#1 |
Hi all,
Finally got my ARB guard installed... not really too hard but the instructions were simply awful. One thing was a bit unexpected... For some reason I thought that the bumper mounted signal lights would come with a plug and play adapter to connect to the factory plug/harness (at least mine didn't come with it). For those of you who have done the install, did you come up with a clean or creative way to connect the lights? I don't really want to cut off the factory plug harness. Thanks! Pete
2003 Tacoma Doublecab TRD 4X4- Overland Adventure Vehicle Donahoe front & rear, Deaver 10, ARB Bull Bar, M8000 winch, Viking Trail line, IPF Lights, Demello sliders, Demello Hybrid Rear Bumper, BFG MT 255/85R16, Range Rider Canopy, Yakima Racks + Basket, Yaesu FT-8800R, CDMA booster, Enersys commerical power, Blue Sea Aux Fuse, Safari Snorkel, ARB/Engel Fridge, etc, etc... |
#2 |
I cut the wire on the factory connector about 6 inchs back from the plug so if I ever neded to go back to stock there would be plenty of wire to splice back in. I used wire splices to connect the turn signals then used sealant to keep moisture from getting into the splices.
John Luttrell 2001 shortcab 4x4, Camburg 2.5" CO's, 285-75-16 mudders, powertrax no-slip, TJM Bull Bar, 8K winch and Hella 500's http://i2.photobucket.com/albums/y6/...l/DSCN0814.jpg 1991 Jeep YJ, 4 inch suspension lift on 33" BFG's http://i2.photobucket.com/albums/y6/...l/DSCN0534.jpg |
#3 |
Deal Master
![]() Join Date: Dec 2004
CliffNotes- I found terminals that mate to the end of the terminals of the Stock turn signal harness
Long Version: Instead of cutting the stock connector or using scotchloks to splice the new harness into the stock wires...... I soldered on some female terminals to the the ARB Included wiring. I chose to integrate the use of the included quick connects in case I need to remove the ARB for any reason- (Actually - I hate using those splice/scotch loks to splice wires- and wanted a clean install - In case I hever had to put back the stock bumper) I carefully removed the plastic plug/harness from the end of the stock turn signal wires - Leaving just the two terminals exposed - I dental pick is a great tool to remove Toyota harness from the terminals. I now connected the two male terminals from the truck turn signal wires to my soldered OEM female terminals on the ARB turn signal wires- I then Heat shrunk the connection- ( I happened to have extra toyota wiring & harnesses around since I pulled them from someones old junked door.) I originally tried to find a plug that would plug & play into the stock harness - but since the connector is built into the turn signal housing - I didn't have any luck finding a similar connector Last edited by grillmasterp; 04-10-2005 at 08:58 PM. |
#4 |
Hmm... I'm not really clear. First, are your connectors the same as mine?
Here are some pics (sorry for the poor light). I've actually never seen a bulb/harness combo like this before... Pic 1 - ARB end Pic 2 - Socket on factory plug with bulb and bulb holder removed Pic 3 - Bulb holder - end to factory plug Pic 4 - factory bulb in Pic 5 - where factory bulb goes into Ideally, I would like to find a way to connect from the ARB ends (which I am OK with cutting, etc) to the harness that goes to the switch. Is the factory plug (with bulb holder removed) common enough that i could find one with just two bare wires on the other end? Thanks, Pete
2003 Tacoma Doublecab TRD 4X4- Overland Adventure Vehicle Donahoe front & rear, Deaver 10, ARB Bull Bar, M8000 winch, Viking Trail line, IPF Lights, Demello sliders, Demello Hybrid Rear Bumper, BFG MT 255/85R16, Range Rider Canopy, Yakima Racks + Basket, Yaesu FT-8800R, CDMA booster, Enersys commerical power, Blue Sea Aux Fuse, Safari Snorkel, ARB/Engel Fridge, etc, etc... Last edited by mountainpete; 04-10-2005 at 09:54 PM. |
#5 | |
I can't post pics right now since my CPU is searching for the hard drive. It's fried. Cheers, P |
#6 |
I did what P1michaud did to my ARB. The only change was putting a clear bulb in to replace the amber one. Works great IMHO.
#7 |
That's an idea...
P1michaud, if you can post pics when your PCs is back up it would be much appreciated!
#8 |
"For those of you who have done the install, did you come up with a clean or creative way to connect the lights? I don't really want to cut off the factory plug harness."
That is what I did. Soldered the wires and coated them with Liquid Electrical Tape http://www.aquaticeco.com/index.cfm/...11554/cid/3006 Zero problems since installation. |
#9 | |
![]() Join Date: Feb 2005
Pete, How did you end up installing the turn signals? |
#10 |
I ended up using the ARB lights with the ARB bulbs (I didn't cut the housings), but took a different route with the connectors. I ended up doing exactly what I didn't want to do at first - I cut off the factory connectors. It's just the most reliable and cleanest way to go in my opinion. I found a set of waterproof quick release connectors at a local autoparts shop and soldered and heatshrinked them on.
Haven't had a problem since then and I have been over the signal lights with water on a few occasions. Pete
#11 | |
No I never did get pictures, all you need to do is this: 1-Using Dremel with cut off wheel to cut the TJM turn signal bulb holder off flush with the back of the light. 2-Use a 7/8" hole saw to open up the TJM turn signal to accept the factory bulb holder/socket. I had to use the Dremel again to enlarge the opening and cut four notches to match the factory socket (i.e. look at how the OEM socket is made, it has 4 slots to lock the OEM bulb holder/socket in place). The actual hole size is just under 1" but by using the 1" hole saw I found it a bitt too loose so stick to the 7/8" hole saw then adjust as necessary to obtain a nice tight fit. 3-I left the factory O-rings in place and added some silicone as an extra precaution. I have not had any issues to date. You can remove the turn signal cover from the front of the bumper via the 2 screws that hold the turn signal in place. This allows you to change the bulb if required. Cheers ,P |
#12 |
TTORA GOLD Sponsor
What a bummer that so much work is required to get this thing dealt with. There must be a better way from the factory/manufacturer.
Dave |
#13 | |
Agreed a plug and play solution would be much better, but the manufacturer probably uses the same signal lights for most of their bumpers thus making it hard to have the plug and play solution. Cheers, P |
| Thread Tools | |
| Display Modes | |
