Sponsored Ad
Go Back   TTORA Forum > General Tech > Fabrication/Tools
Thread Tools Display Modes
Old 04-18-2007, 10:32 AM   #1
PappaF2
PappaF2's Avatar
Default Engine Cage Build
After doing my SAS and wheeling for a number of years my battery mount started to crack like a mofo. I being the procrasinator that I am decided to let it go. Well it ended up going to long and the crack traveled all the way up and under my battery. So while contemplating my fix for this solution I thought about building an engine cage and hanging the battery off that. This idea seemed even more reasonable since I was due for my second timing belt anyway. What the fawk was I smoking?
Well slowly but slowly I have traveled down this path making slow progress. Just to many other things going on to get work done more quickly on it. I am finaly to a point where I thought I'd share some pics. Unfortunatly I am too cheap to buy a good bender so my weapon of choice was a harbor freight kink-o-matic and some 1 1/4" sch 40 A53 pipe. I decided to make no large degree bends knowing that the kninker would fawk it all up. All notching is done with a chopsaw by the precise eye ball method. As of now most of the main structure is pretty much done. I still have to:
-make some more mounting tabs
-make bolt in over the engine tubes
-mount battery
-mount grill/lights
-mount/install hood pins
-mount fenders
-fully weld
-reinstall belts/hoses
-any thing else I forget
It's not done so there will be more added. The plan is for it to look just like a nomal taco when done with fenders mounting in stock like locatins and the stock grill and lights in place. Let me know what you think.
I only have a couple shots right now, I'll get more later.
No turning back:
PappaF2 is offline   Reply With Quote
Old 04-18-2007, 10:35 AM   #2
drabnor
Home Grown Tacoma
drabnor's Avatar
My Rig: 2000 Tacoma
Default
looking good todd! you are in for a lot of work!
TBH IE division
Originally Posted by Scuba View Post
Did you read any part of the reply that just took me 10 mins to search for and write?
Originally Posted by miguelitro View Post
I know I hate having to poke my wire into such a tight hole...
mike
drabnor is online now   Reply With Quote
Old 04-18-2007, 02:42 PM   #3
mojavegold
Default
Looks fine. Are you tying it into an interior cage?
05 Gold SB DC 4x4, Hoes, TC arms, TSB leaf pack, Bilstein 5150's, Timbren bumps, limit straps, locker mod, locker skid plate, one piece rear driveshaft, blah, blah, blah
Definition of the day:
Bozone (n.): The substance surrounding stupid people that stops bright
ideas from penetrating. The bozone layer, unfortunately, shows little sign
of breaking down in the near future
mojavegold is offline   Reply With Quote
Old 04-18-2007, 02:57 PM   #4
PappaF2
PappaF2's Avatar
Default
Not as of now, but right after this project is done I'm putting my off road solutions cage. Later down the line I may tie the 2 together but for now I just want to get it done and wheel.
Old 04-18-2007, 04:06 PM   #5
Tweeter
Desert Moderator
Tweeter's Avatar
My Rig: Tacoma Prerunner
Send a message via AIM to Tweeter
Default
Hey can you take pictures on how you mounted the fenders up and how you do the head/corner lights por favor?
Looks sweet best of luck to you!
Tweeter is offline   Reply With Quote
Old 04-18-2007, 04:35 PM   #6
PappaF2
PappaF2's Avatar
Default
As soon as I end up mounting the lights and fenders I'll post pics. The fenders are just going to be tabs of various sizes made to fit. The lights are going to be tricky as the upper adjusting screw mount hits the tube that runs infront/above the radiator.
Old 04-18-2007, 05:00 PM   #7
PappaF2
PappaF2's Avatar
Default
Thanks RJ, ya it is a lot of work. It's all the little things that you don't really think about that the inner fenders/core support do that get ya.
Old 04-18-2007, 07:12 PM   #8
AZNPG
AZNPG's Avatar
Send a message via AIM to AZNPG
Default
looks nice man
orange high smog(714) 289-1088
AZNPG is offline   Reply With Quote
Old 04-18-2007, 09:18 PM   #9
Angry Andy
GILF lover
Angry Andy's Avatar
Send a message via Yahoo to Angry Andy
Default
Holy crap, Todd!!!!
Thats nice. I like it!!!!
This place USED to be fun.
