Sponsored Ad
Go Back   TTORA Forum > General Tech > Performance/Engine/Exhaust
Thread Tools Display Modes
Old 11-12-2007, 11:13 PM   #1
trd04taco
trd04taco's Avatar
Default 3.4L hard to start when sitting for 1-3 hrs
I've got an '04 Tacoma with the 5VZ-FE and 50K mi. It always starts right up when cold or hot. The problem is when it has been sitting for 1-3 hours and is luke-warm, often it cranks for about 30 sec before it fires up. It idles rough for about 3 sec and then it's just fine. The battery and starter are good.
I've cleaned the MAF sensor and played with the Idle Air Adjusting unit and put in all new NGK plugs with no results. It's been doing this since about 10K mi, but more frequently now. It definitely seems like it's getting enough fuel.
Is there maybe a check valve that could be letting fuel drain out of the fuel rails once in a while or something? If so, where is it and how could I check it? Any other ideas?
Yes, I searched and read quite a few threads on this topic first and couldn't find any answers.
Thanks in advance!
trd04taco is offline   Reply With Quote
Old 11-14-2007, 06:35 AM   #2
jvergos
jvergos's Avatar
Default
I'm having the same problem. It's going in for inspection this week to the dealer, I'll keep ya posted on what they tell.
JVERGOS
STOCK!!!!
jvergos is offline   Reply With Quote
Old 11-14-2007, 09:36 AM   #3
Philfab
Philfab's Avatar
Default
This might help:
http://ttora.com/forum/showthread.ph...ight=hot+start
http://forum.ih8mud.com/showthread.php?t=102573
'Ol Bumpy
SAS'd '96 3RZ/W59 x-cab
3-link w/EB coils, Scout II box, double-ended hydro assist, 4.88's, some Ballistic Fab bracketry...
NEW! Budbuilt Clocking Adapter install (no bodylift)
My Chevy leaf swap guide
Bed trim write-up
Parking brake mod
*NOTE* I respond faster to emails than forum postings. Check my user profile for my email address. I will answer any dumb tech question you may have, just don't spam me.
Philfab is offline   Reply With Quote
Old 11-14-2007, 09:56 AM   #4
mudferret
mudferret's Avatar
Default
I had this problem with my '03 Tacoma when I first got it; I asked my cousin who was a Toyota engineer at the time about it, and he said it was a fuel rail pressure problem, concurs with the links Philfab posted.
No signs of it on my '98 Runner, and no idea if the Tacoma still does it as it was sold a couple of years ago.
Originally Posted by Some chick from American Dad
It's true what they say about geologists, they're the coolest, sexiest men alive.
Originally Posted by mudferret
Suck my penal system.
[photos]
mudferret is offline   Reply With Quote
Old 11-14-2007, 04:31 PM   #5
trd04taco
trd04taco's Avatar
Default
Thanks for the links. I checked them out and will be checking the fuel pump wires asap, even thought that seems like an unlikely cause to me. Keep the ideas coming. I'll post what I find after I take a look at the wiring.
Old 12-10-2007, 03:24 PM   #6
trd04taco
trd04taco's Avatar
Default
I inspected the wires and they all look fine and the problem is getting worse. Any other ideas?
Old 12-10-2007, 03:43 PM   #7
BlownToy
BlownToy's Avatar
Default
Thanks in advance!
This could be a residual fuel pressure problem;
Fuel pressure seems to drops when the engine is off. You need to hook up a fuel pressure gauge to the rail to confirm pressure drop. Start engine then stop it and watch the gauge for the next 10 minutes. It should not go lower than 20 psi.
possible causes:
check valve inside fuel pump; (replace the pump)
fuel pressure regulator
injectors leaking
if it drops; you need to isolate between the 3 just mentioned.
pinch the fuel return line; if the pressure is kept, the leak has to be one of the three.
to check the fuel pump check valve you need to take fuel pressure before it gets to the fuel rails.
it kinda hard to do without the right tools but you get the picture.
Toyota Auto Tech
Engine -> TRD : Supercharger; Headers; LCEng Aluminum 13lbs Flywheel, ACT Clutch, TRD LSD
Fuel mods: RCeng 370cc and FTC-E
Cat Removed, Magnaflow cat-back
OME front lift
Deaver rear Springs with 5100's
Poly Bushings
BlownToy is offline   Reply With Quote
Old 12-11-2007, 12:29 PM   #8
trd04taco
trd04taco's Avatar
Default
Thanks for the advice, I'll be looking at it as soon as I can.
You may not post new threads
You may not post replies
Forum Jump
Hard to steer after sitting. Enquadrider16 Early Tacoma Tech 0 04-03-2006 01:26 AM
hard starting after sitting for more than 15 hours LAW Tech 12 02-05-2006 10:14 AM
Hard start v6... Tacominator Early Tacoma Tech 5 02-20-2005 08:52 PM
Trucks getting a lil hard to start. colorado125 Early Tacoma Tech 22 01-21-2005 07:30 AM
03-04 Hard to start?? BOOBANELLI21 Early Tacoma Tech 28 12-31-2004 09:30 AM
Sponsored Ad
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
