Sponsored Ad
Go Back   TTORA Forum > Rock Crawling Tech > Solid Axle Swap Tech
Thread Tools Display Modes
Old 12-09-2004, 02:31 PM   #1
DesertTRD
DesertTRD's Avatar
Send a message via AIM to DesertTRD
Lightbulb How to setup aftermarket/non bolt on leaf springs on a tacoma. 101
Any time you must move the suspension forward or backwards to accomadate lift and longer springs you must cycle the suspension, heres a small howto.
take your springs your wanting to put on your truck and take them apart, all you want is the main leaf, now take the rest of them and measure the thickness of just those leafs, now make a spacer of some sort, it can be a block of wood, just as long as its PRETTY dam close to the same thickness as the rest of the leaf pack, make two of these, now you can use these to cycle your suspension.
JUst an FYI anyone going spring under doesnt have to make the block, the reason for the block is the leaf spring location changes the axle height on spring over.
Dont cut the stock front mounts off until AFTER you have the new ones welded up. reason is you can always use those as a reference point as to where the hangers are square to one another, if you cut those off then your point of reference is lost and it becomes really hard to tell whats centered and what isnt. Remember if its 7" forward on one side, its the same on the other, another thing is make a center line from bolt hole in the front hanger at a 90 degree angle straight up, you want to measure off this line, as your new hanger wont be at the same height and this is more accurate.
Always tack everything together, NEVER fully weld it up until after you are 100% sure its all going to work, (i learned this the hard way!)
Now after you get yoru front hangers tacked up bolt the springs up to them, then bolt them to the axle, now take a jack and jack the axle up to full bump, determine where it sits, the axle should be 100% straight up and down with the bump stops, also watch the drive shaft, remember the futher up to the frame the axle gets the more it will extend, now droop it out as far as you can with the jack, mine sat on the ground at 21" realisticly your never going to get over 19" on our trucks using leaf springs so using this thought make sure at this setting that the drive shaft is not bottoming out, what i found to help was unbolt the driveshaft from the axle at this point and see if i can push it any further together, you want probably about 1/4" or so of plunge left over when its fully drooped, this will ensure your drive shaft does not bottom out or come apart while using your truck...
Dont set the truck up so that at ride height the tires are square in the fenders, thats not how leaf springs work, they move back and up, not straight up and down.
Now for rear shackles, I found that setting the truck up so the shackle is at a 95-100 degree angle towards the front of the truck is best at full droop, then after you tacked everything together take and cycle it, at full bump your shackle should be laying almost on the frame, this can be adjusted this is why we TACK everything. But you want that thing to lay back as far as possible and the leaf springs with bump stops should be done. The goal is to not let the leafs go too far negative to where they start to prematurely fatigue.
After this is all done weld it up, plating everyhthing helps with stress loads and keeps the frame in 1 peice.
This is also a good time while the leaf pack is tore down to setup the shocks, reason is you can cycle it and get maximum up and down travel out of your setup.
- for 10,000 years, man has been hitting things with hammers to make them work....dont mess with a working formula
Book of the Piece Chapter 3, Verse 10
meh... it's yer junk... so wgasa. LoL -- TacoDell
DesertTRD is offline   Reply With Quote
Old 12-10-2004, 12:26 PM   #2
Pink Taco
Split it open-Eat it out!
Pink Taco's Avatar
My Rig: Tacoma
Send a message via AIM to Pink Taco Send a message via Yahoo to Pink Taco
Default
This is the reason why most people move their axle forward, it helps the tires clear the firewall.
If I am not mistaken if you have the shackle in the front (i.e. jeeps) the tire will move up and forward.
Nice little write up my friend.
Pink Taco is offline   Reply With Quote
Old 12-10-2004, 12:34 PM   #3
YUNADERIS
YUNADERIS's Avatar
Send a message via AIM to YUNADERIS Send a message via Yahoo to YUNADERIS
Default
with the shackle in the front, and you trying to bump up something...doesnt it cause you to do more bouncing off something instead of climbing?
YUNADERIS is offline   Reply With Quote
Old 12-10-2004, 12:37 PM   #4
DesertTRD
DesertTRD's Avatar
Default
My post was not directed at the front of a truck, but rather the rear.. however it will work with teh front also.
Old 12-14-2004, 11:11 AM   #5
Will Revis
Default
Nice post Corey! Im sure alot of guys trying to put 62's on will benefit from your post.
Will Revis is offline   Reply With Quote
Old 12-15-2004, 09:05 PM   #6
BK005
BK005's Avatar
Default
A realy simple method I use, isto drop a plumb bob off the side of the frame, and center over axle, and mark point on frame. mock up new springs, and reference with plumb. EasyPeasyJapNeasy
Rides N Stuff
More Rides
Make A Friend A Day, So STFU your #2
BK005 is offline   Reply With Quote
Old 12-15-2004, 09:19 PM   #7
SEAN_at_TLT
SEAN_at_TLT's Avatar
Default
Although taking springs out of the pack is the easiest way to cycle the suspension, it will actually act different than with the full pack in there, ideally you would use a winch or come-along to draw the suspension together with a full leaf-pack but that's not really an option for most of us.
Good tips!
For more info and pics on this exact subject read THIS
-Sean
Trails Less Traveled
SEAN_at_TLT is offline   Reply With Quote
Old 12-15-2004, 09:22 PM   #8
Mike
Mike's Avatar
Default
For people swapping in 63" Chevy springs, new hanger goes 7.5" forward on '98 and up trucks. I took a piece of flat bar, drilled two 14mm (9/16") holes 7.5" on center, and bolted it to both the old and the new spring hanger to get the spacing. Tack weld, test fit, and then finish everything up!
Later,
....Mike
Mike is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Sponsored Ad
Privacy Policy
Links monetized by VigLink
