Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
Finally had time to write up my rear end install.
This was done the day after we installed my SAW CO's and new Camburg UCA's. Here's that thread if your interested http://www.ttora.com/forum/showthread.php?t=73802 Alcan 8's and Bilstein 5125's upon delivery ![]() ![]() First thing we did was cut the stock exhaust so it wouldn't get in the way of the new springs. I could have used an exhaust hanger bracket but I like not being able to see the exhaust pipe coming out the rear of the truck, just me. I also protected the bare metal of the exhaust pipe w/ JB weld to keep it from rusting. Before ![]() After ![]() Now it was time for the new leafs! We decided to replace the brake line first. This was pretty easy, just remove the e-clip on the high side take the hard brake line loose and then unscrew the stock brake line near the rear axle. This is also a good time to bleed the brakes when you get the new line in. This is the only picture I have before we removed the stock brake line. ![]() New brake line installed ![]() Preparing to remove the stock leafs ![]() Stock LR shock, U-bolts and bump stop removed ![]() The rear shackle bolt was a pain to get out because it was press fit. I beat the crap out of it (w/ nut protecting the threads and lots of WD-40) until it finally came out. Here's is a shot of the LR stock leafs removed. ![]() Leaf Comparison ![]() We had better luck bolting up the ends of the leafs before placing the Alcan leaf pins in the axle. These leafs were side specific also (L and R). We determined left and right from 'L' and 'R' stamp markings on the factory spindles. Left being the driver's side and right being the passenger side. Note the full military wrap towards the front. ![]() We relocated an e-brake cable bracket from the rear axle to the gas tank to allow free movement of the cable between full lock and full droop. We noticed this while cycling the rear suspension with our floor jack. ![]() Wheeler's sent the wrong sized bushings w/ my 5125's so we had to put the stock shocks back on until the bushings came in a week later . The stock shocks were at full extension and barely fit. I had to drive around gingerly (with weight in the back) to keep the shocks from bottoming out.Here's a shot of the new Alcan's and stock shocks. The chrome colored U-bolts from Wheeler's were bugging the hell out of me so I painted them black! Flat black spray paint is your best friend! ![]() Pictures of the 5125's and black U-bolts ![]() Stock ![]() Finished front and rear suspension w/ 265/75/r16 BFG MTs ![]() ![]()
2004 Tacoma Xtra Cab 2.7L 5spd 4x4 ADD geocaching.comSAW LT 2" CO's||Camburg UCA's||Alcan 8 Leafs||5125 Bily's||265/75/R16 BFG MT's||Demello Bolt-On Sliders||MF-1050 Air Compressor||Garmin Rino 110|| Last edited by TacoGunner; 08-06-2007 at 07:47 PM. |
#2 |
nice pics and nice job how does she ride??
2.5 king coilover w/ res TC UCA w/ Uni Balls Rear RaceRunner shocks(they blow) 33's 17'' american racing wheels some nice xenon headlights too |
#3 |
Very responsive and on the rough side when the bed is empty but I personally like the kick of a stiffer/rougher ride. Rides like a dream when the bed is loaded w/ my camping gear. It is much improved over the sluggish stock ride. I'm also happy with the travel I get out of the rear axle now.
My ass end sits a little higher than I would like but I'm hoping after awhile it will settle down. I got about 3in of lift in the rear with the Alcan's and have about 1/2in of rake with the SAW's set at 2.5in.
2004 Tacoma Xtra Cab 2.7L 5spd 4x4 ADD geocaching.comSAW LT 2" CO's||Camburg UCA's||Alcan 8 Leafs||5125 Bily's||265/75/R16 BFG MT's||Demello Bolt-On Sliders||MF-1050 Air Compressor||Garmin Rino 110|| |
#4 |
Nice looking rig. How was the install. Mine was a bitch to get done. But it's in and I'm very happy with it.
'04 Manual 4x4 SR5 TRDSAW 2.0 coilovers, Deaver 3 leaf add-a-pack, and Bilstein 5125's
#5 |
Tacogunner when you ordered you leafs did you order a 2" lift or 3"?What it the height differnce bewteen the front and back? I ordered Saw coilovers and a Alcan 8 leaf 2" full leaf set..When I ordered them from Alcan I told them i will be adding a fiberglass topper so he sai 8 leaf and 2" lift to match the Saw coilovers..Thanks
#6 | |
Not sure what they mean by matching the CO in the front. You could match either 2" or 3" of lift in the rear with the SAWs easy, but it's recommended you not go over 2.5" in the front because of CV angle issues.
#7 |
I ordered my alcans through wheelers with the shocks and all, same deal you've got. The springs WILL relax, soften and settle after a couple thousand miles. I was ass high for about 2 weeks. Than the harshness went away, with my bed unloaded, it rides much better than stock (level too)....
Looking for a new motor
#8 |
I have read that most say if you get 2" coilover on the front,that you want to go with a 1.5" lift in the rear to level it out..When I talked to Tom at Alcan I told him I am going with 2" coilovers on the front and that I will be adding a topper on my truck he said to go with 2" 8 leaf on the rear..I just dont want mine to be rear high a lil is fine but nothing noticable by looking.....Anyways your Truck looks super sharp..If possible post pics sxs with before and after..I hope my stuff comes in soon tired of waiting..
