Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 12-18-2006, 02:59 AM   #1
mach1engines1
Send a message via AIM to mach1engines1 Send a message via Yahoo to mach1engines1
Default Drivetrain noise?
Allright I have searched. but not sure if i know what the problem is. On the freeway gong over 70... in 4th or 5th gear and let off the gas. you can here this noise coming from the transmission. if its in neutral it doesnt but if its in gear it does. Its not all that loud but you can hear it pretty well. I am not familar with manual transmissions. is this normal? or should i just take it to the dealer?
mach1engines1 is offline   Reply With Quote
Old 12-19-2006, 01:46 AM   #2
mach1engines1
Default
Anyone? I dont want to go down to the dealer, and not have my truck for a day, for them to tell me. "5 speeds always make that noise" or something.
Old 12-19-2006, 06:11 AM   #3
kenmo
Default
I have experienced the same noise....I have an 06 reg cab 4x4. Happens at the same speeds your describing when I let off the gas...kind of a faint grinding/rattling noise? I had seen a post a while back where another reg cab 4x4 owner had a driveshaft replaced to fix the problem. I only have 2K on the clock...was planning on taking it in and getting it fixed if it's still making noises at 10K.
kenmo is offline   Reply With Quote
Old 12-19-2006, 06:15 AM   #4
kenmo
Default
Here's the post:
http://www.tacomaterritory.com/forum...ad.php?t=43824
Apparently it was only reg cabs with the problem, and the new driveshaft did NOT fix it.
Old 12-19-2006, 06:18 AM   #5
chizetown
Default
Don't know if it makes much difference but I know on my 04 model I had the same issue and the cats forgot to grease one of the three zerk fittings on the CV joint. Once I greased it myslef the problem went away. The middle zerk fitting is the one they forgot to grease which casued the problems.
chizetown is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Looking for Ways to Troubleshoot Whirring Noise partyman66 Early Tacoma Tech 23 04-13-2011 02:29 PM
98 with lots of drivetrain noise alexh Early Tacoma Tech 12 05-17-2006 10:53 PM
03 Taco Danahoe/Camburg Lift Noise nightsurfride Early Tacoma Tech 5 04-04-2006 12:49 PM
Drivetrain noise.. Daniel_prerunner Late Tacoma Tech 1 03-16-2006 07:16 PM
Odd Drivetrain Noise..... Any Ideas? partyman66 Newbie Tech 4 12-19-2005 02:04 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
