easy lift on 97 landcruiser - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Land Cruiser Tech
Thread Tools Display Modes
Old 11-07-2006, 07:03 PM   #1
itsmeagain5789
itsmeagain5789's Avatar
Default easy lift on 97 landcruiser
my buddy of mine was wondering if theres any way that he can lift his cruiser at all without buying anything, like torsion bars adjustment or somthing else. I'm not sure if it has torsion bars because I've never really looked under it. if this is possible, can someone tell me what to adjust and how much a lift is possible?
New Rig - 2007 Taco Silver Double Cab 4x4 TRD Offroad w/ auto tranny.
3 inch toytec with 885's, aal's, dif drop
Custom Bolt on Sliders
ARB bumper
265/75/r16 Cooper Discoverer STT on stock rim
Tacoma roofrack
Tacoma weather mats
Dealer Alarm System
2 55w cheapo reverse lights (work good though)
Former Rig - 95 4x4 sr5 4runner. 161000 miles
1.5 inch allpro offroad rear coil springs
grille guard with 2 50w lights(i dont wheel too much at night)
32x11.50 bfg mud terrains
itsmeagain5789 is offline   Reply With Quote
Old 11-07-2006, 07:21 PM   #2
MERCER FABRICATION
MERCER FABRICATION's Avatar
Default
uh those >>dont<< have torsion bars. and there is no free lift. he could get a cheap body lift i guess but thats stupid. good shit aint cheap and cheap shit aint good
MERCER FABRICATION is offline   Reply With Quote
Old 11-07-2006, 08:03 PM   #3
Valkyrie
Cracker
Valkyrie's Avatar
Default
Originally Posted by badmoonrising
uh those have torsion bars. and there is no free lift. he could get a cheap body lift i guess but thats stupid. good shit aint cheap and cheap shit aint good
Shut up foo'.
Valkyrie is offline   Reply With Quote
Old 11-07-2006, 08:05 PM   #4
Valkyrie
Cracker
Valkyrie's Avatar
Default
Read more, post less.
The 80's are coils sprung front and rear. If your buddy hasn't even looked under his truck he's even stupider than you.
Old 11-07-2006, 10:31 PM   #5
MERCER FABRICATION
Default
oops.. i meant to say ...dont....
Old 11-07-2006, 10:38 PM   #6
MERCER FABRICATION
Default
btw. i never knew texans said "foo"
Old 11-08-2006, 08:14 AM   #7
Valkyrie
Cracker
Valkyrie's Avatar
Default
The kids here keep me up to date as best they can..
BTW, sorry for coming off like a major dick, I'm usually just an simple asshole.
Old 11-08-2006, 11:33 PM   #8
MERCER FABRICATION
Default
oh im used to it belive me. i work construction
Old 11-08-2006, 11:52 PM   #9
CHRINTHEDESTROYER
CHRINTHEDESTROYER's Avatar
Default
How much axle reuilding do you have to do to these things Chris? And is OME the best spring option? I would really like to get one o these for my family wheelin rig and there are 3 in the local paper. These things are awesome and I wish they were a little more affordable but with factory lockers front and rear and room for 7 I guess there is a reason
An armed society is a polite society
CHRINTHEDESTROYER is offline   Reply With Quote
Old 11-09-2006, 07:12 AM   #10
Valkyrie
Cracker
Valkyrie's Avatar
Default
I did none to mine except repack the birfs (easy) and regear to 4.88 and added ARB's F&R (mine was a 3FE).
They are great. I sold mne because we got a camper and it was a *good* tow rig, but not a *great* tow rig.
I miss that truck....
Old 11-09-2006, 07:55 AM   #11
CHRINTHEDESTROYER
Default
Thanks for the help Chris
Old 11-09-2006, 08:18 AM   #12
Valkyrie
Cracker
Valkyrie's Avatar
Default
NP.
Forgto to answer the other part of the question... OME rally has the best options for these trucks, from mild to heavy duty use.
If you want to get real radical, you can get close to 6" using the OME "J" springs and repress new castor adjustments into the front control arms. There's a bit more work than that, but it's basically a simple, easy to mod setup.
If you get serious later, give me a hollar- I had evey combination of OME shock & spring on there (except the 6") so I can help you figure out which setup would be best for what you want.
Regeraing to 4.88 (running 33's with a 3FE) made the greatest impact on the truck, but it wasn't easy- for the rear, due to the increased width of the ring gear, you actually have to grind down about 4 teeth on one side and 3 more 180* out for the center pin- kind of nerve wracking grinding on a new gear set.
