Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 11-10-2006, 09:12 AM   #1
cell4soul
Default Aftermarket Brake System?
Can anyone recommend an aftermarket heavy duyty brake system for an 05? I'm not thinking just pads, but a whole system.
cell4soul is offline   Reply With Quote
Old 11-10-2006, 09:26 AM   #2
Bear
H-O-L-Y-------S-H-I-T-H-H-A-A
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Default
Not sure if the aftermarket has caught up yet. I would venture a guess that your best bet would be to call Walbro or Bemko (?) directly and talk to a sales rep.
Also try Baer brakes as well.
But if you do go this route…it is going to be pricey!
BEAR
OVERKILL IS AN UNDERRATED ACHIEVEMENT
Originally Posted by abbott
… remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
GO SPURS GO!!!!
Bear is offline   Reply With Quote
Old 11-10-2006, 09:35 AM   #3
ryguy
ryguy's Avatar
Default
URD has the TRD BIG brake system. But I dont think it is much different than what we all have right now.
OLD TRUCK: 2005 Toyota Tacoma DC LB v6 4x4 TRD.
DMZed
HERE IT IS: DMZ Info:
http://www.dmzfab.com/ryanmac.html
ryguy is offline   Reply With Quote
Old 11-12-2006, 11:34 AM   #4
Gadget
Default
Yes, URD has only a couple of sets of the StopTech BKK for your application on hand. Once they are gone, they are gone for good. You can buy them later with a TRD logo on the calipers for a hell of a lot more...
Gadget
_____________________________________________
GadgetOnline URD
Gadget is offline   Reply With Quote
Old 11-12-2006, 04:57 PM   #5
cell4soul
Default
Thanks for the info, I called URD Friday and haven't heard back, I am going to try them again on Monday.
Old 11-13-2006, 12:34 AM   #6
midengine3sgte
midengine3sgte's Avatar
Default
what the major differnce between stock and using the stop tech? and does anyone make a rear disc kit yet or can you use the stock ones from the 4runner or xrunner.
06 TACO DC LB TRD SPORT 4X4 HOES ALL AROUND RESI IN THE REAR, DEAVER 10 PACK IN THE REAR, DEMELLO SLIDERS, BANKS EXHAUST,URD Y-PIPE, BLACK PRO COMP WHEELS, BFG MUDS 285/70/17, CAMBURG 1" REAR BLOCKS
08 TUNDRA 5.7 CREW-MAX 4X4, AFE INTAKE
07 TRD FJ AT 4X4 TRD CAI&EXHAUST
88 TOY 4X4 DOWNEY LIFT,INTAKE&HEADER(SOLD)
91 MR2 GT 30 TURBO 550HP(SOLD)
85 COROLLA 20V
midengine3sgte is offline   Reply With Quote
Old 11-13-2006, 12:10 PM   #7
MaxVelocity
Default
The major difference is brake fade. StopTech makes for one hell of a nice brake setup for a lot less $$$ than Brembo. Larger, thicker rotor combined with a large pad surface area = somewhat better stopping but A LOT less brake fade after contineous hard braking.
Here are my experiences with brakes from racing on the track.
1. Brake pads - some pads have a good initial bite but will be less effective when the rotors are hot. More performance types of pads usually don't brake well for a second but then will stop you a lot better as the temp of the rotor climbs.
2. Rotors - Standard blank rotors do the job but slotted rotors tend to provide for better braking as they help dissapate gas buildup and get rid of dirt. Cross drilled rotors are ok, but slotted are the new thing.
3. Brake lines - There is a HUGE difference in feel between regular rubber lines and steel braided lines. When you hit the brakes, the rubber lines will expand and as heat increases they will expand more as the rubber heats up. The steel braided lines don't expand at all and the pedal feel is very solid (almost stiff).
4. Brake fluid - Brake fluid varies widely. If you're heavy on the brakes you may want to look into a racing brake fluid. They're a bit more expensive but will not boil or break down as fast OE/OEM, and the stuff at kragen.
I plan to upgrade the brakes on my 06 DC next couple of months so I will give Ya'll feedback. Plan is to get some slotted rotors front, new pads (Hawk pads front and back), steel brake lines and racing brake fluid. Hopefully it will give close to the same feeling as my old track/street car.
