Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 10-22-2006, 08:45 PM   #1
colorado125
colorado125's Avatar
Send a message via Yahoo to colorado125
Default Body parts question
Anyone replace a headlight assembly or grille yet? Full replacement with the mounting? How about prices and wher you got it please.
The grille is cracked on the mounting and the headlight on the driver side has the one piece of the mount cracked also. Its on a 2005 with the chrome grill surround.
Thanks.
2002 Dcab, 33" Toyo Open Country AT's on FJ80 rims, full OME suspension, 1" body lift, TRD Exhaust, SC, and Trans cooler, ARB Bullbar, SleeOffroad sliders, future is gears, front locker and cbi Fab rear bumper
colorado125 is offline   Reply With Quote
Old 10-22-2006, 09:24 PM   #2
TACODOC
Rendezvous Conspiracy
TACODOC's Avatar
Default
Check ebay... I got a color matched grill there for $80 plus shippin'
I see headlight assemblies there all the time.
Travel, Explore, Live: AMERICAN ADVENTURIST
TACODOC is offline   Reply With Quote
Old 10-22-2006, 09:31 PM   #3
colorado125
Default
Yeah, and I found out today that I'm not a big fan of wheeling on icy hills. Sliding back down hill 15 feet isn't good. And the worst part is how I stopped (hence, the need for new parts on a 2005)
Old 10-23-2006, 10:00 AM   #4
ocdropzone
ocdropzone's Avatar
My Rig: 81 Trekker
Default
Like 05TACODOC said, ebay is gonna be about your best/cheapest source for parts...
At least you did not set off their airbag....those get expensive..
~Robb
1981 Trekker- 220:1
ocdropzone is offline   Reply With Quote
Old 10-23-2006, 10:29 AM   #5
colorado125
Default
I'll have to look on there. It wasn't very fast, hence just the plastic mounting pieces broke on the grille(and a small cracked piece of the grille) and headlight. The lense/reflector and everything else is fine on the headlight minus that one plastic tab.
Old 10-23-2006, 02:26 PM   #6
TACODOC
TACODOC's Avatar
Default
You might try a little epoxy or something if it's just broken tabs on those parts... maybe engineer new tabs yourself, especially if the defects are not visible I'd try keeping them together on the cheap...
Old 10-23-2006, 02:59 PM   #7
jptiger
Default
Not a bad idea, I might be able to make something work for the headlight assembly. I'll check that out tonight. The grille will have to be replaced. Thanks for the suggestion.
JTiger
2005 Tacoma 4.0, 4X4
jptiger is offline   Reply With Quote
Old 10-23-2006, 03:35 PM   #8
colorado125
Default
Did you get a chance to stop by the dealership and see what they bodyshop said?
Old 10-23-2006, 05:32 PM   #9
jptiger
Default
Not yet. I'm shooting for Wed. Got my eye on a couple of parts on Ebay also. The cost is cheaper but they're prob not OEM so I have no idea about quality.
JTiger
Old 10-23-2006, 11:03 PM   #10
Sisyphus
Sisyphus's Avatar
Default
www.car-part.com
You can use it to buy parts, or simply to check prices on parts before you head out to the scrap yard. You can search for damn near any piece of the truck used.
Originally Posted by PaulW
BFH works. You just need to hit it like a man.
My Truck
Quit making excuses and Donate to the Blue Ribbon Coalition
"Well done is better than well said." -- Benjamin Franklin
I've relocated to here
Sisyphus is offline   Reply With Quote
Old 10-24-2006, 06:19 AM   #11
jptiger
Default
Anybody out there change out a headlight assembly on a new taco yet? I'm having trouble figuring out how to get to the lower mount. In the limited time I had to look last night it appeared the screw was inside/behind the bumper. Any ideas?
JTiger
Old 10-24-2006, 03:52 PM   #12
PB2theMax
PB2theMax's Avatar
Default
I got a new headlight on Ebay for $90. I think the dealership wants over $300 for one.
There are 4 bolts that hold the light. Two on top, one by the edge of the bumper, once you remove the grill (the grill pops off when you remove the two top bolts and two pins). The 4th headlight bolt is underneath on the side of a bracket near the fender. Ya can't really see it. You can just feel it. Ya gotta get your arm up in there and undo it with a short 10mm socket and ratchet. A small 1/4" drive ratchet is the way to go.
05 Tacoma Double Cab V6 4x4 TRD Sport
My CarDomain
PB2theMax is offline   Reply With Quote
Old 10-24-2006, 05:38 PM   #13
jptiger
Default
Thats what I was thinking. Thanks for the info. Hope to have this fixed shortly.
JTiger
You may not post new threads
You may not post replies
Forum Jump
Body Lift Question Higdon08 Suspension 19 10-14-2006 05:22 PM
Got all my manual hub conversion parts in! BigMudTruk Early Tacoma Tech 11 05-10-2006 09:25 PM
Tacoma Part number question :: Parts Dealers help! deephouse Suspension 1 04-05-2005 09:17 AM
Throttle body spacer question terminator Performance/Engine/Exhaust 11 01-23-2005 10:42 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
