#1 |
i went to my mechanic about a squeal i had in my rear end...( i posted it as "Squeak!!!" earlier this week. I talked to him and he believes its my rear end.... most likley my gears. How much total am i looking to replace my 4:10 gears if that is what it is? also, i have been wanting to upgrade to 4:56 for a long time now and i was wondering about how much it would cost to get 2 master install kits and 2 gears (front and rear) also who is the best (price and quality) thanks |
#2 |
Go w/presicion gears for sure imo. I got 4.88's and rear master and front standard install kits and it all totalled 640.00 bucks.
#3 | |
#4 | |
Deal Master
![]() Join Date: Dec 2004
#5 |
Numba 2 Ho
One would suspect a bearing instead of gears if the noise is a squeak or squeal.
I admit to being Crazy but I'm not Stupid |
#6 |
Yeah gears would just grind and it'd be obvious if you had a gear problem if you drained your fluid and there was metal in it. But yeah my 640 quote was for front and rear ring/pinons, rear master install kit and front standard kit.
#7 | |
2004 Tacoma Extended Cab 4x4 TRD | 3.4 Liter V6 | 5-speed manual |
#8 |
Member Dismemberer
Ditto what others said. Probably a bearing and not the gears. If you have 4:10 gears, you can only get new gears from Toyota for about $400 per set. The smallest aftermarket gears start at 4.56.
If the squeal is coming from the rear differential, I'm putting my money on bad front pinion bearing.
Next Socal TTORA event - Miller Jeep Trail - June 22 www.ttora-socal.com TTORA-Socal on Facebook |
#9 |
ok what are the carrier bearings and the front pinion.... drive train isnt my thing
#10 | |
Member Dismemberer
Look on page 2 for the differential exploded diagram.
#11 |
thanks
how much do they run for and where can i get them |
#12 |
Numba 2 Ho
All of the bearings come in a master install kit. But you would do well to find a good rearend shop instead of taking it to the dealer. About all most dealers will do is swap out the entire center section. Dealers just don't do much in the way of wrenching other than to change easy parts and entire assemblies these days. They don't care because it is either your money or Toyotas money, never theirs and if they did do any real wrenching, it would expose them to warranty work where they would most likely loose money. The overall lack of good mechanics along with an increase in the technical complexity of vehicles these days are also contributing factors.
#13 |
![]() Join Date: Mar 2005
as far as install I was quoted about $400 if I bring the 3rd and front diff in, about $700 if they do it all
http://www.flickr.com/photos/terrystaco/ |
#14 |
Numba 2 Ho
The rearend shop I use typically charges about $150 for a gear install if bring in the third and about double if they have to R&R too so that is not too far off.
#15 |
thanks i headin there tomorrow to get it checked out more in depth
#16 | |
Deal Master
Rear Carrier Bearing 90366-51001 if ithe others say its pinion related Pinion Bearing 1 90366-40068 Pinion Bearing 2 90366-34007 |
#17 | |
#18 |
Check the rear U-joint, when I bough my truck, used, the rear u-joint went bad and squeaked. They replaces it and the squeak went away. Just another possability.
#19 |
Well i took it to the mechanic... and strangely enough i broke some type of internal spring in my drive shaft... i found that hard to believe... but thats wat happened...nothin to serious to worry about. He told me to either buy a new drive shaft or just put up with the noise... well u can probably figure out what i did
#20 | ||
![]() My Rig: '00 Tacoma
Inchworm Rock Walkin' Gear |
#21 | ||
#22 | |
Deal Master
#23 | ||
| Thread Tools | |
| Display Modes | |
