Engine trouble code: P0450 Evap Pressure Sensor - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > PreRunner Tech
Thread Tools Display Modes
Old 12-02-2006, 08:36 PM   #1
ochatesme
Default Engine trouble code: P0450 Evap Pressure Sensor
Well I've got a small issue here and was hoping I could get some insight. Lately, I've been getting a CEL that reads P0450, which is an Evap Pressure Sensor malfunction. Now, it is VERY intermittent, it usually takes one to three weeks before it starts to come back on after I pull the battery cable to reset the code. From searching, I found that it could possibly be a leak in the fuel lines, but if it was a leak wouldnt the CEL come on consistently? I'm assuming that the Evap Pressure Sensor is going bad, thus being the reason for the CEL coming on at intermittent stages. Before I go dish out $157 on a new Pressure sensor, does anyone else know what might cause this trouble code to be thrown out?
2000 TRD Tacoma Prerunner (SOLD 8/24/07)
2005 Double Cab TRD Tacoma Prerunner
ochatesme is offline   Reply With Quote
Old 12-02-2006, 10:06 PM   #2
SAR_Squid79
THAT guy.
SAR_Squid79's Avatar
Send a message via Yahoo to SAR_Squid79
Default
If you're not screwing your gas cap all the way on until it clicks, you can get that CEL code.
~Jamie
2000 Tacoma TRD 4WD PreRunner
Supercharged. Locked. Armored.
Mountain: She can crawl it.
Ass: She can haul it.
"Roads? Where we're going we don't need . . . roads."
~Dr. Emmett L. Brown
My Rig My Trailer 4xInnovations
SAR_Squid79 is offline   Reply With Quote
Old 12-02-2006, 10:08 PM   #3
ochatesme
Default
Read about this one too, I make sure the gas cap clicks several times after I gas up. It still clicks even after the CEL comes on so i'm assuming, hopefully, that it's not the gas cap.
Old 12-03-2006, 01:26 AM   #4
RaideRNatioN
RaideRNatioN's Avatar
Send a message via AIM to RaideRNatioN
Default
check all your vaccum lines off of the manifold?
100% AMERICAN
Keep working. Millions on welfare depend on you!
RaideRNatioN is offline   Reply With Quote
Old 12-09-2006, 12:11 PM   #5
ochatesme
Default
Little update on this, I went ahead and ordered a new evap pressure sensor from www.toyotaworld.com seeing as how the dealer wanted about $190 for it. My CEL came on again two days ago and instead of clearing the code like I usually I decided to ride it out and see if it goes away on its on. Well, it went away last night while I was at blockbuster, anyone know why the CEL would have cleared itself? I'm sure it'll come back on within a week or so.
Old 12-21-2006, 09:09 PM   #6
ochatesme
Default
Final update for this thread. My new Evap Pressure Sensor came in last week and I've gone through about 3 tanks of gas without a CEL light. Hope this solves my issue.
You may not post new threads
You may not post replies
Forum Jump
p1300 check engine code sjvicker Performance/Engine/Exhaust 1 01-15-2006 05:10 PM
Check Engine error code? P0420 EVOM1 Performance/Engine/Exhaust 8 07-11-2005 11:26 AM
Check engine code TJGRCD Early Tacoma Tech 6 12-28-2004 08:43 PM
"fuel trim malfunction (bank 1)" trouble code BradleyD Performance/Engine/Exhaust 12 12-19-2004 09:33 AM
Exhaust Trouble Code P0420 and Cat-Back Conflict? Beave Performance/Engine/Exhaust 5 12-18-2004 03:19 PM
