Go Back   TTORA Forum > General Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 09-20-2006, 12:44 PM   #1
crazy10toes
crazy10toes's Avatar
Default Help with locker mod
Anyone live in San Diego that has done the locker mod to their late model Taco. I am a visual person and would just like to take a few minutes of your time to see your setup. I have looked at the diagram in the free mod section and it still confuses me. Any help would be very appriciated.
crazy10toes is offline   Reply With Quote
Old 09-20-2006, 01:10 PM   #2
Sisyphus
Sisyphus's Avatar
Default
This thread may be of help, not sure if you've already read it.
http://www.ttora.com/forum/showthrea...ight=gray+wire
A helpful tip is that in advanced search mode you can narrow down your searches to include only late model tech. It will definitely help you improve your results.
By the way, you might want to introduce yourself in the tell us who you are thread. Welcome to TTORA.
Originally Posted by PaulW
BFH works. You just need to hit it like a man.
My Truck
Quit making excuses and Donate to the Blue Ribbon Coalition
"Well done is better than well said." -- Benjamin Franklin
I've relocated to here
Sisyphus is online now   Reply With Quote
Old 09-20-2006, 08:31 PM   #3
QuickStarr
Default
If you go to radio shack and get part # 275-218 and then go to tundrasolutions.com go into the tacoma forum and at the top find the locker mod stickey. Go to page 12 and look at post #178, it tells you exactly what color wires to hook to what # posts on the relay. It's very simple, I did it and I know very little about electrical systems. Once you get the relay and look at the # posts on the back you will understand. Just take your time.............
You can do it, it's easy!
QuickStarr is offline   Reply With Quote
Old 09-21-2006, 09:17 AM   #4
crazy10toes
Default
Thanks quickstarr! it was actually post #180. This is a much cleaner diagram then the others i have read.
Old 09-21-2006, 09:32 AM   #5
tacosupreme
Veteran
tacosupreme's Avatar
Default
I'm almost 6000 miles away but if you buy my plane ticket and beer while I do it I'll be there tomorrow to help in person-
Or just PM me if you get stuck during the mod, either way I'd be glad to help.
Here is the writeup, a little small, but still legible.
"The ability to quote is a serviceable substitute for wit." - Somerset Maugham
http://www.youtube.com/woodlogan
tacosupreme is online now   Reply With Quote
Old 09-21-2006, 04:55 PM   #6
jtski908
Default
I wonder if there is a way for the dealership to tell this mod was done via some kind of computer message? like when they check it for other messages....I also wonder what type of warranty that mod would void??
Kel
2006 v6 silver Tacoma xtra cab w/TRD, SR5, auto, tow package. 1.25" Daystar leveling kit.
Remember: stoopid hurts
jtski908 is offline   Reply With Quote
Old 09-21-2006, 11:09 PM   #7
tacosupreme
Veteran
Default
No, there is no way to tell that the mod has been done by reading ECU fault codes. Warranty wise, who cares, just "undo" the mod if you have to take it in for something related to the locker. It is pretty easy to hide your tracks in that department. What would it take like ten minutes and some heat shrink?
Old 09-23-2006, 07:37 PM   #8
shaner
Default
Lol Ive Been Trying This Mod With No Luck I Cant Get It To Lock In 2hi Im About To Give Up,im Frustrated At This Point.
shaner is offline   Reply With Quote
Old 09-23-2006, 07:40 PM   #9
Lost Canadian
Default
Is 'anything' happening, what seems to be going wrong for you?
Lost Canadian is offline   Reply With Quote
Old 09-23-2006, 08:14 PM   #10
tacosupreme
Veteran
Default
Is the lock light blinking? If so, try easing the clutch out a little with the steering wheel turned, it will lock in.
Old 09-23-2006, 08:50 PM   #11
TACODOC
Outsider
TACODOC's Avatar
Default
This looks easy enough, one more mod to add to my list...
Originally Posted by hytenor View Post
We have so many unconstitutional laws on the books from the last hundred years of judicial bull shit it would take an act of God to get rid of them.
TACODOC is offline   Reply With Quote
Old 09-24-2006, 08:50 AM   #12
shaner
Default
I HAVE AN AUTO BUT I HAVE THE CLEAR RELAY FROM RADIO SHACK 7-8 ARE THE COILS AND 5-6 GET THE LT GREEN AND LT LUE WIRES WHICH ARE ALSO THE BIG WIRES CORECT? 1=A1 WHICH IS THE PURPLE WIRE
4=B2 WHICH GETS THE PURPLE WIRE
2=A2=PINK 3=B1 LTGREEN/BLACK
Old 09-24-2006, 09:46 AM   #13
tacosupreme
Veteran
Default
And the purple wire has juice right? All you have to do is tap it, meaning current will still flow through the original purple wire. Is the Blue wire on the same bank (BANK "A") as the pink one? I didn't use a radio shack realay so I don't know the numbering system, but there should be a BLUE, PINK, and PURPLE on "bank A" and then a GREEN, LIGHT GREEN WITH BLACK STRIPE, and PURPLE on "bank B".
EDIT:Another common mistake people make a lot is connecting to the wires that run into the ECU. The wires on the ECU side should be dangling!
Old 09-24-2006, 12:45 PM   #14
shaner
Default
Looks Like Im Takin Mine Into The Dealer It Wont Go Into 4 Wheel Drive Now And The Abs And 4 Lo Light Stay On All The Time What A Nightmare This Has Become.
