#1 |
Anybody running it? My brother just bought me a PSC hydro assist pump for my birthday last Friday. It's nice when you have family that understands what a wheeler needs for his rig
I still need to buy heims, bolts, a cooler, hoses, and make some brackets and a larger reservoir. Should be nice to turn in the rocks and on the slickrock again
#2 |
Front shot, ram is hidden away behind the tie rod Closeup the the bracket I fab'ed. The two rings on the outside hold the center pinch clamp. I kinda got crazy with the tack welds and burnt through one of the outer rings (nice bugger weld). I didn't want to weld the bracket for the ram directly to the tie rod like most people suggest. The reason for that is if you ever need to change the length of the tie rod, you have to loosen the jam nuts and spin the tie rod. You would have to adjust your tie rod in full turns and could throw out your alignment. Backside of bracket, I got this piece from Trail Gear. The other bracket from TG welded on the top of the housing. Hayden 401 Tranny cooler, works perfect for hydro assist. Couldn't have tapped that in a better spot! I was worried the fitting wasn't going to clear but it did! Side shot of the ram. |
#3 |
NICE!!! Great work man.
Get er painted and then get some new meats!!!! LOL
Baby Beast- Mini Truck in progress Generation Dead |
#4 | |
(they are probably the worse tires I've seen on a truck )I can afford the black spray paint but not new meats. I actually don't know when I'll be able to afford new tires. My wife and I are expecting a little boy sometime in December. Two kids and a new house doesn't leave much in terms of Toyota $$. I'll survive though
#5 |
My Rig: Your Mom
Nascar called, they want those tires back.
I know all about the kid and house stealing all the truck money, I can't get my truck fixed. Nice work on the ram, I agree that you still need to set toe on a truck that is "driven"
1996 4runner outfitted with a ton of ARB stuff. Got some Warn Items also 1983 Hilux, nuff said |
#6 |
Better pics of my Nascar slicks I used my hydro assist for the first time this weekend at Chinamans http://www.rockfrogs.org/phpBB2/viewtopic.php?t=2062 It worked out well in the rocks with the full time locker. I couldn't even tell it was in 4wheel drive. I did have a mishap with the 1/4" wall DOM tie rod though. Ended up bending it (my jam nuts loosened up, the tie rod rotated, the ram rotated down, and my hydro bracket made contact with driver's side u-bolt plate). I didn't know it was touching and it self clearanced itself |
#7 |
My Rig: 3.4 swapped 85 xcab
How's this working out long term? Hayden cooler keeping up with you? Any chance you remember the specs on your ram (stroke and diameter)?
I've heard of some taking the ram apart to add a spacer to correct the stroke for the toyota knuckles. Did you have to deal with any of that? Anything you would have done different?
de·gen·er·ate I'm outside your window watching you read this. |
#8 | |||
![]() Hydro has been working great since I finally got it setup correctly (I broke the ram, my own fault, I had the ram too close to the driver side U-bolt plate and bumpstop). Hayden cooler has been fine. I'd go bigger if you can. More fluid, lower temps. Ram is a PSC 5.25 stroke 1.5" diameter. You don't want to go to a 2" ram if you run the stock PS pump like I am. I'd 90% sure that's how PSC got this ram to 5.25. Just a .75" spacer inside a 6" ram. Here's the steps my brother did to make his 8.25" throw ram down to a 6" Adding Spacer to Ram My ram had 8.25” of thrown, but I needed less than that for tie rod. I have a good friend who has access to a lath and he turned me a hard plastic spacer. My spacer has a 1.25” outer diameter and a ¾” inner diameter. The following steps are showing the disassembly of a hydraulic ram. Step one – remove snap ring Step two – Remove rod assembly (it just pull right out) Step Three – Remove nut on rod assembly http://rockfrogs.org/Pictures/EE/hyd...m_spacer_3.JPG Step Four – Add spacer (spacer in white) and retighten nut Step Five – Press rod assembly into ram housing and reinstall snap ring I'd step up to a good power steering pump if you can afford it. I've been using the stock 22RE pump. It does fine but whines like a bitch when it gets hot. I usually pop open the hood on the trail during breaks to let it cool off. I also am using the stock reservoir. It's not big enough. You can take some 3.5" exhaust tubing and cut a stock reservoir in half and weld a 4-5" piece of tubing between the two halves for a poor man's larger reservoir. I plan on doing it sometime.
