Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 02-22-2005, 11:43 AM   #1
WareCreek
Default Brake Master Cylinder
Got 130kmi and it appears that my brake master cylinder is going out. When sitting at a red light and holding the brakes the pedal fades and I begin to roll. I can pump it back up and the pedal is hard again for a little bit. Also when coming to a quick or hard stop, the pedal fades. I am going to bleed it tonight just make sure that there is no air causing this, but I am afraid that it is the master cylinder. Opinions or ideas are more than welcome.
Thanks.
Donnie
WareCreek is offline   Reply With Quote
Old 02-22-2005, 12:58 PM   #2
ewood
ewood's Avatar
Default
I would bleed and check all of your lines to make sure there is no damage to the system. And then if it still is soft I guess I would change the master out. I had brake problems for a while and I couldn't really figure it out, so I just finally replaced the cylinder, after 95K, and all has worked well since. Easy job and it's cheep with the core charge. Good luck. Maybe take a look at the calipers as well for any signs of extreme wear around the dust boots.
ewood
'99 V6 4X4 extracab
ewood is offline   Reply With Quote
Old 02-22-2005, 12:59 PM   #3
atwinda
atwinda's Avatar
Default
Thanks.
Donnie
Check to make sure there is no leak in the brake booster line.
atwinda is offline   Reply With Quote
Old 02-22-2005, 02:13 PM   #4
WareCreek
Default
Thanks for the info. Does anyone have a diagram of the brake system that will help to identify all of the parts? I am fairly mechanically inclined, but new to brakes.
Old 02-22-2005, 11:15 PM   #5
Shakerhood
Shakerhood's Avatar
Default
The first car I owned did that at first and then it got to the point where I had no pedal at all and it was the M/C.
Shakerhood is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Sponsored Ad
Privacy Policy
Links monetized by VigLink
