Go Back   TTORA Forum > General Tech > FJ Cruiser Tech
Thread Tools Display Modes
Old 08-15-2006, 08:39 PM   #1
Tankota
Primordial Member
Tankota's Avatar
Thumbs up Rear Locker + ATRAC - Write up
***Updates***
The TRD edition has this working already from the factory.
Seems all the newer FJ's released after the TRD edition now have it working without the modification.
Also, here's a nice write up on doing the mod anotherway without cutting the wire in the engine compartment.
**End Updates***
Ok, it's been finaly done!
A BIG BIG BIG thanks to Alex H., he did all the study and theory behind it, working with the elec diagrams and logic flow of the FJ's systems - and he doesn't even have an FJ!! . I'm just the lab rat who was crazy enough to try it first. So yes, I now can have both the ATRAC system and the rear locker on at the same time, or just ATRAC, or just rear locker, or none of the above.
Ok, on to how to do it!!.. First off, do this at your own risk, yes this could void your warranty, no don't do it if you have no idea what you are doing, and nobody is responsable if you screw it up or anything else!! But if you want to use the rear locker and ATRAC at the same time, read on!
This is the master cylinder, with the VSC computer on the side of it. For those with service manuals and/or electrical diagrams for the FJ, the large connector with all the wires is A4, the smaller one is A5.
This is the wire you are looking for - it's the SMALL blue/yellow. It's pin 26 on the connector, in the electrical diagrams it's terminal EXI3.
You want to cut the blue/yellow, leaving a good amount of length. You then want to take the connector side of the blue/yellow, and using a T-junction or tap, connect it to the Black/orange wire on connector A5 (pin 1). You do not want to cut the black/orange, just tap into it. The remaining blue/yellow in the wire harness just tie away inside the harness, do not ground it or connect it to anything.
That's it! You now can use ATRAC with the rear locker. Damn that was simple wasn't it?
Ok, the theory behind it (all via Alex). The blue/yellow wire is a signal wire from the rear locker (actualy it's from the dash light circut). When the locker is off, this wire has +12v, telling the VSC computer that the locker is off and it can use ATRAC. When the locker is locked, this wire has 0v, telling the system the locker is locked and then it won't let ATRAC turn on. All we have done is take the wire, and tap it into the 12V acc power on connector A5. This tells the VSC computer that the locker isn't on, all the time, even when the locker is on. This doesn't affect the locker light or any of the other lights or system. It just fools the VSC computer into thinking the locker is off all the time.
In Alex's honor, for all his work on this, I think we should call this the Alex hack!
David Hale
Bright Ass Yellow 2007 Toyota FJ Cruiser:Project T2
Icon 2.5" reservoir shocks front and rear, Icon UCA and rear links, 34" Goodyear MT/R tires, Demello Off-road front and rear bumpers, sliders, and skids, 4x150W roof mounted KC's and safari lights, and my ATRAC-Hack
2007 Yamaha Grizzly 700fi 4x4
2007 Toyota Yaris S-Sedan
(DD)
http://www.TheDirtyLens.com
http://www.offroadingadventures.com/
Tankota is offline   Reply With Quote
Old 08-15-2006, 08:49 PM   #2
JohnGalt
Default
The AWM!!! Wowza - AlexAtracHack
JohnGalt is offline   Reply With Quote
Old 08-15-2006, 08:59 PM   #3
sbechtold
SAC'D FJC
sbechtold's Avatar
Default
Very cool mod. When are you going to test it on the trails? Do you have any concerns about ATRAC trying to apply the brakes to one wheel on a locked axle? I wish we knew more detail about how ATRAC works.
sbechtold is offline   Reply With Quote
Old 08-15-2006, 09:11 PM   #4
Tankota
Primordial Member
Tankota's Avatar
Default
ATRAC works by sensing wheel spin on each axle. If it senses one wheel on an axle spining faster than the other, it applies brake to that wheel to lock it and transfer the power to the other wheel. Since the rear is locked, one wheel on that axle can't spin at a diffrent speed than the other, so the ATRAC system never activates on that axle, it ignores it. It will then only activate on the front if it senses one wheel spining up there.
