Driver Side Door - TTORA Forum
Go Back   TTORA Forum > General Tech > Interior/Electrical/Electronics
Thread Tools Display Modes
Old 12-11-2004, 01:04 AM   #1
Lucky13TRD
Lucky13TRD's Avatar
Send a message via AIM to Lucky13TRD
Default Driver Side Door
Hey guys my Drivers side door is rattling like a snake, is this common with 01-04s? If so what’s the fix?
89 4Runner SAS Alloy axles, bellfields, marlin knuckle guesset, trail-gear SAS, 4.88s F&R, lock right in the back, chevy 63s w/double shackle, 37s MTRs, a sweet cammo piant job (soon to be green), Off Axis sliders, custom F&R bumpers, more to come.....
____________
Spell check is the best invention since sliced bread!!!!
Lucky13TRD is offline   Reply With Quote
Old 12-11-2004, 02:14 AM   #2
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
I would think not. Is anything else rattling or just the door?
If you are still under warranty take it in.
hytenor is offline   Reply With Quote
Old 12-11-2004, 10:06 PM   #3
Weeman
Send a message via AIM to Weeman
Default
Mine also rattles and i have a 98...its bugs the hell out of me but since i dont have warrenty anymore i just crank the music up.
1998 Xcab 4x4 SR5 V6 non-TRD 5spd, 2.5" Kings, downey shackles, bilstein 5100s, 15x8 Bajas, 32x11.50 BFG A/T, 18" magnaflow
Weeman is offline   Reply With Quote
Old 12-11-2004, 11:34 PM   #4
augator
Default
is it when the window is down because i let my little bro borrow my truck and when he returned it (Muddy as heck) the window now rattles in the door when rolled down. I haven't had time to see if it is off track or whatever.
augator is offline   Reply With Quote
Old 12-12-2004, 12:03 AM   #5
flatlandtacoma
flatlandtacoma's Avatar
Default
Make sure this bolt is tight. It holds the window track in place. If it is loose or missing the window track will rattle like crazy.
1999 Tacoma 5VZFE
flatlandtacoma is offline   Reply With Quote
Old 12-12-2004, 12:08 AM   #6
Wgasa84
dreamin' about wheelin'
Default
good call, that is my bet!
CA4WDC, BRC, and Tread Lightly
SAVE JOHNSON VALLEY AND THE HAMMERS!
WWW.FOJV.ORG
Keep the effort alive! Get involved!
Spotters are for pussys!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Wgasa84 is offline   Reply With Quote
Old 12-12-2004, 12:10 AM   #7
tbplus10
tbplus10's Avatar
Default
Theres a bolt on the door jam that comes loose and causes the doors to rattle.
If you open the door you'll see a bolt head below the lock mechanism (I think it holds the power window motor). I loosened them up, put a couple drops of Lock-Tight on, and retourqued them. Have'nt had rattling in a year now.
Tim
tbplus10 is offline   Reply With Quote
Old 12-14-2004, 09:44 AM   #8
Outback
Wile E. Coyote... Genius.
Outback's Avatar
Default
Yep, took my '02 to the dealer for just that rattle. Didn't know about the easy fix. Eah, it was under warranty and free...
Jody.
'01 DCab 4x4 TRD
Full OME w/ 882s, ARB air locker in front, axle relocated 3/4" back ARB Bullbar, Demello sliders, Skid Row t-case skid, All Pro e-locker skid, CBI Rear bumper, 16" black steel Wheeler's & 265/75/16 Revos
KE5CCC Amateur radio
Toyota... Because everything else just sucks.
Outback is offline   Reply With Quote
Old 05-17-2005, 03:04 PM   #9
Hector
Default
Same here, always the cheapest fix. However now I'm getting a ''clunk'' as the window approaches the top of the seal. I've watched and it lines up fine, the noise seems to be inside the door. tried the track bolt already, any thoughts?
Honest patriotic american not trying to hijack luckytrd's thread, but it would have had the same title anyhow.
99 X-cab 2.7 5 spd 4x4 donahoe/deavers, arb w/ m9000 (silently for sale)
95 FZJ-80 slee 4'',triple locked, slidered, skidded, stupidcharged, DD
72 FJ-55 SOA,lincoln locker,8274, 36's,some rust
Hector is offline   Reply With Quote
Old 05-17-2005, 03:20 PM   #10
NisAznMonk
NisAznMonk's Avatar
Send a message via AIM to NisAznMonk
Default
Tim
Is Lock-tite permanent?
NisAznMonk is offline   Reply With Quote
Old 05-18-2005, 10:23 AM   #11
tacomalo
tacomalo's Avatar
Default
Not permanent just damn close....
Blue is medium/heavy duty and will hold for a long time but does not require heating to remove.
Green is about the same strength as blue but has the ability to penetrate the threads after assembly and may require heating to release.
RED is the grand mama of hold, definately heavy duty and in most cases it will hold extremely well and in some instances will require heating to release.
These are the general purposes of loctite, there are other variants but these are the most common....
(I break everything I touch)
tacomalo is offline   Reply With Quote
Old 07-18-2005, 03:41 PM   #12
mandymh
mandymh's Avatar
Send a message via Yahoo to mandymh
Default
I am having this same problem (rattling) on the passenger side. I checked the bolt and it is tight.
It also makes a few noises as the window is going up or down, it is more pronounced down about half way; almost like it is catching on something.
I don't want to take it in, any ideas what else it could be?
My Girly Truck
mandymh is offline   Reply With Quote
Old 07-18-2005, 05:18 PM   #13
atwinda
atwinda's Avatar
Default
Take the door panel off and double check that the window is in it's rails.
atwinda is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
