Home | Events | Emergency Rescue Team |
Sponsored Ad
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Colorado Chapter > Maintenance & Parts
User Name
Thread Tools Display Modes
Old 06-26-2007, 01:23 PM   #1
hanksyota
hanksyota's Avatar
Default squeaky sounds
since the steamboat trip, my car has been making some squeaking noises. it is coming from the drivers side front tire/brake area. it sounds just like a brake pad that is worn, but only happens when i hit a bump, not when i brake. could the little warning scraper mechanism be rubbing the rotor? any ideas would be fantastic. i want to make sure its good to go, im going to MOAB July 12-16, (yes i know, i will die in the heat) and want everything in top condition. TIA.
Henry
search before doing anything, even farting, or people will shove that fart so far up your ass, your burp will smell like shit.
96 Tacoma SX 2.7 5spd, bone stock on 31's.
hanksyota is offline   Reply With Quote
Old 06-26-2007, 03:05 PM   #2
RedRunnertc
RedRunnertc's Avatar
Default
Jack up the truck and try and "wobble" the wheel like you are checking for loose lugnuts with your hands at 12:00 and 6:00 (top and bottom). If it wobbles AT ALL, repack and/or replace the wheel bearings.
I don't imagine how it could have happened, but you might have gotten some water/mud in there
President - CO Chapter
'96 Impala SS - my own personal cop car
RedRunnertc is offline   Reply With Quote
Old 06-26-2007, 03:20 PM   #3
hanksyota
hanksyota's Avatar
Default
thanks troy. i will do it as soon as i get home. mud? no chance, ok maybe a little. is this a bad situation to be in?
Old 06-26-2007, 07:16 PM   #4
RedRunnertc
Default
You need to get it fixed soon, but it's not a "don't drive the truck until" situation. It's not tough to repack them. The Tacoma front end IS only semifloating, so you need to have a little more sense of urgency about it than those of us with the older full floating fronts (I really don't understand why Toyota would change that way)
Here's a writeup - yours might be a little different
http://toyota.off-road.com/toyota/ar....jsp?id=186138
Old 06-26-2007, 08:51 PM   #5
spindleshanks
spindleshanks's Avatar
Default
Dude Henry, the FIRST thing you should do before anything else is buy a $2 can of brake clean and thoroughly spray down the calipers, rotors, and friction material. If it's still squeaking after that, you can do some more diagnosis.
Originally Posted by RedRunnertc View Post
Aren't you a Regional Manager AND a little bitch?
Mr.Clean '03 Taco
As yet unnamed '03 Honda Shadow Sabre 1100
spindleshanks is online now   Reply With Quote
Old 06-26-2007, 09:24 PM   #6
hanksyota
hanksyota's Avatar
Default
thanks guys, i will get the brake cleaner and try that. didnt have a single chance to tonight. i'll be looking at it tomorrow, and let you know. thanks again guys.
You may not post new threads
You may not post replies
Forum Jump
squeaky suspension slimstacoma Suspension 17 05-10-2006 10:16 PM
Squeaky Springs wyotaco Late Tacoma Tech 14 04-12-2006 09:47 PM
seat a bit squeaky? micah Early Tacoma Tech 8 03-07-2006 07:26 PM
squeaky clutch? 2ktacoma Performance/Engine/Exhaust 14 10-21-2005 11:18 AM
squeaky bushings supahonkey Early Tacoma Tech 11 12-11-2004 02:12 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