Toyota ran an FJ on the Rubi with a simular mod, and rumor has it they may enable this on the 08's
David Hale
(DD)
Old 08-15-2006, 09:27 PM   #5
Tankota
Primordial Member
Tankota's Avatar
Default
For some background history of how this mod came about, it orginated on the mud board:
http://forum.ih8mud.com/showthread.php?t=84238
Alex I already personaly knew from wheeling with him as part of The Trail Crew. We e-mailed back and forth the details of trying this mod, including wiring and electrical diagrams.
David Hale
(DD)
Old 08-15-2006, 09:59 PM   #6
treknwil
treknwil's Avatar
Default
In the FJ cummunity this is like the second coming of Christ.
2007 FJ Cruiser 4x4...Yellow and White. A-trac, rear differential lock, Upgrade package #2 with 17" alloys. 285/70-17 MTR's, Home made level lift, Rock sliders, LCA skides, All-Pro extreme LCA links, Home made Highlift jack clamps, 4 KC's on roof rack,
1987 4runner SR5 22RE 5spd. Budbuilt skids & transf. case cross member, Flowmaster. 32x11.50/15 BFG MT's, home made 1" body lift, sliders, winch plate.
Had a 81 PU SR5 4x4 long bed brand new as my first new vehicle.... loved that truck!
treknwil is offline   Reply With Quote
Old 08-15-2006, 10:16 PM   #7
FJ Cruiser News
Banned
Send a message via ICQ to FJ Cruiser News
Default www.fjcruiser.cc/forum
Hats off and a decent bow to the electrical wizards whom can look at scematics and figure this stuff out. IRL I am a plumbing contractor, Union
trained, 15 years old to 48 years old, I need no more practice, I have always held men whom can grasp scemantics of electrical systems and design to the highest level of intelligence. When it comes to electricity, I RUN, and dam fast at that! I am 99.9% sure that if I were to do this w/ the warranty policy I purchased, that covers much of the electronics on the vehicle, basically I bought (some will say threw away big money) a 1600 $ or so policy covering dam near everything. Oh well, I am very impressed w/ your skills though. Congrats!
FJ Cruiser News is offline   Reply With Quote
Old 08-15-2006, 11:06 PM   #8
Tankota
Primordial Member
Tankota's Avatar
Default
Donations can be sent via pay-pal to vaud "at" cyberverse.com I need a set of 17" Mojave Teflons so I can fit 34's. LOL..
David Hale
(DD)
Old 08-16-2006, 07:24 AM   #9
Tankota
Primordial Member
Tankota's Avatar
Default
Ok, it's been tested on an MT and works on them too, make sure your taps into the black/orange are good! Same person also took it off-road and verifed the ATRAC and locker are working with no problems.
David Hale
(DD)
Old 08-16-2006, 08:38 AM   #10
viter
viter's Avatar
Default
nice!!!
viter is offline   Reply With Quote
Old 08-30-2006, 05:24 AM   #11
Hotrodguru
Hotrodguru's Avatar
Send a message via ICQ to Hotrodguru Send a message via AIM to Hotrodguru Send a message via MSN to Hotrodguru Send a message via Yahoo to Hotrodguru
Default
Posted this on the FJ Cruiser Forum
PROOF that this mod is a BIG advantage.
http://www.fjcruiserforums.com/forum...ead.php?t=8917
Chris has the mod on his FJ, tackling this hill was not the easiest thing with our stock FJ's but Chris's did it alot easier than mine. I had to stop and keep switching between ATRAC and the locked rear diff. The process was repeated many times while Chris just gave it gas on the same climb and made it to the top on the first go run. I did too, but after alot of switching around. Can't wait to do this mod.
Guru
Hotrodguru is offline   Reply With Quote
Old 09-02-2006, 10:43 PM   #12
Strike
Strike's Avatar
Default
I did it. Works great. It only takes 5 minutes. It's not worth it Not to do it IMO.
