Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
SoCal Vice Pres.
Okay - in preparation for my 4WD Conversion, I took some measurements today. I want you guys to check my math. I have to get my Front Driveshaft Lengthened, and my Rear Driveshaft Shortened, and these measurements have to be right!
If someone with a 98 - 04 Tacoma, with a stock Tranny & T-Case can doublecheck my measurements, that would be a big help too. Here's what I've got: Driveshafts were measured from output flange -to- Center Support Bearing (Center of bolt) Prerunner: Tail-housing -to- Rear Output Flange = 6" Driveshaft = 39 1/2" Stock 4WD: T-Case + Tail-housing = X" Driveshaft = 27 1/2" My 4WD Conversion: Adapter Plate Kit = 8 1/2" T-Case = 12 3/4" TOTAL LENGTH = 21 1/4 Stock 4WD Driveshaft will need to be shortened 3 1/4" My Math: 39.5" + 6" = 45.5" (amount of space from CSB -to- Transmission) 45.5 - 27.5 = 18" ( X = 18" [stock 4WD T-case]) 18" - 21.25 = -3.25 So - Stock 4WD D-Shaft = 27.5 - 3.25 = 24.25" 24.25" + 21.25" = 45.5" = amount of space from CSB -to- Transmission Sound about right? Jim @ Inchworm told me that I would need to Shorten/Lengthen my Driveshafts by about 4". Are my Stock 4WD Measurements off? My measurements are all based off of mathematic calculations - I don't actually have a stock 4WD to look at and/or measure. ![]() ![]() ![]() One more thing: In the pictures above, I noted the placement of the Speed Sensors. I've got that down. But what in the hell is this:
~Jamie 2000 Tacoma TRD 4WD PreRunner Supercharged. Locked. Armored. Mountain: She can crawl it. Ass: She can haul it. "Roads? Where we're going we don't need . . . roads." ~Dr. Emmett L. Brown My Rig My Trailer 4xInnovations Last edited by SAR_Squid79; 03-20-2007 at 06:24 PM. |
#2 |
SAC'D FJC
This is the transfer indicator switch. In other words, it's the 4WD indicator switch. When you shift into 4WD this switch causes the 4WD light in the dash to light up. As for the drivelines I can't help, but I would recommend waiting until you have it all installed before having your drive lines made up.
BTW, nice to see another Lefty owner.
2007 Titanium Silver FJ Cruiser, 4x4, AT, SFA Project 07 FJ Cruiser SAS | Inchworm Gear | Diamond Axle | Demello Offroad Member: TLCA / BRC / CA4WDC Last edited by sbechtold; 03-20-2007 at 06:49 PM. |
#3 |
SoCal Vice Pres.
Oh ok - I don't even think I have that light in my dash... I'll have to ask Harold (Interex). Otherwise, I'll just zip-tie this wire out of the way.
~Jamie 2000 Tacoma TRD 4WD PreRunner Supercharged. Locked. Armored. Mountain: She can crawl it. Ass: She can haul it. "Roads? Where we're going we don't need . . . roads." ~Dr. Emmett L. Brown My Rig My Trailer 4xInnovations |
#4 |
Lefty?
As in left hand front output? (yes, I'm a frickin noob)
1995.5 Tacoma Regular Cab 2.7L I4 w/ 5 spd manual w/4.10s 31x10.50 Courser AT and KYB Shocks Rhino Liner OTR (and then some) 2002 Honda VTX 1800c |
#5 | |
Lil G
George 2003 X-Cab V6 Auto 4x4 Bilstein HD Struts|OME 881s|Small ToyTec Spacer|OME Dakar Leafs|OME Greaseable Shackles|ProComp MX6 Shocks|305/70R16 Maxxis Mudders|Deckplate Mod|Midland CB|PA|4ft FireStick Cool gif Of My Truck My TTORA Gallery Wanted(badly) Gears|Lockers|Black Steelies For Sale 4x4 Mud Flaps(rear w/ metal frame ONLY)|Stock Leafs w/ 70k|Stock Front Coilover w/ 3" Daystar Spacers|3" Lift Shackles(w/ stock bushings and greaseable top bolt)STOUT! |
#6 |
I just got done efiling so sorry no numbers look good right now...