It was a blast wheeling it, and very nice driving it...
Old 11-09-2006, 02:58 PM   #13
beno
Default
Slee Off-Road has both a 4" lift as well as a true 6" lift that are heavier rated springs. These are great springs and Slee Off Road is a great supplier and supporter of the 80 series LC.
Doing a lift is pretty simple on the 80 series. Swap everything out, put the new ones in.
That said, the higher you go, the more modifications you'll need to make to correct suspension geometry--things like:
1. Extended brake lines (Slee has these)
2. Adjustable front and rear panhards (to center the axle under the vehicles--Slee has these too)
3. Sway bar drops (Slee has these too--though I just took my sway bars off).
4. Bump stops
5. Upper rear control arms to correct rear pinion/xfer case angularity
6. POssibly a front or even rear DC drive shaft to correct for lift.
Good luck.
-onur
Oberlin, OH
1997 FZJ80: ARBed, Lifted, Slee'ed, Warn'ed, Slidered, Dual Batted, 3X Locked.
beno is offline   Reply With Quote
Old 11-09-2006, 08:56 PM   #14
KyleT
Send a message via AIM to KyleT
Default
slee 4" is the easiest way to lift.
96 T4R Limited Lifted E-Locked 4.88'd 295's on Lexus Rims
KyleT is offline   Reply With Quote
Old 11-10-2006, 02:05 PM   #15
JTSDIFFS
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
My Rig: Many toyota 4x4's
Default wow
sent you a pm
JTSDIFFS is offline   Reply With Quote
Old 11-10-2006, 02:06 PM   #16
beno
Default
A Slee 4" is not the easiest lift for the 80 series.
The Slee 4" requires significant suspension geometry adjustments to make it work right.
An "easy" lift would be the OME 2.5" medium or heavy lift option.
This requires little to no suspension modifications beyond the springs/shocks.
Another easy way to lift an 80 series is to throw some bigger tires underneath it.
285/75/16's work well, as do 305/70/16. Some have even fitted 315's underneath their rigs with stock suspension (you will rub).
Old 11-11-2006, 12:30 AM   #17
KyleT
Default
the ome does not come with caster correction last time i checked, which in my opinion is needed at any amount of lift on a LC. slee is 100 percent bolt on and doesnt need anything but bigger tires. im not knocking OME by any means.
Old 11-11-2006, 07:20 AM   #18
Valkyrie
Cracker
Valkyrie's Avatar
Default
You do not need caster correction for under 3" of lift.
Why does everyone insist on bending over and handing their wallets to Slee? I'll never understand...
Old 11-11-2006, 03:10 PM   #19
stu
stu's Avatar
Default
What other companies sell lifts of the same height that are comprehensive?
stu is offline   Reply With Quote
Old 11-11-2006, 08:07 PM   #20
itsmeagain5789
Default
do they just have spacers for these things, he's really just going for cheapness and looks. he doesnt need a 4 inch lift. 2.5 inches is good for him, but ome is still pretty pricy for theirs.
ARB bumper
Tacoma roofrack
Tacoma weather mats
Dealer Alarm System
Old 11-12-2006, 08:18 AM   #21
Valkyrie
Cracker
Valkyrie's Avatar
Default
Spacers ? Pricey? JFC it's only $60 a spring and $60 a shock, which is pretty damn cheap.
Your buddy really is an idiot, quit hanging around with him if he won't listen.
If he's that much of a broke-dick dumbass, sell the Cruiser and fuck up a cheap POS truck... like an S-10.
Old 11-12-2006, 03:26 PM   #22
beno
Default
You can have spacers machined locally for a reasonable price, but as the saying going, if you want to play, you have to pay.
The OME will be the easiest and cheapest in the long run.
Old 11-12-2006, 03:31 PM   #23
beno
Default
I don't agree with this.
Even with a 3" lift or less you are going to get some dive as well as some skittishness in the rig especially at highway speeds.
Granted, it won't be crazy wandering, but it will be considerable.
The OME bushings are worth the price, IMHO, for correct suspension geometry of a DD'ed vehicle.
That said, I give my money to Slee because:
1. They have a great product that is well-researched and tested. Not many in this country who know the 80 series cruiser as well as Christo and Ben.
2. They give excellent customer support: call them anytime if you have any problem with products that you ahve received from them. They bend over backwards to help you correct your issue. That to me is very important. Most companies don't know what "real" customer service is. Christo does and he stands behind his products 100%.
