Sponsored Ad
Go Back   TTORA Forum > Classifieds > Wanted
Thread Tools Display Modes
Old 12-12-2004, 12:02 PM   #1
jayotto4
jayotto4's Avatar
Question sway bar diconects
Where to get and about how much $. Worth it?
http://community.webshots.com/user/jays99taco
http://www.cardomain.com/ride/776831
"power corrupts, and absolute power corrupts absolutely"
Lord Acton (1834-1902)
jayotto4 is offline   Reply With Quote
Old 12-13-2004, 12:06 AM   #2
tbplus10
tbplus10's Avatar
Default
Definately worth it, allows better front flex. I doubt there any out for the 05's yet. A company on the board just came out with some for 95 to 00 trucks for around $170.
Pull yours off and find a local fabricator, I wouldnt think they'd be hard to fab.
I built some for my 99 at home in about 2 hours, for about $10.
Tim
tbplus10 is offline   Reply With Quote
Old 12-13-2004, 06:31 AM   #3
jayotto4
jayotto4's Avatar
Default
They are for a 99.but thinking for a 05 also. What did you use for yours?
Old 12-13-2004, 03:19 PM   #4
tbplus10
tbplus10's Avatar
Default
I used the stock lower connectors with a receiver made of 2" X 1.5" .120 wall tube notched and welded on it. A 5" X 3/8" threaded rod and a 3" X 1.25" steel rod tapped with the 3/8 x 20 threads bolts to the sway bar end, their held together in the receiver with a 7/16" pin.
Took 2 hours to make, required welding, cutting, tapping threads, and notching tubing, all work can be done with common hand tools. Cost about $10 including new stainless hardware, I reused the stock rubber bushings.
Tim
Old 12-14-2004, 08:28 PM   #5
cooper4x4
War Eagle
cooper4x4's Avatar
Send a message via MSN to cooper4x4
Default
Contact Joey at joey@bangedupoffroad.com. he used to make some and has a lot of supplies left over that he wants to get rid of. I have some of his and they are great and easy to use. Remove two cotter pins and they are out.
2002 Limited Doublecab 4x4
Toyota Trail Riders
cooper4x4 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Sponsored Ad
Privacy Policy
Links monetized by VigLink
