Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 | ||
Big tars, little bed.
This has been around a while, Ive used it before, but until today I had never scrolled past the crawl ratio table to the bottom of the page, at the bottom it tells you your rpms at a given speed. This seems to be very accurate and is all calculated for you. No brain power required
![]() http://www.grimmjeeper.com/gears.html This calculator will tell you the following: All final drive ratios. Crawl Speed at Given RPM in Feet Per Minute Road Speed at Given RPM in Miles Per Hour Road RPMs at Given Speed There are options to factor in crawlers, axle gears, and tire size. He might add in a 3 tcase calc for anyone running triples. And each table, except the final drive table, has scroll menus so you can change rpms and mph. And the last thing is there are 2 columns so you can do side by side comparisons of different setups. For anyone unfamiliar with this subject read on. In step 1 you choose your tranny. 2.7 5spd = W59 3.4 5spd = R150F 2.7 and 3.4 autos got either the A340F or the A340E. As Ive stated below all choices will produce a 2.57 t-case low so it shouldnt screw up the numbers too much if you pick the Toyota tranny. One thing though, on step 2, there is only one Tacoma tranny listed A340F. This step determines your t-case ratio even though you are selecting your tranny again. So if you have a 95.5 and up Tacoma, 4runner or FJC choose the A340F tranny. EDIT: A Toyota Tacoma and FJC option has been added. Choose that for your t-case ratio. Xtra Info: This guy is in the process of adding choices: W59 R150F and A340E to step 2. They will all produce the same 2.57 tcase low, but its nice just to get the details right. As for you 6-speed guys I dont think he's gotten that far yet. im sure he'd be gald to add it in but he may need some help from ya'll to get it correct as I believe he's a Jeeper. But give him some slack he's created an outstanding calculator. http://www.grimmjeeper.com/gears.html __________________________________________________ ___________ This may be useful as well. http://www.ttora.com/forum/showpost....0&postcount=22 Quote:
Another. http://www.tacomaterritory.com/foru...15&postcount=11 Quote:
Southeast Takeover 2010 My Truck and Specs BRC since 2006www.sharetrails.org TLCA #15854 www.tlca.org SFWDA since 2005 www.sfwda.org Last edited by GOT COPE?; 06-24-2007 at 11:31 PM. |
#2 |
That is a great site, and I used it in conjunction with a hand held gps to determine my what my new-to-me truck's gear ratio was.
A good amount of info in a single post.
1997 Taco Xtra cab on 33's |
#3 |
Yep that's the best one I've ever seen.
Dale 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#4 |
Just so y'all know, I'm the one who wrote this calculator. While I'm a Jeep guy, I do want the tool to be usefull for everyone. I saw that some people were having a few issues with the Yota material. So I swapped a few things around and added some labels to make the Yota stuff a little clearer. I also added the FJ's 6 speed manual.
Let me know how you like the updates or if you want any changes. I may not get to it for a week but I'll do my best. Oh, and please spread this link around to anyone who can use it. It's free for everyone. Post it in forums, put links on your web page, whatever you like to spread the word. Last edited by zero cool; 01-20-2007 at 02:04 PM. |
#5 | |
Rocket Scientist
![]() Join Date: Dec 2004
I know the W56 has .85here are the '05 Taco tranny specs that you can add. 6sp manual 5sp manual 5sp AT
#6 |
Hey everyone. This is very useful. Thanks to the person who created it. Now I have a question about it though, I have a 96 tacoma V6 and I don't know what undersdrive I have. Can anyone help me out? The gears I don't even know what it has, I know though it is stock system. Read my sign. to see what I have on it so far. I want to know what MPG I'm getting. Thanks!
1996 Tacoma 3.4 V6 4WD, 3" body lift, Rancho Shocks, K&N FIPK, Airaid throttle body spacer, 32X11.50 BFGoodrich tires on American Racing 15", Dual Exhaust System 40 series Flowmaster. |
#7 | |
Rocket Scientist
#8 | |
and like hytenor said, you aint got no underdrive
Southeast Takeover 2010 My Truck and Specs BRC since 2006www.sharetrails.org TLCA #15854 www.tlca.org SFWDA since 2005 www.sfwda.org |
#9 |
*cough* sticky me.
Thank You.
Southeast Takeover 2010 My Truck and Specs BRC since 2006www.sharetrails.org TLCA #15854 www.tlca.org SFWDA since 2005 www.sfwda.org Last edited by GOT COPE?; 02-01-2007 at 08:41 AM. |
#10 | |
Crawl it!
Thanks Roy, you ROCK!
96 Taco Xtra cab 4X4, 2.7, 5 spd, lots of miles with a few mods... Quit Dicking around. I'd rather wheel than wrench! |
#11 |
good to know, thanks
4xinnovations sliders,lockers, Ome 881's, Rear 63" chevys , Arb front bumper, Custom rear bumper, winch, Natebuilt skids and some other stuff |
#12 |
Thanks man, this is such useful information! I really appreciate it.
#13 |
Differentials!