Addicted Off Road Quote:
#9 | ||
Couple of tips I've learned about hydro assist.
Make sure you mount the ram as close to parallel to the tie rod as possible. You don't want the ram at an angle. My first setup (as shown above) was OK. I liked the clamp but for some reason, whenever I would turn the wheels side to side, the ram would rotate the tie rod and work all the jam nuts loose. I even tried to rotate one TRE all the back and the other all the way forward and then tighten the jam nuts. Still had issues. When I redid the front steering after bending up the tie rod and breaking the hydro ram, I got rid of the TRE's and went with heims. I also straight welded the driver side bracket to the tie rod rather than use that clamp. I don't have a problem with the jam nuts backing off anymore. Here's some updated pics of my setup. It makes slight contact at full steer L&R. I have a new bolt with the head half shaved off to replace it. Frontside of diff bracket to show the radius cut to fit the curve of the housing. I just used the TG tie rod bracket I had bought from the first time I installed the assist. I cut it down and just welded it to the tie rod rather than having it on a clamp.
#10 | ||
Here's what my first tie rod looked like after making contact with the driver's side U-bolt plate
![]() TRE's were fine, knuckles were fine, knuckle studs were fine, Here's what it did to my bumpstop and frame ![]() Broken ram
#11 | |
Thanks for the info.
#12 | |
My Rig: 98 BlackTaco
I need a spacer like that! My ram has more travel than my axle u joints do, so i found out anyway.
I was going to send it back to PSC, but this looks pretty simple! Aaron still know the guy with the lathe? Quote:
Jerry '98 Tacoma TRD ......I see a dark sail on the horizon, set under a black cloud that hides the sun.... ......Savage Rabid Beast....... |
#13 | ||
I do but he doesn't work for the company that he machined the spacer. I've got access to a lathe or 2 (actually my grandfather has a small table unit he bought for me but I haven't cleared off space in my garage to put it anywhere) but I don't have the time to get one machined any time soon. Too much going on in Dec, sorry.
#14 |
My Rig: 96 4Runner
Rodger Brown will make any size spacer you want.
#15 |
No worries Aaron. Busy time of year!
Who is Roger Brown? Jeff, where you on 115 Friday, right near 3rd st? i though i passed by you headed to the trail.
#16 | ||
#17 |
My Rig: 96 4Runner
That was me.. I was heading home from my parents cabin.. I was considering running the trail, but I had wheel stud issues and a load of wood in the back..
#18 | |
#19 |
My Rig: 96 4Runner
It was a while ago since I ordered mine from him. It is a special order part. I gave him the dimensions and he had it to me pretty quick.
#20 |
Nice work on the steering Aaron! Looks great, and super beef! Gotta get out next year with you southern dudes, if my truck ever gets done.
#21 |
Perfect. Thanks. Great thread, I'm book marking for when I go HA
| Thread Tools | |
| Display Modes | |
| Hydro Assist Q's | 1moreyota | SAS/SFA Tech | 16 | 11-20-2007 06:36 PM |
| Hydro assist | Mr Stubs | Tech | 8 | 09-17-2007 10:06 PM |
| Best steering pump (or modify stock one?) for hydro assist? | Tacoma747 | Solid Axle Swap Tech | 1 | 04-03-2007 08:35 AM |
| Need for hydro assist | 01blkext | Solid Axle Swap Tech | 6 | 01-19-2007 06:45 AM |
