Bump Steer Correction for 05-07 Tacoma? - TTORA Forum
Go Back   TTORA Forum > General Tech > Suspension
Thread Tools Display Modes
Old 11-12-2006, 09:09 PM   #1
bulletboss
Question Bump Steer Correction for 05-07 Tacoma?
Hello All,
Newbee to this site. Bought my '06 Taco 4x4 DC SB w/ TRD Off Road pkg in May. Installed a Toytec 3" lift kit about a month ago and 285/75-16 Yoko AT/S tires on Eagle 16x8 rims last week, and now I have some pretty pronounced bump steer. Wasn't so bad when I just had the lift kit and stock tires and rims, but when I mounted the new larger tires and rims it really became pronounced. Hence, two questions:
1. Anybody know of a bracket kit to mount the steering rack lower, or one that raises the tie rods on the steering knuckle? I've Googled it quite a bit and haven't found anything out there.
2. After crawling under the truck I noticed that the tie rod ball joints mount from under the steering knuckles. Can they be reversed so they mount from the top instead? This would appear to decrease the tie rod angle considerably.
Thanks in advance for your help.
bulletboss is offline   Reply With Quote
Old 11-12-2006, 11:59 PM   #2
ryguy
ryguy's Avatar
Default
did you get it aligned? That usually solves things!
OLD TRUCK: 2005 Toyota Tacoma DC LB v6 4x4 TRD.
DMZed
HERE IT IS: DMZ Info:
http://www.dmzfab.com/ryanmac.html
ryguy is offline   Reply With Quote
Old 11-13-2006, 06:37 AM   #3
banThis
banThis's Avatar
Default
I'm curious what you are calling "bumpsteer" with ifs and rack?
banThis is offline   Reply With Quote
Old 11-13-2006, 07:43 AM   #4
bulletboss
Default
It's all aligned - had it aligned after the lift was installed, and again this past weekend after the new tires were mounted. So no issues there. New tires/wheels were completely balanced, too, when they were mounted.
Bump steer is the condition where the tires going over bumps or undulations in the road cause instant toe changes to be transmitted through the steering linkage and felt directly through the steering wheel. It's caused by the tie rods traveling in a different arc than the suspension.
Most factory suspensions are engineered for zero bump steer. That, of course, can go out the window if aftermarket parts are installed and the suspension geometry changes as a result.
You may not post new threads
You may not post replies
Forum Jump
Bump Steer UTKtacoma Suspension 12 02-09-2006 06:37 PM
found a cool article on coilover comparison.... The Dude Suspension 2 01-23-2006 09:13 PM
steel wheel tacoma same as alloy wheel tacoma? Alex Early Tacoma Tech 3 07-27-2005 05:46 AM
Yikes, Bump Steer! Eztrog88 Early Tacoma Tech 9 06-11-2005 08:19 AM
Front TrueTrac fitment on a Tacoma Question kytann Early Tacoma Tech 7 01-12-2005 07:26 PM