Angry Andy is offline   Reply With Quote
Old 04-19-2007, 03:02 AM   #10
PappaF2
PappaF2's Avatar
Default
Originally Posted by Angry Andy View Post
Holy crap, Todd!!!!
Thanks Andy!
Old 04-20-2007, 01:58 AM   #11
mojavegold
Default
Looks nice. It's gonna be bullet proof when you tie it into the interior cage.
Old 04-22-2007, 11:54 PM   #12
PappaF2
PappaF2's Avatar
Default
Time for updates:
I had to ditch the airbox to fit some tube work for the cage so I got me a cheapo conical filter and adapter for 3" MAF and mounted it up. Looks like it should work although I haven't started the truck with it yet.
I spent most of my time this weekend getting the grill lined up and mounted and started mounting the head lights. I was a long tedious process getting the grill lined up but I think its looking pretty good now. Head lights only have one mount done so far but I think it'll work.
Start of head light mounts:
Random shots:
Starting to look like a truck again:
more to come in a few days.
Old 05-02-2007, 09:23 AM   #13
PappaF2
PappaF2's Avatar
Default
Updates:
I made a bit of progress over the last week.
Got the headlight buckets done, just gotta finish weld them and drill a hole for the tension spring from the light housing. I used some 1" x 1/8" strap to make these. For the time being I plan on adjusting the headlight angle by adding wasers behind either the top of side adjuster mount to get the desired angle. No the most trick but it should work.
Started mouting the AC core thingie
A few months ago I figured since the rig was apart and I needed to replace my Power Steering pump anyway, I made a double size resivoir out of my 2 pumps.
Coming together more now:
More pics to come in the coming weeks.
Old 05-15-2007, 06:14 PM   #14
Deserttaco
www.deserttaco.com
Deserttaco's Avatar
Default
updates?
Deserttaco is offline   Reply With Quote
Old 05-16-2007, 12:47 AM   #15
PappaF2
PappaF2's Avatar
Default
Originally Posted by Deserttaco View Post
updates?
Ask and you shall recive!
So I guess Amber is going to be at Katy's house doing a scrapbook thing on Wed, cool.
UPDATES:
Starting to get closer to done, most of the major stuff is hung, just a few bits of fabrication left.
Got the AC core thingie hung:
Got the Battery box built and mounted:
Old 05-16-2007, 04:13 AM   #16
jh3
Default
This is just fawken sweet man, good to see good, informitive tech on ttora.
-Josh
jh3 is offline   Reply With Quote
Old 05-16-2007, 08:19 AM   #17
Deserttaco
www.deserttaco.com
Deserttaco's Avatar
Default
SWEET!!! looks good man. Keep up the good work, and the updates.
Amber and Katy are hosting some scrapbooking get together. They sure do seem to love doing that stuff.
Old 05-16-2007, 10:04 AM   #18
PappaF2
PappaF2's Avatar
Default
-Josh
Thanks man.
Thanks Steve. Ya I am trying to keep up the progress and as long as that keeps up I'll be doing updates. I'll be working on it again tonight and on Friday to, hopefully I can get some stuff done.
Here's an update in the wrong direction, I was drilling a hole in the fuse box support and got a bunch of wires tangled in the drill. SO of coarse it ripped a bunch of wires out of one of the connectors! So no I get to rewire that sh!t!!! Fawk it's always 1 step forward 2 steps back for me.
Anyhow, yea the girls love scrapbooking, but thats cool with me. As long as they keep doing that it makes it easier to justify working on/buying parts for the truck! Plus Katy has made some sweet pages about 4 wheeling trips!
Old 05-16-2007, 10:46 AM   #19
Brain
Brain's Avatar
Send a message via AIM to Brain
Default
Todd! That battery holder is SICK!!!! Almost makes me want to tube out my front end
-The Brain
Brain is offline   Reply With Quote
Old 05-16-2007, 10:55 AM   #20
PappaF2
PappaF2's Avatar
Default
Thanks Brain! I almost thought I wasn;t going to be able to fit the battery under the hood, which is a big reason I started this project anyway. But by moving some engine components back some (fuse box, etc) I got it to fit.
I wanted to try and incorrporate some bling into this build anyhow, and after a couple different rebuilds of the mounts I am pretty happy with it.