3. Christo supports the Land Cruiser community. He is a vital member providing important technical information on many different boards, most especially ih8mud.
4. He's a hell of a nice guy and he is an honest businessman. Those are important in my book.
So, if you'll never understand then I guess it would behoove you to not talk about a business you don't deal with.
Best.
-onur
oberlin, OH
Old 11-12-2006, 03:34 PM   #24
beno
Default
This is not correct and Christo would argue against you on this.
You need considerable changes to make the Slee 4" or 6" to work.
Give Christo a buzz and he'll explain it to you if you don't believe me....
But yes, caster correction is needed on any amount of lift if the truck is to operate well.
Best.
-onur
Oberlin, OH
Old 11-12-2006, 04:57 PM   #25
Valkyrie
Cracker
Valkyrie's Avatar
Default
Bullshit... I guarantee you. Don't repeat what you hear, because it isn't right- and you don't know what you're talking about. I have experience backing me up.
Old 11-12-2006, 04:59 PM   #26
Valkyrie
Cracker
Valkyrie's Avatar
Default
Please stop repeating this. Just because you opened your wallet doesn't make you an expert...
Old 11-13-2006, 01:00 AM   #27
beno
Default
Then, I'd like for you to come and drive my truck with J's and 1.5" spacers up front and OME trim packers in the rear.
With the OME caster correction bushings, I still have wandering at highway speeds and some dive at braking.
I don't know what's bothering you but there is no reason to use curse words or be antagonistic.
You are truly representing your homestate of Texas well.
This has been documented time and again and to tell someone who hasn't lifted an 80 before that everything will be fine is flat out lying.
Best regards.
-onur
Oberlin, OH
Old 11-13-2006, 01:05 AM   #28
beno
Default
So you are telling me that changing the suspension geometry from stock to anything else will not have any effect on the drivability of a vehicle, let alone the caster?
I think that you have been fed some misinformation.
Changing geometries from stock thus makes the original configuration different....correct?
This is intuitive beyond the fact of being correct.
I don't know what your problem is but if you do a simple search over at MUD in the 80's section there are tons and tons of threads....and not just ones that Christo has replied to...there are many experts (and I'm no where near that) that argue for a equal adjustment of suspension points when lift has been done on a vehicle.
So, you have never opened your wallet to a vendor or to someone that provides you with a service?
I think you are being disingenuous.
Best.
-onur
Oberlin, OH
Old 11-13-2006, 07:44 AM   #29
Valkyrie
Cracker
Valkyrie's Avatar
Default
Best regards.
-onur
Oberlin, OH
First off, don't change the subject when you are caught.
Firstoff, I didn't say "everything would be fine" so stop fabricating things.
You said "Even with a 3" lift or less you are going to get some dive as well as some skittishness in the rig especially at highway speeds."
That is not true because that does not have to happen. If you use OME light, med or heavies (about 2" in real world) you will have no need for castor correction.
When you come back with 3" springs and a 1..5" spacer, well no duh...
As far as representing Texas, well if straight, no nonsense talk that is true and based on experience is what you were referring to, I'll take that as a compliment.
Old 11-13-2006, 07:52 AM   #30
Valkyrie
Cracker
Valkyrie's Avatar
Default
Best.
-onur
Oberlin, OH
1. I never said that it didn't affect driveability
2. I have done suspension mods on every type of Toyota you can name
My remark wasn't that I've never paid someone, it's that because YOU paid (i.e. did none of the work) YOU are not instantly the knowledge base YOU are pretending to be... based on both the "quality" of your information and the fact that by your own admission your overpriced hackneyed suspension setup you are so proud of sucks.
You may have the last word, I am not letting you drag me down any more. One more for the ignore list....
You may not post new threads
You may not post replies
Forum Jump
getting a lift for my truck hybridcx Suspension 8 01-04-2007 05:49 PM
Lift Configuration HELP for 1996 Taco with specific Needs SuaveGato Newbie Tech 12 09-09-2006 10:01 PM
Lift Configuration HELP for 1996 Taco with specific Needs SuaveGato Early Tacoma Tech 4 09-05-2006 11:40 PM
Cutting a 3" Body Lift down??? NESurfer Early Tacoma Tech 2 08-23-2006 02:31 PM
Lift suggestions? Snowtaco27 Suspension 15 11-05-2005 10:15 PM
