Go Back   TTORA Forum > General Tech > Exterior/Paint/Body Panel Modifications
Thread Tools Display Modes
Old 09-21-2006, 12:37 AM   #1
TacoDell
truck ~n~ tow
TacoDell's Avatar
Arrow Rock Lights and protection...
Well I finally have all the rock lights up and running...
Here's the locations I mounted them in and the direction they point...
Order... front bumper, below drivers feet (body mount support), rear cab (body mount support) and aft bed...
Understand I was trying to be as cheap as possible and trying not to drill anymore holes in the truck then needed...
I bought 8 of the Wally World Dirt Burner Fog lights cause they're expendable... Lucky for me cause the brackets that came with them lined up perfectly with pre-existing holes on the body mount supports... No drilling for the four lights between the wheel wells... Except I drilled for the grounds... The front one bolts to an existing filler panel I made for the AP bumper... and the rears are mounted to the panels that reinforce the tail light housings/bed corners... One hole is there and I had to drill one extra for each rear light bracket...
I ran 8Ga. wire from the 34R with an 80 amp inline fuse inline to the Buss Fuseblock (rated @ 100 amps) and relays... Which are all mounted on one board and siliconed to the floor in the cubby hole... I set this up to switch for right and left sides on two switches... From the fuse box the passenger side exits the hole exiting the rear of the cab on that side... the drivers side exits there... I ran 14Ga. wire from the fuse block to the lights... Covering the whole shabang with the black plastic flex hose... It looks factory and is zippy tied up neatly on the frame rails and with easy access to where each light plugs into the hot... I set up the relays so that the pair of lights covering both front and aft of each wheel is on one relay for each corner... Though it doesn't really matter as the right and left bank are wired into seperate switches (4 lights per side/switch)... It's only my preference so that if a relay were to go out... I would only lose one corner of the truck...
Well... I found that after everything was wired and ready to go... I noticed that a rock had cracked the lens of the drivers side light mounted to the rear of the cab... I realized that I needed to somehow protect that one and the one at the rear of the bed as stuff gets kicked up purdy good when the mud flaps are removed... so on to my next issue...
I needed to make some guards... Went shopping to Home Depot... Picked up two Galv. framed screen mesh 8" X 16" for a furnace or some shit ? (see pic)... And a 4ft. section of rain gutter debris mesh... (This stuff is the thickest I could find... Seems to be stiff enough for the task... But keep in mind... I was trying to not impede any of the light... so it had to be as open as possible...
I boxed in the pair at the rear of the cab (both sides) using the body mount supports as mounting points... The forward edge uses two sheet metal screws... and the rear was a tight fit so I used some stainless tie wire... It's a tight fit on the rear support as it's right next to the frames body support... It worked out fine but I had to cut holes for the nuts that protrude from the light brackets so the mesh could lay flat to the surface... Yeah if you had a mind to try and utilize the light bracket bolts to hold the mess... then have at it... I was feeling a bit lazy here... Plus I tied it thru an existing hole... making the only holes drilled... were the two on the forward support... All tightend down... and they seem fairly stout... Time to move out back...
Now these were much easier to deal with... Just a little bending to shape and ta da... I used a pair of dykes to put the bend in the Galv. framing... It bends easily... The forward lower edge is supported using an already existing hole (square) and a clip for the bolt to thread in... (Parts left over from removing my front tupperware off)... Two sheet metal screw hold the aft end... the forward upper end has no support at this time... Maybe an L bracket down the road if need be... I rolled the edge in so as to keep the whole thing from being a rock catcher... It is rolled in past the point of the rear inner plastic fender... With the mudflaps removed... there is no chance of the tires throwing rocks up into the basket... Now mud could be a problem with this set up but I don't know that yet... But I hate mud and avoid it like the plague... If I can go around... I will ...
Well that's about it... Sorry I didn't include every detail... But it's all really just a common sense approach... And utilizing what is already there... I'm sure there will be the critics... But hey... do something else if this doesn't appeal to you...
Oh and what good would this thread be if you can't see the lights working... LOL
Keep in mind... It was still daylight out and was parked in the garage... When it's really dark out... They illuninate much better... I'll try and get some shots of it in the dark... and add them to this later...
Hope this gives others some ideas...
EDITED for some more pics... Shoulda pulled the flaps for a better effect... as they're shadowing the tires...
'00 Taco SR5 V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...photo's
Trailer...
