Alternator upgrade - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 08-30-2006, 06:36 PM   #1
Hutch98
Hutch98's Avatar
Default Alternator upgrade
Before I ask I did use the search and no good data so wondering if there are recommended alternator upgrades when running aftermarket lights, winch, etc. Read an article in fourwheeler about electrical upgrades and checking on what people have done to keep the battery(s) charged.
Hutch
"Beer is proof that god loves us and wants us to be happy" Benjamin franklin
Hutch98 is offline   Reply With Quote
Old 08-30-2006, 06:40 PM   #2
jester_motorsports
Machinist Extraordinare
jester_motorsports's Avatar
My Rig: 99 Tacoma
Default
http://www.tacomaterritory.com/forum...ighlight=boyle
Josh
99 Tacoma
jester_motorsports is offline   Reply With Quote
Old 08-30-2006, 07:24 PM   #3
Hutch98
Hutch98's Avatar
Default
Thanks for the info
searched under the wrong area --one more
Hutch
Old 08-30-2006, 08:07 PM   #4
jester_motorsports
My Rig: 99 Tacoma
Default
Originally Posted by Hutch98
Thanks for the info
Hutch
No problem.
Josh
99 Tacoma
Old 08-30-2006, 08:44 PM   #5
equin
Default
Anyone know if there is any kind of junkyard upgrade that'll work for our Tacomas without much modification? I'm thinking of something similar to the 3G alternator junkyard upgrades for some Broncos, like in this thread:
http://fullsizebronco.com/forum/show...rnator+upgrade
In other words, if a Tundra or Toyota minivan has a higher-rated stock alternator, can it be easily retrofitted to our Tacomas? Just wondering about any less expensive alternatives, assuming there are any.
Ed Q.
03 Tacoma Ex Cab 3.4L TRD 4x4
equin is offline   Reply With Quote
Old 08-30-2006, 08:47 PM   #6
jester_motorsports
My Rig: 99 Tacoma
Default
They make an 80 amp alternator in addition to the 70 amp one that is most common.
Josh
99 Tacoma
Old 08-30-2006, 11:08 PM   #7
equin
Default
Yeah, thanks for the info. I read about that in the other thread you posted. I was just wondering if there was a 130 amp alt like the 3G alt found in some Ford Taurus's, Econolines, Mustangs, etc. that would fit ours without much retrofitting. Those cost only about $20 from a junkyard and alot of Bronco drivers retrofit 'em in their trucks. I wouldn't be surprised if the GM and Jeep crowd figured out about some higher-rated junkyard alternators that bolt on to their rigs as well, so I was wondering if maybe Toyota (or maybe even some other brand?) offered something more, like maybe a 100-120 amp stock alternator that might work without having to mess with complicated bracket fabrication and wiring and such. Probably not, but wondering in case someone else might have discovered something.
Ed Q.
Old 08-31-2006, 02:20 PM   #8
Guapotaco
Guapotaco's Avatar
Default
160 amps is enough to run a welder right? does the dick have one of these running his welder??
Guapotaco is offline   Reply With Quote
Old 08-31-2006, 07:45 PM   #9
jester_motorsports
My Rig: 99 Tacoma
Default
He'll correct me if I'm wrong but.....I'm 99% sure he's got a modded one from Boyle Future like mine. After all, he's the one that gave me the contact info for Boyle.
Josh
99 Tacoma
Old 08-31-2006, 08:11 PM   #10
shovelracer
shovelracer's Avatar
Default
If my memory serves me correctly there was a GM one that kinda fit with some spacers and rewiring and maybe the pulley. I believe it was from a suburban. Not the OE part, but aftermarket upgrade. A few years ago this is what I was told by someone who was selling some 200+ amp ones. Maybe Mr. Alternator ??? If some one else knows anything about this that would help cause I never went any deeper into it than that.
WWW.NJTTORA.COM
Inchworm crawler rocks!!
shovelracer is offline   Reply With Quote
Old 09-01-2006, 08:52 AM   #11
scotth
scotth's Avatar
Send a message via Skype™ to scotth
Default
I have a welder with the stock 80 amp alt. Works just fine. 1/4 inch plate no problem.
2000 Taco. 33's, All-Pro suspension, body armor. M8000. On board welder, 1000 watt inverter.
scotth is offline   Reply With Quote
Old 09-01-2006, 09:48 AM   #12
EnolaGaia
Default
I've seen reports that an AC Delco 160 amp alternator for a Chevy LS1 engine can be easily transplanted onto a 2RZ / 3RZ engine, with the only tweaking being in fitting / adapting the wire harness.
EnolaGaia is offline   Reply With Quote
Old 09-01-2006, 01:32 PM   #13
Teotwaki
Teotwaki's Avatar
Default
Partznet showed three OEM 2005 Taco alternators available
ALTERNATOR, Tacoma, 4.0L, 90 Amp 2005 $537.04 $413.52
ALTERNATOR, Tacoma, 4.0L, 100 Amp 2005 $562.17 $432.87
ALTERNATOR, Tacoma, 4.0L, 130 Amp 2005 $623.41 $480.03
I would need a core from a junkyard as buying a new alternator from Toyota is way out there.
ALTERNATOR, 4-Runner, 6 Cylinder 03-05 $623.41 $480.03
Teotwaki is offline   Reply With Quote
Old 09-01-2006, 03:02 PM   #14
EnolaGaia
Default
LCE (LC Engineering) is now offering Mean Green HO alternators for Tacomas:
http://www.lcengineering.com/newslet...p?p=view&id=70
... @ $370.00 each
You may not post new threads
You may not post replies
Forum Jump