MaxVelocity is offline   Reply With Quote
Old 11-13-2006, 12:14 PM   #8
peekay331
peekay331's Avatar
Send a message via AIM to peekay331
Default
any idea where i can replace all my front and rear brakelines? i found these on ebay:
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
i have unresponsive brakes, and after i bled them last night (with my motiv brake bleeder), they now pull to one side during braking!
http://community.webshots.com/user/peekay331
http://community.webshots.com/user/peekay330
2001 D-cab 4x4 TRD
32" BFG AT on 589's
King coilovers
Alcan springs
Bilstein 5150's
1.5 bodylift
ARB bumper
Demello sliders
RDS auxiliary fuel tank/tool box
Bel air shell
Garmin 2610 gps and Gpsmap 76
Extremeair 3/4 hp knockoff
motojackrack
peekay331 is offline   Reply With Quote
Old 11-13-2006, 12:43 PM   #9
MaxVelocity
Default
sounds like you still have some air in the system near the other oposite side. Not sure about those hoses you linked to but they won't fix your current problem.
StopTech carries SS brake lines and for racing brake fluid you can get Motul or ATE.
Here is where I get my ATE racing brake fluid:
ATE Brake fluid
StopTech SS brake lines
Old 11-13-2006, 12:50 PM   #10
peekay331
peekay331's Avatar
Default
ATE Brake fluid
yeah, i'll have to check that out tonight.
the stoptech lines look great, but they only have fronts. any idea where i can get the rears too? basically, i want to improve the brake feel and make it more responsive.
2001 D-cab 4x4 TRD
32" BFG AT on 589's
King coilovers
Alcan springs
Bilstein 5150's
1.5 bodylift
ARB bumper
Demello sliders
Bel air shell
motojackrack
Old 11-13-2006, 01:50 PM   #11
tonestoyo06
tonestoyo06's Avatar
Default
yeah but the one that TRD and URD has is for the X-Runner ONLY. on top of that, you would need a bigger wheel to cover the disc. (i believe its 18's.) i want aftermarket brakes for the other trucks, and i'm wanting a rear disc brake conversion too. the drums are really holding up to my 35 inch tires.
06' Prerunner
K&N CAI Banks Exhaust
Mickey Thompson 315/70/17 ATZ
Mickey Thompson Classic Locks
tonestoyo06 is offline   Reply With Quote
Old 11-13-2006, 03:02 PM   #12
MaxVelocity
Default
from my track experience, BBKs are good primarily for constant hard braking where brake fade is a serious issue. The work around to actually buying a BBK is to get better replacement parts. I'm planning to contact Hawk to see if they have a pad like the HPS which is a street/track pad. It brakes well initially (not as good as OEM) but will keep braking when hot way past what the stock pads can handle. A true race pad is really bad for the street or offroad because they don't brake worth $hit until the brakes are hot. Also slotted rotors will help dissapate the gas buildup between the pad and the rotor as heat increases as well as give a place for dirt to go and prevent the pad from glazing over. I'll do some research on the rears, I've never had drums before ... LOL
Yeh, and the other problems with BBK is that you may need to install adapters for the calipers, change your backspacing/offset, may require larger diameter wheels, wheel spacers, and may not be compatible with ABS. Basically, headaches come with the package unless it was designed as a factory upgrade (would think that if it's TRD then it should not be a problem other than the wheel clearance issue).
Old 11-13-2006, 08:54 PM   #13
Gadget
Default
We have StopTech brakes for many applications. We are sold out of the XRunner brakes and will never have them again form the looks of things.
Gadget
GadgetOnline URD
You may not post new threads
You may not post replies
Forum Jump
Aftermarket radios and the 6-speaker system nilson Interior/Electrical/Electronics 23 06-18-2005 08:08 PM
OT: Aftermarket Brake Hoses Shakerhood Off Topic 15 06-14-2005 02:01 AM
nastly brake problems... supahonkey Solid Axle Swap Tech 3 06-02-2005 06:35 PM
Flushing brake system 97TacoDude Early Tacoma Tech 12 05-12-2005 06:24 PM
brake system flush mohawk17 Early Tacoma Tech 3 01-03-2005 09:45 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