My Garage
TacoDell is online now   Reply With Quote
Old 09-21-2006, 12:42 AM   #2
YoTRacer158
YoTRacer158's Avatar
Send a message via AIM to YoTRacer158 Send a message via Yahoo to YoTRacer158
Default
You should make them all different colors, with relays to make them flash...that way you could throw some sick light shows after a long day of wheeling.
2004 V6 5spd 4x4: TRD Charger, URD Fuel Mods/AFR/Unlimiter/2.1" Pulley/Crank Pulley/Short Throw, Supra MAF, TrueFlow Filter, JBA Ti Ceramic Headers, SpinTech Exhaust, SPEC Stage 3+ Clutch, BentUp Front Bumper, Chaos LT/Kings, 62" Deavers/18" Kings/, Glassworks Supercharger Hood/Fenders/Bedsides, 15x8 Black Steelies, 33x12.5 Claws, 4.56's, RR Solid Motor Mounts
youtube.com/YoTRacer158
YoTRacer158 is offline   Reply With Quote
Old 09-21-2006, 01:49 AM   #3
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
I'll need to add this too... That and the flashy lights are sure to draw a crowd... LOL
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 09-21-2006, 01:53 AM   #4
YoTRacer158
Default
I made a mesh grill for the scoop on my glassworks hood and my buddy talked me into letting him put a blue led behind it (he wanted to put them EVERYWHERE, so I figured letting him put one on would make him happy and save my truck from being completely riced out)...waaaaay sick, I'll try to post some pics.
Old 09-21-2006, 02:50 AM   #5
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
This thing has a mesh grille in it... I just don't think I got the courage to mount that thing on my rig...
LOL
Maybe if it were silver... hmmm...
I don't know what ever possessed me to buy it in the first place...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 09-21-2006, 02:56 AM   #6
YoTRacer158
Default
Yeah seriously...makes about as much sense as your avatar...
I figured since mine is a REAL scoop I should probably put a grill in there to keep a good sized rock, or bird, or whatever else from flying into my engine.
Old 09-21-2006, 05:11 PM   #7
faithoffroad
faithoffroad's Avatar
Default
I really dig those screens. Great write up.
"If it has tit's or tires, you can be pretty sure your going to have problems with it"
faithoffroad is offline   Reply With Quote
Old 09-21-2006, 11:18 PM   #8
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
Thanks... I thought it was time for me to add something constructive... rather then just flaming noobs for not posting properly... LOL
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 09-22-2006, 12:03 AM   #9
ocdropzone
ocdropzone's Avatar
Default
Nice write up..My old lady just said oh great as she saw the gears going in my head about how I gonna use this to put rock lights on my taco now...
~Robb
1981 Trekker- 220:1
ocdropzone is offline   Reply With Quote
Old 09-22-2006, 03:54 AM   #10
bray
TTORA BRONZE Sponsor
bray's Avatar
Default
I like the S/C hood/scoop. I'd like to get a pair of functional louvers. I've seen some on E-Bay that came off of a 60's model Baracuda or something like that and they were badass. Wouldn't be extremely noticeable on my truck. It's black too.
Originally Posted by miguelitro
fat chicks and scooters. they may be fun to ride but you dont want your buddies catching you on one.
bray is offline   Reply With Quote
Old 09-23-2006, 12:09 AM   #11
firemandave
IYAOYAS
firemandave's Avatar
Send a message via AIM to firemandave
Default
nice writeup. Rock lights are one of my soon projects. I like the idea of the flashing lights, i think i'll have to setup an auxillary setup just for those for those crazy camping nights
1998 Tacoma 4x4 limited Trd
"Welcome to Thunder Dome B$^&h"
http://s23.photobucket.com/albums/b3...anDave/Tacoma/
Myspace
Aviation Ordnance/United States Marine Corps
firemandave is offline   Reply With Quote
Old 09-23-2006, 06:02 AM   #12
Animal
┌∩┐(◣_◢)┌∩┐
Animal's Avatar
Default
Nice Work Dell.. now you can light up my street when we have a power outage..
just curious.. but how well do you think yer mesh will hold up to landing on a rock.. or is that just for the little stuff that yer tires will kick up..