You using your stock rear driveshaft and a front you bought? Main thing is either get it installed like dude said or just measure from where one blts to the next and subtract that from center support to where the front one bolts. I want to say mine before the crawler was 19 3/4 rear output to center support? Or maybe it was 28 1/4? I forget. I wouldn't trust anyone elses numbers too much man- somehow these things are all different. Measure mounting surfaces if you must though- all you can do really. 1/4 - 1/2 inch wont matter too much- that carrier support is slotted and the rear splined
"i'll help when i get home. help by standing around and scratching my butt and drinking your beer, that is how you help someone work on their truck, right?" -Molly |
#7 |
![]() Join Date: Dec 2004
I would wait until its all bolted in or at least mocked up and then measure inside to inside of each flange at the 3 o'clock position to get accurate measurements. It costs too much to do it twice and you'll only save a dayor two anyway, which probably wont make much difference b/c something else will go wrong and you'll have to order a part or something. Like Wes said, somehow they are all a little different.
#8 | |
What you want to do is set one side of the t-case sensor to a ground and wire the other side into the cab. Tap the GREEN wire to this t-case sensor and your 4WD light will come on once your t-case is shifted into 4WD.
Harold '07 Tundra Double Cab Limited 5.7L '99 Tacoma Ext. Cab V6 non-TRD - Converted PreRunner -> 4X4 TRD E-locker, Man. hubs, independently controlled ADD diff, Aussie Front Locker, Warn XD9000i, CBI Bumper, 4xInnovations Sliders, Custom bedbar, 16x8 ProComp 1079's, Donahoe CO's, Chevy 63" Springs, Bilstein 5150 10" Resi Shocks, 3" RB BL, Hayden tranny cooler '94 Toyota Supra Turbo PT76-GTS, Auto->6 speed '87 Toyota Supra Turbo 4X4 Conversion Thread |
#9 |
I would have just bought a 4x4, too much work/mods to go wrong.
#10 |
![]() Join Date: Aug 2006
Ha, coming from a desert rat. Y'all put so much work into those crazy sand-running rigs that this is like making a sandwich in comparison. It's just an adapter and t-case. Even a simple one-stick divorced setup requires more work, and let's not even mention what goes into a two-stick crawler.
-Ryan Get my light saber. It's the one that says "Bad Motherfucker" on it. |
#11 |
Oh hey squid, question:
It looks like you're keeping your stock 2WD tranny, right? How much was that tail adapter from inchworm?
#12 | |
#13 | |
SoCal Vice Pres.
1.) Switching a Transmission is a PITA 2.) My Truck (and transmission wiring harness) is "California Emissions" 3.) I know where my transmission has been, and how well it's been maintained. 4.) Last year I spent a lot of money to have my transmission upgraded to better handle the extra power from the Supercharger.
#14 | |
SoCal Vice Pres.
#15 | |
![]() I may go this route as well. With only 17k on my tranny, it seems like the best route to go for me too. What t-case did you get?
#16 |
hey, were you at these days jamie? if you are not to far let me know when you are getting serious, i'll come out if you need a hand (got to get you ready, moab is getting close!)
otherwise good luck man, looks as though things are getting close! you really have 39 1/2" before your center support bearing? other wise your math sounds right... but if you can, the best way would be to bring the truck in with everything mounted up and let them measure and look at you set up to deturman what you need. other wise measure stock and subtract what you are adding. good luck man!
87 4runner SAS work in progress... 04 Dodge 2500 quad cab H.O. Diesel |
#17 | |
SoCal Vice Pres.
I'm in Lake Bluff, IL - about 5 - 5 1/2 hours from you. The guy that regeared my front diff still has it. As soon as I get that back from him, I'm going to install my spindles, hubs, Diff, CV's, Camburg UCA's, and Donahoes all in one day. Then all I'll have left to do is the T-case, Shifter, x-member, and D-shafts another day. I really want to have this done inside of the next 4 weeks. I need my truck every day, so I have to figure out a way to mock everything up, so I can at least get an accurate measurement of the Rear d-shaft and still be able to drive my truck. If you seriously want to come lend a hand for either phase - give me a call. It would help to have your truck to look at for reference, and you can crash at my place, and we can drink beer!
~Jamie 2000 Tacoma TRD 4WD PreRunner Supercharged. Locked. Armored. Mountain: She can crawl it. Ass: She can haul it. "Roads? Where we're going we don't need . . . roads." ~Dr. Emmett L. Brown My Rig My Trailer 4xInnovations Last edited by SAR_Squid79; 03-21-2007 at 08:32 PM. |
#18 | |
SoCal Vice Pres.
