Clutch Pedal Spring Bushing replacement - TTORA Forum
Go Back   TTORA Forum > General Tech > Cheap Tricks
Thread Tools Display Modes
Old 11-07-2006, 11:58 PM   #1
boostaholic9
boostaholic9's Avatar
Default Clutch Pedal Spring Bushing replacement
a long while back i had seen a thread on this topic but i just cant seem to find it to save my life! well it starts off with the squeeking of the clutch pedal then someone provided a write up on the bushing replacement. any help will help
i know that im going to get that one person to post "use the search", and i did!
i really am epecting that from DICK FOSTER!
thanks guys!
00 tacoma- Swapped, 5.13s, HP 44, 9" Locked & Armored
Originally Posted by WARTOY View Post
What are all of those hoses on the front of your truck for? Do you have a flux capacitor in there or just a laundromat?
boostaholic9 is offline   Reply With Quote
Old 11-08-2006, 01:43 AM   #2
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
Here's one thread... discussing that spring swap... http://www.tacomaterritory.com/forum...=clutch+spring
Type "Clutch Spring" in the search box and start reading... that's what I just did... Found this in only a few minutes... There may be more... I don't remember if there was an actual write up... Think it was just added to an existing Clutch Squeaking complaint...
Originally Posted by Scootn2nature View Post
so fuck off you little 18 yr old lying ass punk.
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is online now   Reply With Quote
Old 11-08-2006, 09:30 AM   #3
mrbigbri
mrbigbri's Avatar
Send a message via AIM to mrbigbri
Default
Don't be afraid to search Google too...
http://www.google.com/search?hl=en&q...=Google+Search
The first article is probably the oldest and best for fixing the problem (every 2 years or so...).
http://www.lieblweb.com/tacoma/Mecha...tchBushing.htm
1997 Toyota Tacoma 4x4
Supercharged 3.4
mrbigbri is offline   Reply With Quote
Old 11-08-2006, 10:29 AM   #4
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default Linear spring
Here's what you should do... fark that stock spring plastic bushing shit that you have to replace every coupla' years... This fix is cheap and easier... http://yotatech.com/showthread.php?t...lutch%2Bspring
Truck...
Trailer...
Old 11-08-2006, 11:04 AM   #5
Valkyrie
Cracker
Valkyrie's Avatar
Default
Here's one helpful thread: http://www.tacomaterritory.com/forum...ad.php?t=29814
and a write-up: http://homepage.mac.com/danny/clutch.html
and another: http://www.lieblweb.com/tacoma/Mecha...tchBushing.htm
For future use, try simple searches like Clutch Bushing and it will take you to 99% of the squeaky clutch threads.
So what exactly did you search for that came up with absolutley nothing???
Valkyrie is offline   Reply With Quote
Old 11-08-2006, 12:13 PM   #6
RotN'Rob
RotN'Rob's Avatar
My Rig: 2003 Tacoma
Default
I recently replaced my clutch pedal bushings. The write-up is in the knowledge base. One recomendation, replace all the bushings in the pedal assembly. I replaced them all since I had it apart. All the bushing from the stealership where only $12.00. It's fairly easy, it took me about 45 minutes to do the job. Good Luck
Originally Posted by adampfisters
(if I only had a garage door into my bedroom - and no fat chick comments on that either)
Traded in this;
for this;
03 Xtra Cab TRD V6 5 Spd
Lots O' mods. Bumper, skids, winch, blah, blah, blah.
RotN'Rob is offline   Reply With Quote
Old 11-10-2006, 09:59 AM   #7
boostaholic9
Default
thanks guys, also the clutch pedal has been getting harder to push in but im not too sure if it is because the spring has worn in to the bracket and causing it to bind or its the rod that slides into the master cylinder is not going in straight has any one had this problem? the master cylinder is new also.
Old 11-11-2006, 11:06 PM   #8
freejake3
freejake3's Avatar
Default
Best fix is to yank that f*@#ing spring and whatever is left of that bushing right on out. Don't look back. Subject is beyond a dead horse. Makes me wonder why I even bothered to respond......oh yeah I'm dying for Posts.
Surf to Live - Live to Surf
'99 Taco 3.4 with some goods
'95 4Runner 3.slow with some goods
freejake3 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
found a cool article on coilover comparison.... The Dude Suspension 2 01-23-2006 10:13 PM
x-post from suspension: coilover comparison, interesting reading... The Dude Early Tacoma Tech 0 01-22-2006 01:24 PM
Annoying clutch pedal design? Taco '06 lem Early Tacoma Tech 20 01-17-2006 06:44 PM
Stuck clutch pedal fix...2 of them. rojodiablo Early Tacoma Tech 2 05-27-2005 11:28 PM
Clutch Pedal Bushing StemsCornfedTaco Off Topic 6 05-05-2005 06:30 PM