2007 Toyota FJ Cruiser Black Diamond MT 4x4
Rear Locker ATRAC Mod
285/75R/16 Goodyear Wrangler MT/Rs
OME 3" Suspension Kit
More Mods to come as time and money allow.
Strike is offline   Reply With Quote
Old 09-03-2006, 01:58 AM   #13
highbeams
highbeams's Avatar
Default
Tankota and a few guys from 2 other forums gave the mod a major workout yesterday at Rowher Flats, and came away all smiles and thumbs up.
as they said, it works perfectly, giving you a locker in the rear and a computerized limited slip in the front. doesn't get better than that.
Ten fingers, Ten toes
www.adventure4x4.net
highbeams is offline   Reply With Quote
Old 09-05-2006, 12:39 AM   #14
yoshiboy
Default
Looking at the picture above, does he have stock tires? It looks like just Dueler HTs. I was just wondering.
yoshiboy is offline   Reply With Quote
Old 09-05-2006, 11:34 PM   #15
rfjtoy
Default
I went up Miller's Truck Trail yesterday, a-trac and rear locked. The tractions was great and it patched worked great all day LOOOOOOOng.
FJC Silver, ARB/Warn 8000, OME lift, IPF lights, 295 Nitto Grapplers, Dirty Parts= Video frt/rear, Street pilot 2720 GPS, Dual Battery, Cobra CB, CO2, ARB freezer/fridge, Atrac patch
rfjtoy is offline   Reply With Quote
Old 09-06-2006, 06:03 AM   #16
Interex
Interex's Avatar
Send a message via AIM to Interex
Default
Yes, he was running stock wheels/tires.
Harold
'07 Tundra Double Cab Limited 5.7L
'99 Tacoma Ext. Cab V6 non-TRD - Converted PreRunner -> 4X4
TRD E-locker, Man. hubs, independently controlled ADD diff, Aussie Front Locker, Warn XD9000i, CBI Bumper, 4xInnovations Sliders, Custom bedbar, 16x8 ProComp 1079's, Donahoe CO's, Chevy 63" Springs, Bilstein 5150 10" Resi Shocks, 3" RB BL, Hayden tranny cooler
'94 Toyota Supra Turbo PT76-GTS, Auto->6 speed
'87 Toyota Supra Turbo
4X4 Conversion Thread
Interex is offline   Reply With Quote
Old 09-06-2006, 08:02 AM   #17
calamaridog
Default
The combination of TRAC and rear locker is awesome. The 2000+ Land Cruisers have TRAC and run this combination with a rear ARB. Very nice to have options such as this and I'm not surprised to see Tankota leading the way. Sweet.
2000 UZJ100 Land Cruiser
TLCA #14734
Blue Ribbon Coalition #36400
Calamaridog
calamaridog is offline   Reply With Quote
Old 09-19-2006, 01:11 PM   #18
Hotrodguru
Hotrodguru's Avatar
Default
Well finally had the chance to try out the mod this weekend and I'm going to have to give it a big thumbs up! At the crest of this climb was a nasty drop off to the left. Since the conditions were muddy and slippery the vehicle would naturally slide down to the left towards some trees. On the right side the front right tire would catch some big roots which meant there was not grip to be had.
Well after some careful manuevering back and forth I was able to shimmy outta the bind. With the rear locker locked and A-TRAC off the front tires would spin with no grip. As soon as I enable A-TRAC I was able to progress forward enough that I could change my approach angle and get out of that tight bind. Once I was facing the direction I wanted to go I turned off the A-TRAC. I wanted some tire spin and a bit more speed to get out...worked like a champ.
Old 09-19-2006, 09:12 PM   #19
KungFooo
KungFooo's Avatar
Send a message via AIM to KungFooo Send a message via MSN to KungFooo Send a message via Yahoo to KungFooo
Default
I really want to do this mod, but at the same time I am affraid to cut into the wire.
2010 4Runner SR5 with stock everything
KungFooo is offline   Reply With Quote
Old 09-25-2006, 02:07 AM   #20
DigableKid
DigableKid's Avatar
Default
Did it, works great. Good lookin out Tankota and all affiliated!