(http://www.inchwormgear.com/store/pr...roducts_id=985) (With the T-case setup for Twin Sticks like it is, the shifter lines up perfectly to come through exactly where the stock shifter would be)
#19 |
hey give me a break, i have been drinking a little... (maybe more?)
anyways, let me know when you are getting closer, i might be up for a road trip! you got to tell me when you are doing it so i can try to make it on my off days (despite what you think, i do work every once and awhile!) just want to make sure you have no excuses and make it out to moab with us! it's coming up fast! let me know man!
#20 |
SoCal Vice Pres.
I got my Driveshafts back from the shop yesterday!
Cost me $320 total, but they did an excellent job - 3-day turn around, and they even replaced the pesky center support bearing on the rear D-shaft. I think I'm gonna go back to them and have them make me a F & R trail spare after my conversion is done. I've got my fingers crossed that my measurements were correct. Now all I'm waiting for is BUDBUILT for my crossmember! ...I'm trying to give him my money, and I can't get him to return my calls!
#21 |
NorCal Vice Prez
My stock t-case measures 12.5 from the front of the t-case to the flange. The driveshaft from the mounting flange to the mounting flange after the support bearing is 31". Note that this is with a manual tranny, pushbutton 4wd transfercase.
Hi, my name is Phill, above are things I say W6FTW
#22 | |
SoCal Vice Pres.
#23 |
hell i called bud buit and got an answer the same day... even shipped the skids i bought that day! got them a few days later... good guy, not sure why you are having problems, but give him a chance, he will take care of you...
#24 |
SoCal Vice Pres.
Since I know a few others are currently preparing for a PreRunner - to - 4WD conversion, I need to update this thread with results...
It ended up that my math in this thread was correct! Apparently that high-school algebra paid off after all... ![]() My rear driveshaft that I used for the conversion was a stock Tacoma 4WD shaft. I had 3 1/4" taken out of it, and it made it exactly right for use with my Inchworm Lefty, and PreRunner adapter kit. So basically if you're using Inchworm parts like I did, whatever driveshaft you're using needs to be 24 1/4" long (measured from the forward flange to the center support bearing). If you're using all OEM parts, and doing the transmission swap and all that, your driveshaft needs to be 27 1/2" long. If you're modifying your PreRunner driveshaft you would need to have 12" taken out of it. If you're modifying a PreRunner driveshaft for use with an Inchworm conversion, you would need to have 15 1/4" taken out of it. Hope this helps someone out.
#25 | |
Matt Young 2002 Tacoma DoubleCab SR5 TRD 4x4 PreRunner Mods:saw 2.0's w/o sway-bar*deaver 3 leaf aal w/ bilstein 5100*4.56 yukon gears front/rear*manual aisin hubs up front*factory trd locker in rear*35x12.5x15 BFG MT's on 15x8 Steelies*flowmaster super 40 single in/dual out dumped at the axle*4xinnovations 80" long sliders*4xinnovations front tube bumper w/ stinger*mossyrocks fab bed-bar*1" roger brown body lift*budbuilt front skid plate my 4x4 conversion!!! myspace |
#26 | |
THANKS FOR THE MEASURMENTS! very helpful. i think im getting back on track with this conversion. (my dad is still skeptical since its "his truck") but i really like the looks of this route with the inchworm adapter and also id be able to persuade my dad with this route much easier. would it be possible for you to post some pictures of the install from inside the cab? from the diagram you posted up it looks like the shifter would almost be bcomming out where the arm rest is... |
#27 |
oh ya one more question. how do i go about installing the adapter? must i remove my transmission to put it in place or can i just crawl under there and get to work?
#28 | |
SoCal Vice Pres.
The 2 hardest parts (because I was doing all the work alone) was hammering the coupler on to the transmission output shaft, and manhandling the Lefty into position, and getting the bolts started (re-emphasize I did that all BY MYSELF!!!).
#29 | |
#30 |
SoCal Vice Pres.
Yeah - shouldn't be as heavy.
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Transfer Case Noise... Does Your Truck Do This? Video Included | partyman66 | Newbie Tech | 8 | 02-27-2007 06:18 PM |
| 4x4 Transfer Case (Tacoma Vs. 4Runner) | BlackBetty | Newbie Tech | 6 | 11-03-2006 01:56 PM |
| Dual Transfer Case Crossmembers!! - $189 | JTSDIFFS | Sponsors Products | 0 | 09-27-2006 10:32 AM |
| Differential/ transfer case lube question | Firescooby | Newbie Tech | 4 | 12-20-2005 10:50 PM |
| 04 Transfer Case | Gammon | Early Tacoma Tech | 1 | 08-22-2005 07:37 AM |