Animal is offline   Reply With Quote
Old 09-23-2006, 10:16 AM   #13
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
Thanks... Since yer going to go the flashy/bling light route... You'll need my bling/ hood scoop... bah ha ha ha...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 09-23-2006, 10:36 AM   #14
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
Thanks Erik... Those things are so far up under the body and protected by the sliders that getting crushed by a big rock would be nearly impossible... And my BFG AT's can only throw a certain size rock... That's what I'm trying to protect it from... the ones that get caught in the tread... those little 1/4' to 1/2" dirty bastards... The mesh will hold up to that... Maybe even larger stuff... But I won't know... 'til I know... The cab mounted "Rain Gutter Mesh" stuff is nearly 1/16" thick... It should keep it's shape... But even if it don't... It won't make any difference as long as it keeps deflecting those pesky little rocks... I'm not worried of how purdy they look... There up and under and out of sight anyhow... The lowest point of the basket is 4" above the lower frame rail... That's gotta be one narrow pointy rock to protrude up into that... I think I'd have worse problems if that were to happen...
Oh and if and when they do go to shit... The total cost of replacement ? Uh... $ 11.50... for all four locations... Shouldn't kill the bank...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 09-23-2006, 10:40 AM   #15
4TACXOMA4
4TACXOMA4's Avatar
Send a message via AIM to 4TACXOMA4 Send a message via MSN to 4TACXOMA4 Send a message via Yahoo to 4TACXOMA4
Default
I used the same lights as you, mounted in pretty much the same locations. The only bad thing about the lights, is how long they last. I don't run mine much, but out of 8 lights on my truck, only four of them still work, and I have used my rock lights maybe 4 times.
-Brent
1996 Xtra Cab V6
My Truck
SAS Parts For Sale
4TACXOMA4 is offline   Reply With Quote
Old 09-23-2006, 11:01 AM   #16
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
So what's the problem ? Wiring ? The bulbs burning out ? I'm thinking of using 35 watt bulbs as I've noticed they produce a lot of heat... Time will tell... And lastly... what more could you expect from Wally World ? Piaa quality ? LOL... I personally like the exchange rate... I buy a new set and return the old ones that go kaput... But so far no issues... And it's fun driving up and down the street with them on... gets tons of odd looks... LOL
Though with as many vehicle code book laws as there are in Cali... I'm sure I'm breaking some retarded law...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 09-23-2006, 08:28 PM   #17
4TACXOMA4
4TACXOMA4's Avatar
Default
I'm assuming the bulbs are just burning out, cause I plug a new one into the same wiring and it works just fine. I don't expect them to last forever, but it would be nice if they lasted more than 4 hours.
-Brent
1996 Xtra Cab V6
My Truck
SAS Parts For Sale
Old 09-23-2006, 11:28 PM   #18
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
Yeah i think 55 watt is too much for these small lights... And they get extremely hot... so that may be of consideration... And may be prematurely wearing out the bulbs due to the high heat and lack of heat dissapation... Or the bulbs are just shit quality... I know that PIAA offers a 35 watt h-3 bulb that draws 35 but puts out @ a supposed 65 watts or some crap... But PIAA's are too costly for my blood... so I'm trying to find an optional h-3/35 watt bulb... But in regards to yer complaint... I'd suggest that you find a higher quality bulb... Or recheck yer wiring for any shorts or lack of proper (good quality) grounds...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 10-03-2006, 10:04 PM   #19
YoTRacer158
Default
haha finally hound the pics of the LED's comming out of my scoop (looong gone dont worry)
Old 10-03-2006, 10:13 PM   #20
4xClover
4xClover's Avatar
Default
Nice job and great write up!!!
'98 SAS on 37's
4xClover is offline   Reply With Quote
Old 10-04-2006, 09:04 AM   #21
Jeff.
I hate fucked your mother
Jeff.'s Avatar
Default
Those look awesome...
Have you thought about LED's in place of those 55 watters? I know the price becomes a factor...but either way, the one's you got look like they'll do the trick x10...I was just thinking along the lines of reliability. How much were the Wally World ones each?
If I did more night wheeling, I'd put some on...Fuck, now I want some.
Jeff.
SN4WD.COM
SHUTUPANDWHEEL.COM
2002 Tacoma - with stuff done to it.
| 4 wheels & tires | 1 spare of each | silver | sr5 badge | lights | cb | cb antenna | toyota badge | TTORA stickers (long gone) | fender flares | grey interior | leaf springs | speakers | |
Jeff. is offline   Reply With Quote
Old 10-04-2006, 09:43 AM   #22
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
LED's are not bright enough unless you use multi's that have a bazillion LED's... and that will get very costly...