It's all about Balance and Options Baby.
DigableKid is offline   Reply With Quote
Old 09-25-2006, 04:17 AM   #21
PWWFJ
PWWFJ's Avatar
Default
Another THANKS to Alex and Tankota. I did it also and works great. Yeee Haww!
PWWFJ is offline   Reply With Quote
Old 09-26-2006, 10:29 AM   #22
OFRD_GRL
save the bewbies!
OFRD_GRL's Avatar
Send a message via AIM to OFRD_GRL Send a message via Yahoo to OFRD_GRL
Default
provided its not raining this evening i will be doing this along with finally wiring my winch and putting in my rope line
~Una
My Trucks | Wheeling
OFRD_GRL is offline   Reply With Quote
Old 11-18-2006, 05:49 PM   #23
LandCruisers4Life
Default
If and when I do this mod.. Probably WHEN I do this mod, I will be making it to where I can switch it back and forth from stock to modified wiring configuration, and at the same time using some sort of waterproof connectors (marsh marine probably). That way if the Toyota tech plugs in his computer to do diagnostics he will not detect any difference. In other words, keep the wiring in modified form for everyday driving until you take it to the dealer, then switch it back to the initial configuration so Toyota isn't any wiser.
LandCruisers4Life is offline   Reply With Quote
Old 11-19-2006, 09:17 AM   #24
SAR_Squid79
SoCal Vice Pres.
SAR_Squid79's Avatar
Send a message via Yahoo to SAR_Squid79
Default
NICE JOB!
You should print up some professional looking instructions, make up some of those jumper wires and sell this as a kit on eBay for $25 a pop!!
~Jamie
2000 Tacoma TRD 4WD PreRunner
Supercharged. Locked. Armored.
Mountain: She can crawl it.
Ass: She can haul it.
"Roads? Where we're going we don't need . . . roads."
~Dr. Emmett L. Brown
My Rig My Trailer 4xInnovations
SAR_Squid79 is offline   Reply With Quote
Old 11-19-2006, 12:59 PM   #25
hytenor
Rocket Scientist
hytenor's Avatar
Default
Toyota will be offering this with a new TRD pkg...for around $7500 extra. Your mod seems like a slightly more economical solution, LOL
Originally Posted by rojodiablo View Post
But my rear is pretty good, and I have a lot of droop, and a ton of flex.
Originally Posted by awsumdc View Post
I like my strap-on.
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 11-19-2006, 01:41 PM   #26
FJAggie07
FJAggie07's Avatar
Default
I have done this mod and it is invaluable. Nough said.
FJAggie07 is offline   Reply With Quote
Old 11-19-2006, 10:25 PM   #27
Tankota
Primordial Member
Tankota's Avatar
Default
I still think they stole my write up for the TRD edition.. we should be getting some of that TRD package money.. lol...
David Hale
(DD)
Old 11-19-2006, 11:52 PM   #28
hytenor
Rocket Scientist
hytenor's Avatar
Default
I like my strap-on.
Old 12-29-2006, 11:35 AM   #29
Tankota
Primordial Member
Tankota's Avatar
Default
Minor updates added to post #1.
David Hale
(DD)
Old 12-29-2006, 11:50 AM   #30
hytenor
Rocket Scientist
hytenor's Avatar
Default
so, when do you do the crawler mod?
I like my strap-on.
You may not post new threads
You may not post replies
Forum Jump
05 Rear locker Question siambxr Early Tacoma Tech 10 09-28-2005 12:58 AM
Trade my TRD rear for a stock rear+cash? kyle Parts/Electronics/Wheels & Tires For Sale 15 09-09-2005 05:38 PM
To lock or not to lock? SP Jon M3 Early Tacoma Tech 77 01-13-2005 07:45 PM
Stock rear locker seth_js Early Tacoma Tech 7 12-17-2004 11:22 AM
Front or Rear Locker? tbrown Early Tacoma Tech 12 12-14-2004 07:00 PM
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