Old 09-24-2006, 12:52 PM   #15
tacosupreme
Veteran
Default
The ABS and 4LO light only come on when a) the locker is engaged, or B) the blue wire with the yellow stripe is grounded. That means you probably shorted it out somewhere. Several hundred people have completed this simple mod with no damage to any components, I doubt you hurt anything either. Just match up all of the factory wires and crimp them back together and "undo" the mod. Also is the truck in 4LO, or is just the light on? My guess is you shorted out the purple wire and popped the 4WD fuse.
Old 09-24-2006, 01:06 PM   #16
shaner
Default
Ill Check It Out Thanks For Your Help Im Goin Crazy!
Old 09-24-2006, 01:17 PM   #17
shaner
Default
4wd Is The Ecu-b Correct It Is Ok
Old 09-24-2006, 07:32 PM   #18
K.V.
Default
The Lt Blue & Lt Green wires ARE the "big wires" - correct. Your schematic is a little different than mine. I did mine this afternoon with the Radio Shack Relay# 275-218 (http://www.radioshack.com/product/in...tId=2049722&cp) and hooked it up as follows with no problem.
‘Lt Blue’ = 6
‘Lt Green’ = 5
‘Pink’ = 4
‘Lt GN/Black’ = 1
‘Violet’ (a.k.a purple) = 2 & 3
‘Red/Black’ = 7
‘Wht/Blk’ = 8
Hope this helps!
K.V. is offline   Reply With Quote
Old 09-24-2006, 08:24 PM   #19
tacosupreme
Veteran
Default
Check the 4WD fuse behind the little fold out cubbie just below the locker switch. third fuse to the right, bottom row. Relax dude, it's an easy fix.
Old 09-25-2006, 07:55 PM   #20
shaner
Default
LOL THAT WAS IT ILL TRY THE MOD IN THE MORNING SORRY FOR SPASIN JUST NERVOUS WORKIN ON A MONTH OLD 30,000 DOLLAR TRUCK SORY.
Old 09-25-2006, 07:58 PM   #21
shaner
Default
‘Lt Blue’ = 6
‘Lt Green’ = 5
‘Pink’ = 4
‘Lt GN/Black’ = 1
‘Red/Black’ = 7
‘Wht/Blk’ = 8
Hope this helps!
THANKS ILL TRY IT THAT, WAY BY MYSELF, I HAD A SO CALLED EXPERT HELPIN ME LAST TIME, THIS CANT BE THAT HARD, THANKS AGAIN.
Old 06-11-2007, 08:30 PM   #22
redhottaco
redhottaco's Avatar
Default
there are two pink wires and I don't know which one to use. my locker is on and so is abs light. the truck will not go into 4wd. Should have had help on this one, sigh.
2006 tacoma AC TRD 6speed, TRD catback, Volant cai, Donahoe co +2.5, Camburg uca, Alcan 8 , donahoe resi's, toyo mt, Go Broncos
redhottaco is offline   Reply With Quote
Old 09-16-2007, 11:12 AM   #23
kingcrabbercurry
kingcrabbercurry's Avatar
Default
‘Lt Blue’ = 6
‘Lt Green’ = 5
‘Pink’ = 4
‘Lt GN/Black’ = 1
‘Red/Black’ = 7
‘Wht/Blk’ = 8
Hope this helps!
I've got my wires hooked up as described above (I'm also using the same relay from Radio Shack) and the mod worked exactly ONE time. I backed down my driveway about 30 feet, engaged the locker and everything seemed to be working fine. I disengaged the locker and put it in 4 HI and everything worked well. Locker still engaged in 4 HI. Put it in 4 LO and tried to engage the locker, no dice. Now nothing about the mod is working. 4WD will still engage, but the locker won't go in in 4 HI or 4 LO. I checked the 4WD fuse, it's still good.
I have the wiring harness hooked back into the ECU, that's the way it worked once before. Should I leave it unplugged? Can anyone who has experienced a similar problem give me some guidance?
"There is no 'off' position on the genius switch." - David Letterman
kingcrabbercurry is offline   Reply With Quote
Old 09-16-2007, 02:15 PM   #24
tacosupreme
Veteran
Default
Sounds like you hooked the relay up to the ecu instead of the locker. Hope you didn't fry your ecu dude. Reread the directions very very carefully and you will understand.
Old 09-17-2007, 11:19 AM   #25
kingcrabbercurry
Default
No, I've got it hooked up correctly now. I think I wasn't turning the wheel enough to engage the diff when I was testing it. Everything works like a charm now, as evidenced by the 45 foot ruts I made in the rain-soaked field behind my house.
Also, for everyone who has not done this mod yet, I would encourage you to check it out. It took me maybe an hour total, and only cost about $25 at Radio Shack. Just make sure you tap the ground wire from the coil contact back into the white and black wire running to the ECU, I couldnt find an easily accessible bolt to ground to.
You may not post new threads
You may not post replies
Forum Jump
2005 Tacoma locker Mod 05yota4x4 Late Tacoma Tech 199 03-06-2010 06:34 PM
Rear Locker + ATRAC - Write up Tankota FJ Cruiser Tech 63 06-06-2009 11:35 AM
locker mod (grey wire) for the FJ Craigfireman FJ Cruiser Tech 2 04-03-2006 04:03 AM
recap on locker mod nation Cheap Tricks 0 12-10-2005 10:24 AM
Grey wire mod, locker not operating. BLOWNYOTA Early Tacoma Tech 7 10-12-2005 02:33 PM
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