TTORA GOLD Sponsor
Here is another one:
http://justdifferentials.com/index.p...id=2&chapter=0 also stocking all the taco gears!
JT's Parts & Accessories Your 4x4 & Differential gurus Click for Gear Deals 866-349-6801 info@justdifferentials.com www.justdifferentials.com |
#14 |
Good info as I'm contemplating 35's.
Deacon 03 DC Warn winch, AllPro rear bumper DeMello sliders, front bumper, 1 in BL Donahoe's front & Deavers rear, 33's dual battery, Bushwacker flares Tundra front brakes |
#15 | |
hell is other people
ripped from sonoran steel.
FUCK SURFINGDRUNK "There is nothing good or bad but thinking makes it so". Bill Shakes I love to buy my parts from trdparts4u.com!
#16 |
What happened to the calculator link? It's just coming up with a page full of ads now
#17 |
Domain expired... hopefully he figures it out before the domain gets ganked by some unscrupulous... gotta go see about something brb.
+( )X( )=
#18 | |
Rocket Scientist
I use this one |
#19 | |
Oh, and they sent the billing notification to my old email address that I had disconnected during the move so I didn't catch it for almost a week.
#20 | |
#21 |
NorCal Vice Prez
Thanks! This will help determine my speedo error now that I have 4.88's and 35's
![]() I think your crawl speeds are off though??? I punched mine in with the xfer and 4.7 underdrive, and my speed is comming up at 201 at 5000 rpm. Maybe the decimal has to be moved over 2 places?
Hi, my name is Phill, above are things I say W6FTW
#22 | |
#23 |
NorCal Vice Prez
Ah, makes sense.
Thanks!
#24 |
NorCal Vice Prez
Ok, I'm busting my brains out.
I'm running tyhe R150F tranny, and stock was 30.46" tires, with 4.11's... Now I am running 34.46" tires, with 4.88's. Can anyone help me determine the error? I think it's at about 5.6%
#25 |
The way I calcluate it, your driveshaft will be spinning 4.952% faster with your current setup than it did with your stock setup at any given speed. That means your speedo is running 5% higher than it used to at any given speed.
So when your speedo says 65, you're really going about 62. Naturally, you can have up to a 10% variance between speedo reading and actual speed from the factory. This can vary over time. The difference in air pressure between cold and warm tires can have that much impact. For all intents and purposes, you're in the "close enough" category. |
#26 |
NorCal Vice Prez
Well, I went from a 30 tooth, to a 33 tooth. I could theoretically go to a 32 tooth, and be only 1% off.
I wasn't too far off though . Thanks!!!!!!
#27 |
TTORA GOLD Sponsor
Except for that annoying background image, that is a really nice calculator.
Back in 1999 or 2000 I built this one for Marlin's site: http://marlincrawler.com/java/getspd_calc.html That was made a loooooooooong time ago and I've always wanted to improve it. Now that I've got the new Marlin Crawler website running, I have been wanting to bring back this old jew with many, many more options. Thanks for the link, it has given me a lot of great ideas! Mike |
#28 |
![]() Join Date: Jul 2007
Under the "Tire Size Change, find new differential ratio."
I plugged in my numbers... New tire diameter is 33 and old 31. Current gear ratio is 4.10 im guess becasue I still have stock gears... so, whenit calculates the new info, is this telling me what gears to get? Hi=3.97 New=4.36 lo=4.76 actual= 3.85 If im understanding this right, tthen 4.36 is the gears it recomends to get for 33 inch tires. I seemsm, however, that 4.56 is what most people use....How will the 4.56 compare with the 4.36 for power and gas milege? Thanks and sorry for the noobness....
#29 | |
Rocket Scientist
![]() for the taco: aftermarket gears are 4.56, 4.88 and 5.29. OE are 3.58, 3.91, 4.10, 4.30 and 4.56 (some Runners had OE 4.88s but not in the Taco) all of those "charts" do NOT take other factors into account: more aero drag, more weight, wider tires have more rolling resistance, etc. So, you havt to go with a lower ratio (higher #) to begin to compensate. And, with so little hp and torque from these engines you can only compensate just so much
#30 |
TTORA BRONZE Sponsor
This is some really great info posted. It seems everyone pretty much has or is planning on getting bigger tires so it makes a great reference.
http://www.quotewarz.com CLICK HERE>>>Tacoma Insurance Multiple Online Quotes 1-800-610-3464 50 Insurance Companies Nationwide |
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Very cool Gear ratio calculator! | BigMudTruk | Early Tacoma Tech | 16 | 10-24-2006 10:28 AM |
| Gear Ratio | tennessee01tacoma | Newbie Tech | 5 | 05-30-2006 08:10 PM |
| gear ratio | TacomaTRD05 | Early Tacoma Tech | 17 | 02-03-2006 01:14 PM |
| Gear ratio | CajunTacoma | Newbie Tech | 1 | 07-25-2005 05:47 PM |
| tire size and gear ratio calculator | The Shocker | Tires/Wheels | 5 | 02-02-2005 03:21 PM |