#9 |
nothing special
![]() Join Date: Dec 2004
I don't understand all this level lift stuff. A truck is supposed to have a slight amount of rear lift to compensate for added weight. My truck sits butt high with Donahoes at 2" and Deaver 8 leafs when it is unloeaded but sits and rides just right when there is some junk back there.
If I was in World War they'd call me spitfire. |
#10 |
Very Nice Truck! I Have The Ome Suspension And Dakar Springs. It Looks Like We Got About The Same Overall Lift, Since We Both Have The Same Tire And Wheel Size. I Got My Stuff From Wheelers Too, And In The First Delivery Attempt(a Week Late On Ship Out Date) One Of The Dakar Springs Was Broken. Had To Send It Back, Wait Another Week. Went To Finnaly Do The Install And Realized They Never Sent The Rear Shock Bushings Either. It Really Sucks When You Pay For Stuff And Are Told You Will Have Everything And You Will Have It By This Date, And You Dont. But Wheelers Made Good , And I Would Still Use And Recomend Them. Good Shots Of The Install!!
02 TACOMA 4X4 V-6 TRD EXT CAB / OME SUSPENSION/DAKARS/BUCKSHOTS /SNORKEL - EVERYTHING INSTALLED UNDER THE SHADEY TREE 06 TACOMA 4DR TRD PRERUNNER |
#11 | |
#12 | |
#13 |
Shocks are upside down. Shaft should be on bottom
04 xtra cab 4x4 trd 5 speed all-pro bumpers, co's, uca's and rear 3" springs milemarker winch homemade sliders and skids 265/75/16 BFG AT's |
#14 |
Finally! Someone wants to bitch about the damn shock orientation! According to Bilstein it doesn't matter.
#15 |
The rear install was a peice of cake compared to the front. The only problems were getting the bolts out of the rear shackles when removing the stock springs.
#16 |
Just giving you a hard time. Jealous since i still have stock rear springs with Daystar shackles. At least i have the Bilstein 5100's
#17 | |
EDIT: Oops, I guess your running allpro CO's?
#18 |
Thinking of going with the All-pro 3 in and stock shackles if the stock springs ever give up. Unlike every one else with stock springs mine have held up real good so far and i flex the shit out of them and carry heavy loads once in a while
#19 | |
Not having enough C clamps to hold the leafs together w/o having to jack up, place one of them in, and then vice grip them together like 18 times it seemed like and then my Bilsteins were a pain to get on. The bushings were just a smidge too small and with the tight space to work in, couldn't get enough of a good whack at it with a rubber mallet.But, shit, it is all done and I'm very happy with it. It rides so much better than stock. The price we have to pay to have the good looking rides
#20 | |
'99 3.4L Ext Cab 4WD TRD |
#21 | |
Ride wise, it is much better than stock. It's pretty smooth and handles bumps way better. Everybody kept saying that it would definately be better than stock but it's even better than I thought it would be. Keep us posted on when you get it in.
#22 | |
CO's went in with a little massaging.
#23 | |
On the bilsteins I used a floor jack to get the bottom bushings lined up, and then I released the floor jack at the same time pushing sideways on the shock to "snag" the lower shock mount. Then I pounded it the rest of the way with a deadblow. For others: Use dishsoap to lube up the inside of the shock bushings, it makes it much easier for the bushings to slide onto the upper and lower shock mounts!!
#24 |
![]() This is my deaver 3 leaf the military wrap holds it all togather
2003 Toyota Sequoia SR5 4x4 V8 R.I.P 2003 Toyota Tacoma TRD all D'Hoed up "I wish exacto was emo, so he would cut himself." ƃɐqǝɥɔnop ɐ sı ʎʇıɹnd |
#25 |
Member Dismemberer
True it doesnt matter, but with a shaft down orientation, you are less likely to dent the shock housing. This gets to be more important on a Bilstein single wall shock because dents will impair the operation of the shock.
Upcoming SoCal Events: Azusa Canyon - Sept 11 Corral Canyon - Sept 25 Less fishing...more wheeling! ![]() www.socal4x4geocachers.org Thanks to all the sponsors of the Socal Takeover! |
#26 | ||||
#27 |
Good point...do you know off hand if the 5125's are single walled?
#28 |
since you have that big ol' spare tire under there, the shock looks crowded!
D cab tacoma, hybrid fabtech 6" with custom deaver leafsprings, 1" reloaction plate, bils in the rear, 37 mtr's, 36" TSL, 4.88's, 14" magnaflow dumped, AFE cold air intake, full cbi protection(bolt on), wheeler type b's, tom woods shaft, dual compressors, 5 gal tank with train horn, yellow top, rock lights, skid |
#29 |
Throw it in your bed
#30 | |
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Bilstein 5100/5125s FOR SALE... | ginobetterfly | Parts/Electronics/Wheels & Tires For Sale | 10 | 07-18-2007 12:30 AM |
| bilstein 5125s on backorder | Jeehole | Suspension | 6 | 11-16-2006 10:43 AM |
| Bilstein 5125s for sale for 2-3 inch lift | tacoma_trd1999 | Parts/Electronics/Wheels & Tires For Sale | 2 | 09-20-2006 06:18 AM |
| Just Ordered Alcan Leafs | eNnihilate | Suspension | 7 | 07-26-2006 08:08 PM |
| SAW/Alcan/Bilstein install? | Portman | Newbie Tech | 10 | 05-04-2006 09:18 PM |