Old 06-04-2007, 10:34 AM   #21
PappaF2
PappaF2's Avatar
Default
Time for an update. Not to much happening, I've been working on the mounts for the hood pins. I thought I had them set on the first try but it turnned out I couldn't get the battery out once I had the supports tacked in. After wasting hours on several failed attempts at making a mount that would allow the battery to clear I finally came up with something that should work.
I also made the mounts for the driver side fender, I'll make the passenger mounts once I get a strait fender. I think most of the major fab is done, just need to weld it all up and make a few tabs and gussets here and there.
Old 06-04-2007, 12:14 PM   #22
AZNPG
AZNPG's Avatar
Default
nice updates man
Old 06-04-2007, 07:46 PM   #23
joel
joel's Avatar
Default
Where did you buy the adapter for the filter to MAF from?
FOR SALE
Built 95.5, std. cab, Manual, 3.4 v6 Tacoma
http://www.tacomaterritory.com/forum...d.php?t=146226
joel is offline   Reply With Quote
Old 06-05-2007, 12:24 AM   #24
PappaF2
PappaF2's Avatar
Default
Originally Posted by AZNPG View Post
nice updates man
Thanks, I just wish I could do enough work to update it more often.
I got the MAF stuff from the Ricer section at Pep Boys.
Old 06-05-2007, 12:38 AM   #25
Super Doody
Super Doody's Avatar
Default
Originally Posted by PappaF2 View Post
Time for updates:
Todd. Nice work. You should think about getting those fabric filter bags that goes over the filter. By itself it will suck in a lot of dirt.
Jim
2003 4x4 V6 TRD
SC with URD kit, Aquamist 2D, 2.2 Gen 2 Super Grip Pulley, Donahoe Coilovers, Camburg UCAs, Deaver Leaf Pack, Goodyear MTR 265/75/16, Alpine 9830, Sirius Sat. Alp1., Corbeau Legacy Seats,
Super Doody is offline   Reply With Quote
Old 06-05-2007, 12:47 AM   #26
PappaF2
PappaF2's Avatar
Default
Thanks, ya I am planning on getting one of those fabric filter covers, espcially since this is the cheapo delux filter from pep boys.
Any leads on who sells the filter covers?
Old 06-05-2007, 12:55 AM   #27
Super Doody
Default
Try this. A little on the expensive side. But a lot of other people make the same thing.
http://store.summitracing.com/egnsea...=KeywordSearch
Jim
2003 4x4 V6 TRD
Old 06-05-2007, 01:15 AM   #28
PappaF2
PappaF2's Avatar
Default
sweet thanks.
Old 06-08-2007, 01:45 PM   #29
gosurfn
gosurfn's Avatar
Default
just use some pantyho's (sp?), that's probably the cheapest way. The front end is coming together nicely. I'm planning on doing the same this summer and tying into the cab cage, any suggestions or words of wisdom? Why did you use that adapter for the air filter? Any reason why you didn't want to move th battery to the bed?
gosurfn is offline   Reply With Quote
Old 06-08-2007, 02:01 PM   #30
PappaF2
PappaF2's Avatar
Default
What is pantyho's?
Thanks, words of wisdom??? Not really, just that it takes alot longer than planned (at least how I plan ) Plan on spending time just staring at it trying to get things like the grill, fenders, hood line, etc all lined up.
I'm using the air filter adapter because my stock air box was impeading the placement of the passengerside down bar from front hoop to shock hoop.
The reason I didn't move the battery to the bed? Cause I'm an idiot.
If I had it to do over again I probably would have moved it to the bed and skipped the whole engine cage project. Originally though I liked the idea of the battery under the hood in stock location. I like it now that I finally got it mounted but it caused way to much time wasted and anger to do it again.
You may not post new threads
You may not post replies
Forum Jump
NEEDED: Reliable fab shop for roll cage build 4WD Toyota Owner Magazine Desert Race Rig Build Ups 44 03-08-2007 08:34 AM
Bed cage and rear bumper build ElBandito Fabrication/Tools 16 02-15-2007 03:12 PM
Engine Cage and Radiator PappaF2 Long-Travel Suspension Tech 17 11-10-2006 02:44 AM
show me your ENGINE CAGE! peekay331 Early Tacoma Tech 5 08-16-2006 05:51 PM
Engine cage/fender mount/core support krash Fabrication/Tools 6 03-26-2006 09:10 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