WW Dirt Burners... $14.00/Pair and some change... I haven't have issues with the bulbs... Even after this... ... http://www.tacomaterritory.com/forum...ad.php?t=45744 and besides these bulbs are fairly cheap to replace...
I've located some 35 watt H-3 replacement bulbs and will be trying them out... They may offer longer life... less drain... less heat... and put out nearly the same light as the 55's... http://www.autolumination.com/ sells them... ($9.00 each though ) Check them out... they have tons of LED options if you choose to go that route...
There are plenty of better light options out there... But this was done with a budget in mind... and cheap replacement... Harbor Freight sells a pair for about the same price... similar in size/watts (H-3)...
I like my cheapo set up... Plenty of bang for the low buck...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 10-04-2006, 10:04 AM   #23
Jeff.
Jeff.'s Avatar
Default
For sure! I really like the setup...
Jeff.
SN4WD.COM
SHUTUPANDWHEEL.COM
Old 02-16-2007, 11:46 AM   #24
06HAOLE
06HAOLE's Avatar
Default
Nice setup with those rock lights. I was going to say why not go simpler with a premade LED setup but from the pictures you posted your setup is 2-3 times brighter than any LED setup I have ever seen.
BFG / King / Total Chaos / Walker Evans / Soltek / DMZ / Currie / Wilwood / BMS / Defined Engineering
Krawltex Motorsports 512 996 9669
06HAOLE is online now   Reply With Quote
Old 02-18-2007, 05:31 PM   #25
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
Thank you...
I played around with some multi LED's before I did this and wasn't satisfied with the light output... Those pics are in my driveway... On the trail.. they seem even brighter... I think Wally World discontinued the Dirt Burner lights... But Harbor Freight has some fogs that look to be about the same size and maybe a little wider pattern... And they're probably cheaper then the Wally's... so those will be the replacements if I need to do so... Only problem with those little 55 watt lights is that they tend to run on the hot side... So far they are holding up though...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 02-18-2007, 07:52 PM   #26
Animal
┌∩┐(◣_◢)┌∩┐
Animal's Avatar
Default
Hey Dell... I need to get me some of these... then we can go hit up some night trails!! I was really impressed with yer lights from the Snow Wheeln' up in Idlewild!! I'll see if I can pick some up and wire the ish!!
now I just need a wiring diagram...
Old 02-19-2007, 01:34 AM   #27
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
You should see the LightForce units in action...
Oh bring it over and I'll show you how to wire them... I might even help... If'n I'm in a good mood...
Get those Harbor Freight ones... and watch for the sale on them... I know they were on sale at one point for like $ 9.00 a set... And that was a steal...
Oh and search you lazy white mexican... ha... The wiring diagrams are all over this forum... Hell you don't do anything at work anyways but fark around posting shiat here... You got the time to search...
Soon as I get my front diff breather re-attached
(It would seem my gear installer did a poor job of reattaching it ... Still waiting to see if Holcomb Creek was deep enough to get sucked in )...
He'll be correcting that Monday or Tuesday... (and that is going to be a biatch... without dropping the diff again... Cause I made a feeble attempt and said to hell with it... He farked it up... he gets to correct it )...
I'll be ready for another run by then ...
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 02-19-2007, 01:57 AM   #28
Animal
┌∩┐(◣_◢)┌∩┐
Animal's Avatar
Default
Ya... Imma keep an eye out for deals... I don't live next to Harbor Freight like you do... so... I'll scope out Lowe's or WallyWorld!!
Just give me the word on when you wanna hit up another trail!!
What are ya tryn' to say... I've been searchn' left and right.. I'm finding good stuff over here... I just need to put it to practice!!
Ya... There's not much to do here at work during the night shift... so I roam the board, and Intardweb for info on ish!!...
Old 02-19-2007, 02:02 AM   #29
TacoDell
truck ~n~ tow
TacoDell's Avatar
Default
Well since yer intardwebbing... You don't need to live next to HarborFreight... duh...
>>> www.harborfreight.com <<<
Truck...
~n~ ...photo's
Trailer...
My Garage
Old 02-19-2007, 02:18 AM   #30
Animal
┌∩┐(◣_◢)┌∩┐
Animal's Avatar
Default
he he... thanx for the link!!
See... I knoe how to Search
You may not post new threads
You may not post replies
Forum Jump
Clear Mask Paint Protection System Sucks. CMB1998 Off Topic 3 08-31-2005 09:20 PM
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
