Sponsored Ad
Go Back   TTORA Forum > General Tech > Performance/Engine/Exhaust
Thread Tools Display Modes
Old 08-14-2006, 03:58 PM   #1
scottdeane
Default Lack of Power
Im running a 3in body lift and a ToyTec 3in lift with 33x12.5-16 Durango A/T's. My truck has ok power but when i hook my trailor up and put my to race quads on it, the truck turns into a turd. I have a magnaflow muffer and removed on of the cats and did the deckplate mod. Is there anything else i can besides buying a supercharger. I dont want to regear it yet till i need new tires because i want 35's. Any help would be great.
scottdeane is offline   Reply With Quote
Old 08-14-2006, 04:18 PM   #2
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
You are already aware of your shortcomings. You need to re-gear. Look into 4.88 gears if you plan to upgrade to 35s.
Next Socal TTORA event - Miller Jeep Trail - June 22
www.ttora-socal.com
TTORA-Socal on Facebook
ShowStop is online now   Reply With Quote
Old 08-14-2006, 05:42 PM   #3
scottdeane
Default
Where is a good place to get gears? and do i need the install kits? My local toyota deal said they would install front and rear gears for $300-$350
Old 08-14-2006, 06:23 PM   #4
WickedTaco
WickedTaco's Avatar
Default
Yes you do need install kits. 300-350 for gear install front and rear is not bad at all. Go for it...
Since when does a toyota dealer install after market gears? I am impressed with that price coming from the dealer and all.
Wow
"True greatness comes when your tested"
WickedTaco is offline   Reply With Quote
Old 08-14-2006, 06:24 PM   #5
WickedTaco
WickedTaco's Avatar
Default
Yes, you do need install kits..
Old 08-14-2006, 10:20 PM   #6
scottdeane
Default
where is a good place to get gears and install kit. I called 4wheelparts and they said i need a different yoke and all this other stuff. it came out to be like 1100 bucks unistalled and 500 do to the front and 300 for install and i about laughed at him for the install cost. since i already had the quote from my dealership.
Old 08-14-2006, 10:58 PM   #7
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
Dont go to 4wp, they will sell you crappy Genuine Gears. Stick with Precision or Yukon if possible. Check with the guys at PORC for gear and install kit pricing. www.performanceoffroadcenter.com
If you have a 2002 or newer model, you will probably need a new pinion flange due to a pinion change on the newer models. PORC can tell you what you will need.
Where are you located? Zuk does some great work and he is in AZ. www.gearinstalls.com
www.ttora-socal.com
Old 08-15-2006, 12:09 PM   #8
scottdeane
Default
I live in N.W. Pa.
You may not post new threads
You may not post replies
Forum Jump
lost low end power... help? bigd9247 Performance/Engine/Exhaust 9 02-27-2006 04:51 PM
tundra S/C or Turbo?? snowbunny chaser T-100 & Tundra Tech 23 10-02-2005 10:04 AM
Power off timer? taugust Interior/Electrical/Electronics 4 06-30-2005 11:15 AM
No power in power steering MarzzTaco Early Tacoma Tech 4 02-28-2005 03:14 PM
Ignition On Power Sources TheChiefSinner Interior/Electrical/Electronics 5 12-30-2004 07:55 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
