Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 01-07-2008, 07:51 PM   #1
45LongColt
45LongColt's Avatar
Default Compass and temp. went out...?
Guys, has this ever been a problem on the Tacoma? Buddy of mine has an 06 and his "accessory meter" as it is properly labeled just went out all together one day. Anyone else ever have this problem?
2008 Tacoma DC 4x4 OR TP
and the biggy: Desert Sand Mica!
45LongColt is offline   Reply With Quote
Old 01-07-2008, 08:32 PM   #2
Janster
Janster's Avatar
Default
Whatta ya mean by 'went out'?
You're referring to the overhead console temp/compass?
Have you taken the overhead console down and checked the wiring for proper connnection?
Sounds like you lost power....? Fuse? Bad connection?
All my children....
http://www.lieblweb.com/Jansters07Avatar.jpg
"Jandy"
Janster is offline   Reply With Quote
Old 01-07-2008, 08:42 PM   #3
TACODOC
Rendezvous Conspiracy
TACODOC's Avatar
Default
Bad connection, I had that happen once. Check the wiring and ensure the connection is tight.
Travel, Explore, Live: AMERICAN ADVENTURIST
TACODOC is offline   Reply With Quote
Old 01-07-2008, 08:43 PM   #4
JayDawg
JayDawg's Avatar
Default
Mine sucks! I will get in my truck at 7am and it will read something like 20 degrees. I will then get back into my truck at around 2pm and it will still read 20 degrees when it is in the 50's. It will then take forever to get back to the actual temperature reading.
My current one:
2007 Tacoma 4X4 extended cab TRD off road package. Speedway Blue
5100 Bilstein shocks set to 2.5", Rear leaf TSB, Randy Ellis design lightbar, 4 Piaa 80 racing series off road lights from my 97' Tacoma.
My last one:
1997 Tacoma 4X4 extended cab.
White
Pre runner bumper, 4 PIAA 80 racing series off road lights, American eagle rims, 31" BFG All Terrains and a few other little things. Lost her in 01' because of a bad lease deal.(Will never lease again!)
JayDawg is offline   Reply With Quote
Old 01-07-2008, 08:53 PM   #5
Trail Gator
Trail Gator's Avatar
My Rig: Tacoma Preunner
Default
Are you sure He didn't turn it off accidently?
2005 Access Cab Prerunner TRD Off Road
265/75 BFG A/T, Magnaflow 18", K&N Intake Filter, other stuff.
Trail Gator is offline   Reply With Quote
Old 01-07-2008, 08:58 PM   #6
45LongColt
45LongColt's Avatar
Default
Thanks guys for the responses. Ya know, he may not realize there is an off setting. I sent him the wiring diagram that shows the connections so he has what he needs to trace it down. Just was wondering if there had been any previous problems I didn't catch.
Old 01-08-2008, 03:56 AM   #7
45LongColt
45LongColt's Avatar
Default
It does seem that there is common theme going on here, check out this thread. It has the cause and remedy too. Certain resistors on the temp/compass module overheat and unsolder themselves. A very common electronics type of problem and easily remedied, add more solder!
http://www.toyotanation.com/forum/sh...d.php?t=172978
Old 01-08-2008, 08:24 AM   #8
MTtaco
Lucky Man
MTtaco's Avatar
My Rig: Tacoma Dbl Cab 4x4
Default
Mine went out but it was still under warrenty. Toyota didnt say what the prob was.
KEEP WORKING
MILLIONS ON WELFARE
DEPEND ON YOU!!!
06 DBL CAB OR, SAW 2.0's, Edelbrock extreme travel, Timbrens, TSB & Wheeler's 3 AAL rear,
255/85R16 Cooper ST's, Shrockworks Sliders, Light Racing UCA's, TJM Bull Bar
MTtaco is offline   Reply With Quote
Old 01-08-2008, 10:09 AM   #9
project82
project82's Avatar
Default
Mine went out under warranty as well. Not sure what it was...probably the connections! They come in handy though.
project82 is offline   Reply With Quote
Old 01-11-2008, 08:00 AM   #10
stoked51
stoked51's Avatar
Default
mine went out, but extended warranty wouldn't cover it, because they said it was the display that was inoperable not the sensors?
