Sponsored Ad
Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 11-27-2006, 10:59 AM   #1
RENEGADE76254
Send a message via AIM to RENEGADE76254
Default Time for Upgrade - Maintenance
So I am nearing 100k on my Tacoma (3.4 auto ext. cab). Mods are OME882 up front, rebuilt leafs in rear, 33x10.50 BFG A/T on stock alloy 15x7. Still stock 4.10 gears in rear. And as much as I hate to admit it my truck is a Prerunner, I wish I had gotten a 4wd now, but none the less, Its still my truck and I love it. So for the Christmas season I have asked only for money and my grandparents and parents have agreed to give the gift early so I can work on my truck during Christmas break (I'm in college). With two and a half weeks left I am starting to plan and order parts. I have about $400 to work with.
First off I am getting new front shocks, and everybody I've talked to says use OME shocks with OME coils. --- So OME shocks approx. $200 (free install, my girlfriends dad is a service tech and has a coil compressor at his shop)
Next my truck is near 100k and believe I need to change my transmission fluid. --- To have it drained and filled and all is about $80.
That leaves approx $120.
I know $120 is not much at all, heck when it comes to trucks $400 is not a lot either. How would you folks use the last 120? would you just save it and put it in the bank? or would you use it on something else? should I change out or upgrade anything else at 100k? plugs, wires, etc etc?
Thanks in Advance...
-SLIM-
1999 TOYOTA TACOMA PRERUNNER
RENEGADE76254 is offline   Reply With Quote
Old 11-27-2006, 11:02 AM   #2
Dick Foster
Numba 2 Ho
Dick Foster's Avatar
Default
At 100K it's time for a timing belt and water pump if you haven't as yet.
I admit to being Crazy but I'm not Stupid
Dick Foster is offline   Reply With Quote
Old 11-27-2006, 11:12 AM   #3
RENEGADE76254
Default
Is timing belt something I do can myself with mechanic help, or should it be taken somewhere? what about the water pump? Does brand matter, I hate to pay Toyota's insane high prices for these parts.
-SLIM-
Old 11-27-2006, 11:13 AM   #4
Dunk
Dunk's Avatar
My Rig: 2004 Tacoma D-cab
Send a message via MSN to Dunk
Default
you could save some money on the tranny change and do it yourself. Im with dick on just doing the 100k maintenence Items.. Youll need to DIY as the parts will eat up what you have left.
Built 2004 D-cab Tacoma.
Dunk is offline   Reply With Quote
Old 11-27-2006, 11:17 AM   #5
RENEGADE76254
Default
I don't know if this matters but I reckon it can't hurt to include. When I installed my lift and tires I noticed a drop in gas millage, and it seemed to be consistent, within the past 3 to 4 tanks, I have noticed a dramatic decrease in millage. For example, the trip to and from college took a 1/4 tank, recently its been taking more like 3/8 of a tank, no a/c or heater on , using cruise control. all interstate, no stop and go.
-SLIM-
Old 11-27-2006, 11:18 AM   #6
RENEGADE76254
Default
I don't know for sure but for some reason I remember hearing that if you drain and fill yourself it will only remove about 1/2 of the fluid. It has to be pumped to drain it all. Can i pump it myself, if so, how?
-SLIM-
Old 11-27-2006, 11:21 AM   #7
My Rig: 1999 tacoma
Default
x3 on doing the t-belt and water pump. they are on my list of things to do this winter break from school. The few hundred you spend there can save thousands down the road. And i would only use toyota parts.
I like goats
87 cherocar
ike is offline   Reply With Quote
Old 11-27-2006, 11:23 AM   #8
Dick Foster
Numba 2 Ho
Default
You can do it.
Old 11-27-2006, 11:27 AM   #9
Dick Foster
Numba 2 Ho
Default
That is normal. You've jacked the truck up in the air and increased drag. You have made the engine do more work. Unless you regear your diffs by the same percentage of tire size change you will also have a loss in getting away from stop signs and such. In the world of physics, nothing is free.
Old 11-27-2006, 04:20 PM   #10
RENEGADE76254
Default
Thanks for the explain. However when I installed tires and lift (spring of this year) I noticed a change, and the gas millage was consistent after the change. However within the last little while I have noticed it has started to worsen a little more each tank these last few tanks. I don't know what is causing it to do so, however I will be replacing my plugs ASAP, the timing belt and water pump will wait until Christmas break, also the transmission flush and shocks install will also. I only have 2 more weeks and then 2 exams the following week. So I should be able to hold out a few hundred miles until then.
-SLIM-
Old 11-27-2006, 04:26 PM   #11
Dick Foster
Numba 2 Ho
Default
You may have winter gas blends in your area. They put in more alcohol and you get less mileage. I've noticed this pretty much happens every winter. The weather gets cold and people complain about reduced mileage. It's because the fuel often changes with the seasons.
Still jacking the truck up and putting on larger tires is going to cost you mileage.
Old 11-27-2006, 04:46 PM   #12
RENEGADE76254
Default
I had not heard anything of the sort, good info. thanks
-SLIM-
Old 12-02-2006, 08:13 PM   #13
RENEGADE76254
Default
i picked up some spark plugs this weekend, and did a lil wrenching with a fellow local TTORA member. got his oil changed and a few other things squared away on his and changed my plugs. it runs alot smoother (sp?) and the exhaust (flow 50 single in dual out) sounds a bit deeper and defined. the truck seems to be a lil more throttle responsive than before. i know that the spark plugs didnt give me an extra 15 hp but i never knew how much proper maintance could make such a difference. i can see now my vision was so clouded by aftermarket parts and flashy advertising, when after all the key to owning and maintaing a great truck is proper maintance and care.
future plans are for a radiator flush and fill before it gets real cold, transmission service, installing new shocks (new ome's are in the mail) and mainly just takin some time to clean up the vehicle, checking connections, makin sure stuff is greased properly and all. and of course a t-belt and possible water pump.
thanks for the help guys
-SLIM-
You may not post new threads
You may not post replies
Forum Jump
longest..... CUCUY Off Topic 23 02-15-2009 03:18 PM
2nd Time in 24K having leafs taken apart by dealer cleaned and relubed Archer32 Late Tacoma Tech 15 08-06-2006 12:51 AM
went for the first time, have a few ? KevT Lets Talk About Wheelin! 13 08-01-2006 07:32 PM
Time change Zackattak News/Error Reporting/Suggestions/Help 3 11-02-2005 12:58 AM
Do Mufflers Get Quieter Over Time? tsunami982 Newbie Tech 11 10-19-2005 10:25 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
