round tubes, there is equal force being put onto the tire in 4 places instead of 2. Make sense? LOL
-The Brain
Old 12-09-2004, 11:20 AM   #24
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
its the bouncing around that will eventually wear/fatugue and finally break the metal. the weight of the tire/wheel makes for a big lever. Mounting the tire hoist to a double bar and then adding something like what the stock spare holder has should do the trick though. That will transfer most of the stress to the tire brackets and bars. If later on it looks like the frame rails are getting still getting to stressed you can beef them up where the bars are mounted. I've seen some 1/8" diamond plate rail caps that would take care of that.
now you got me thinking of doing the same for my extra spare
Old 12-10-2004, 12:12 PM   #25
YUNADERIS
YUNADERIS's Avatar
Default
you can cut the part off the back if you want....thats if you gusseted the sides.....i know my towers are mounted high on the frame with little on the motor side...but we used 3/8ths plate to gusset mine
Old 12-10-2004, 03:10 PM   #26
Brain
Brain's Avatar
Default
Doooood, wtf are you talking about? Hahaha
-The Brain
Old 12-10-2004, 03:13 PM   #27
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
see, he's lost it...
Old 12-10-2004, 03:15 PM   #28
Brain
Brain's Avatar
Default
Damn Chris, you have rike a birrion posts!!!
-The Brain
Old 12-10-2004, 03:40 PM   #29
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
for now this form is getting too time consuming to scan and reply to so I'll probably wind up on the cali board more often and cut back here.
Old 12-10-2004, 03:48 PM   #30
Crash
Kill Yourself!
Crash's Avatar
Send a message via AIM to Crash
Default
Brian is a post whore!!!! Could have added some brackets fuckstick.
-Truck Details
A hardly seen 1996 Tacoma with some goodies that I don't use.
-Dan
Crash is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Sponsored Ad
Privacy Policy
Links monetized by VigLink