Toytec 3" lift kit (OME coils/shocks)
American Racing Forged Wheel 17"
285/70/17 Bridgetone AT Revo's
Bilstein Extended Rear shocks
Magnaflow Exhaust
K&N Drop-in Filter
6000k HID Headlight w/ 2800K Fogs
Undercover Tonneau Cover
Performance Products Low-Profile Bug Deflector
AVS Wind Visor
Redline Hood Shocks
Alpine IVA-W205 Head unit
Alpine Blackbird navigation
Alpine Type R components
Rockford Fosgate 10" Sub
Interfire Amplifiers 700/500 watt
stoked51 is offline   Reply With Quote
Old 01-11-2008, 05:04 PM   #11
45LongColt
45LongColt's Avatar
Default
Stoked51, that really sucks! Take that sucker out and see if those resitors need resoldering. I am sure it is Rohs compliant, ie., no real solder but that new stuff that does not work nearly as well. Mixes with regular solder just fine though so find someone that solders and let them fix it for you.
Old 01-11-2008, 05:35 PM   #12
stoked51
stoked51's Avatar
Default
cool thanks, I'm gonna pull that sucker out and solder away..
Magnaflow Exhaust
K&N Drop-in Filter
AVS Wind Visor
Redline Hood Shocks
Old 01-31-2008, 06:38 PM   #13
Walt
Default Oh Yea!!
I took out the board and resoldered the two 510 flat chip resistors. there are two side by side and three side by side, for me it was the two.I took apart and plugged board in by itself and touched until display came back this is how I found out what the problem was. Just so you know I used a 15 watt solder iron so I wouldnt burn up components This was successful and compass is currently working. If you look at back of board you can see a bit of browning where the two resistors are so I guess they do get hot and melt there connections.
Walt is offline   Reply With Quote
Old 01-31-2008, 09:00 PM   #14
redruff
Default
My temp is always off as well. My f150 was dead nuts on...
Is there any way to calibrate them?
But when its -20 and it reads -15...I'll take it!
redruff is offline   Reply With Quote
Old 02-01-2008, 09:05 AM   #15
YJ-Dog
YJ-Dog's Avatar
Default
Does anyone have a wiring diagram for this system? I went to the dealer yesterday and wanted to buy the Toyota repair manual (3 volumes) they wanted $170.00 per volume. That was a lot more than I thought it would be.
What I want to do is disable the dimming function of the unit when the lights are on during the day. I want to install a light sensor (light dependant resistor or a photo resistor), so that at night the system works as it does now, but if it is daylight the unit will not dim so I can read it.
YJ-Dog is offline   Reply With Quote
Old 02-01-2008, 06:29 PM   #16
YJ-Dog
YJ-Dog's Avatar
Default
Thanks for the link 45LongColt.
Old 03-09-2008, 12:42 PM   #17
WesJ
Default
sorry to bring this back up yet again, but my compass and temp stopped working yesterday (figures 2 days after I get it this stuff quits!!) and Im trying to remove it so I can see if I just need to solder it but am not having any luck getting the overhead console itself out. i have taken the screw out of the sunglass's holder area and it is not moving back or down to come out so I can get to the temp/compass unit. anyone know why it may be extremely difficult to get out? am I missing screws somewhere?
