Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 02-21-2005, 06:01 PM   #1
nees1212
Default thule rack with surco safari rack (basket)??
I recently purchased a Surco Safari Rack to mount on my Thule roof rack on my shell. The bars of the Thule rack are spread out too far to put any type of weight in the Surco basket. In a couple months I'm going to have the shell painted, and at the same time, I'd like to move the Thule rack. However, if I move them, that means the mounts (which are the style that mount on the side of the shell) will be right above the window on the shell, which I don't think provides much support. Is there a different mount that I can use that will still utilize the Thule bars?
nees1212 is offline   Reply With Quote
Old 02-22-2005, 10:42 AM   #2
nees1212
Default
Bump. TTT.
Old 02-22-2005, 09:24 PM   #3
BajaTaco
BajaTaco's Avatar
Default
I understand what you are saying. I had to consider the same scenario (spread between cross bars) and basically, out of necessity, I had to mount them above the windows. I don't think it is a problem.
http://www.bajataco.com/flipout03.jpg
The other alternative would be to use a shell that has the roof mounted rails, which will give you a lot of adjustability with the spread on the cross bars. (or get a longer, stronger basket).
BAJATACO.COM
My site
BajaTaco is offline   Reply With Quote
Old 02-23-2005, 08:29 AM   #4
nees1212
Default
Thanks. That's exactly what I was looking for. So you didn't sacrifice any strength with your setup?
Old 02-23-2005, 09:14 AM   #5
BajaTaco
BajaTaco's Avatar
Default
I don't think so. I figured if the rack was going to deform the shell where the opening from the window was, it would become apparent when I would try to open the win-doors. If the win-doors themselves were going to be providing shear support for the weight of the rack, I imagine they would be hard to open (weight pressing down on the frame) and once open, they would not shut correctly (weight having deformed or bowed the frame). I haven't had any such problems. That pretty much convinced me that it is not an issue, and the fiberglass structure itself is solid enough to support the weight, even where the depth of the material above the windows is less.
BAJATACO.COM
My site
Old 02-23-2005, 09:41 AM   #6
nees1212
Default
Thanks for the information. When I get mine painted this spring, I'll have him patch the holes, and I'll relocate the mounts to above the windows.
You may not post new threads
You may not post replies
Forum Jump
Sponsored Ad
Privacy Policy
Links monetized by VigLink