Wes
06 DCab Prerunner, TRD Sport, V6, Auto
WesJ is offline   Reply With Quote
Old 03-09-2008, 12:52 PM   #18
Topper
Banned
Default
http://www.ncttora.com/fsm/index.html
Topper is offline   Reply With Quote
Old 03-09-2008, 12:53 PM   #19
WesJ
Default
f'n awesome, thanks a ton, that oughta help out a lot, both now and in the future!!
wes
Old 03-09-2008, 02:21 PM   #20
TACODOC
TACODOC's Avatar
Default
Mine stopped working a few weeks ago... again. I haven't really missed it since it quit working...
Looks like I'll have to solder it up when I get time or when I give a damn
Old 03-09-2008, 02:45 PM   #21
45LongColt
45LongColt's Avatar
Default
WesJ, download that huge one. It'll run off of a thumbdrive in any windows computer. A manual you can always pack around with you. How cool is that? They say you just have to yank the console down after you get the screw out, it's held up there by plastic claws.
Look for the large flat resistors to see if the solder has cracked around the ends of them.
Old 03-09-2008, 02:49 PM   #22
WesJ
Default
Just got done fixing mine, it just takes a real hard pull on the console to get it out.
After I got it out and apart I did what others suggested and pushed the resistor down and sure enough started working right away. So I brought it inside and put some solder down and I hope it holds.
Just a note, if you push the resistor down I recommend doing it with something other than your finger, that sucker got hot QUICK! After I barely touched it and realized how hot it already was I used the handle of a small screwdriver to gently push on it to see if that was the culprit on mine too.
Thanks for all the help guys!!
Wes
Old 04-15-2009, 01:13 PM   #23
neily
My Rig: 2006 Tacoma
Default
i need to buy a new screen for it mine blew out, its fried. anyone know where i can get a new screen?!?!?! or can an electrician fix it???
neily is offline   Reply With Quote
Old 04-15-2009, 02:38 PM   #24
GMAK
GMAK's Avatar
Default
just resolder the 510 chips on the circut board.
'06 tacoma 4x4 v6-trd
donahoe c/o
tc uca
timbrens
allpro 3" w/ fox 2.0s
255/85/16 bfg km2
rear tire-gate - for sale $250
Go 49ers!
GMAK is offline   Reply With Quote
Old 04-15-2009, 03:19 PM   #25
neily
My Rig: 2006 Tacoma
Default
so even if theres a black spot on my screen and LOOKS like its FRIED, if i resolder it should still work?!?!?!
Old 04-15-2009, 03:45 PM   #26
brinner
Brian
brinner's Avatar
Default
look at the sun, wear a watch and tape a thermometer to the outside of your windsheild
my lawyer is telling me that i should let you know that im joking
brinner is offline   Reply With Quote
Old 04-15-2009, 04:14 PM   #27
45LongColt
45LongColt's Avatar
Default
They ALL have that spot near the edge, just resolder those flat gray/black resitors back to the solder pad. You can't see that burnt spot through the colored bezel.
Old 04-15-2009, 05:05 PM   #28
neily
My Rig: 2006 Tacoma
Default
sweet ill do that! thanks dude!
Old 04-15-2009, 06:12 PM   #29
mr.trd
I think I remember where Moab is?
mr.trd's Avatar
Default
That's funny, mine went out on the trip up to Billings. Fixed it now though.... didn't take more than 5 minutes...
Brant Luckow
INACOMA
'06 d-cab TRD Off-Road
Lift Me, Lock Me, Use Me, Abuse Me
mr.trd is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Where to mount the temp sender for the trans temp ah64id Late Tacoma Tech 23 04-07-2007 09:11 PM
EGT temp? MNTaco Performance/Engine/Exhaust 30 02-09-2007 06:02 PM
Compass and outside temp gauge in 04 Taco C4 Cory Interior/Electrical/Electronics 9 12-23-2006 07:26 PM
Tundra OEM Rear View Mirror/Compass/Thermostat tcm glx Parts/Electronics/Wheels & Tires For Sale 1 04-06-2006 03:34 AM
Temp. of a/c output at max thehulk Performance/Engine/Exhaust 13 07-01-2005 04:45 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
