Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 01-31-2008, 06:00 PM   #1
Switch
Switch's Avatar
Default Question about aux reverse light circuit
I'm planning to add aux reverse lights using a relay as others have done. But I'd also like to be able to switch independently, regardless if key is in ignition. Can I do this using one relay and a diode?
Typical installation (black OEM, Red New circuit):
With extra switch and diode(blue)
Is there a smarter way to do this? How do I size diode?
2006 Tacoma
CA4WDC #11593
*****Don't believe everything you think*****
Last edited by Switch; 01-31-2008 at 11:17 PM. Reason: added color coding to circuit
Switch is offline   Reply With Quote
Old 01-31-2008, 09:31 PM   #2
DentedTacoma
DentedTacoma's Avatar
Default
Are you sayign that you want it on when you back up and then also whenever you flip a switch? I just did my backup lights a couple weeks ago and at first I thought I did it wrong but then found my battery was gone. If you check my recent posts you can find the diagram I put up to check. It works fine although there could be some more inline fuses.
RIP - 1998 Tacoma SR5 (to the crusher)
1985 4Runner SR5 with a 22RTE
DentedTacoma is offline   Reply With Quote
Old 01-31-2008, 09:33 PM   #3
LittleRed97
LittleRed97's Avatar
Send a message via AIM to LittleRed97
Default
i think thats a great idea to be able to switch them independently but looks like a lot of wiring. i cannt think of an easier way to have the same capability but im not the best at setting up that stuff just know the basics. good luck im interested to see how it comes out.
1997 Single Cab
5spd, 4x4, I4 2.7L,3:58s, 235/75r15 bfg at's, some stereo
------------------Totaled-------------------
And missed, had some good adventures
Now a 2000 bright red Jeep Cherokee. 2 more cyliders, 1.3 more liters, 2 more seats, 2 more doors, 1 more solid axle, and LSD
LittleRed97 is offline   Reply With Quote
Old 01-31-2008, 10:53 PM   #4
kamaaina1
kamaaina1's Avatar
Default
Everything you need right here! I just did mine a few days ago. Independent system.
Hope this is what you were after.
http://www.kchilites.com/Add-on-Wiri...y-P504C83.aspx
04' SR5 TRD V6 Xcab
kamaaina1 is offline   Reply With Quote
Old 01-31-2008, 11:20 PM   #5
Switch
Switch's Avatar
Default
Yes, aux back up lights on in reverse or when I flip switch. Sorry my question was not clear. I updated drawing to show red and blue for these two parts of circuit.
2006 Tacoma
CA4WDC #11593
Old 02-01-2008, 10:24 AM   #6
pinhead4914
pinhead4914's Avatar
Cool How?
ok the thing is that you will need a two filament bulb and an added hot wire
one filament is to get power from stock lights and the other gets power from your new switch in the cab you can pull a hot off of a battery outlet in fuse box in the cab not acc. outlet since acc outlet is only on when the key is in the ignition and on acc or run
continued on next
'99 3.4l sr5 All Manual taco
OME co's, alcan leafs 2"s lift
flyn high 4:19 and green
pinhead4914 is offline   Reply With Quote
Old 02-01-2008, 10:25 AM   #7
pinhead4914
Default
this way you have two circuits to the same bulb
if you do not use a dual filament bulb in this process the stock lights will come on when you use aux lighting if that is ok with you then use a single filament bulb and they will come on every time you put it in reverse
if you do it this way aka running straight from stock lights the one filament will come on every time you use reverse and the other will only come on when you tell it to "IF THEY ARE LEFT ON IN THE CAB AND ARE RUN FROM BAT THIS WILL KILL YOUR BATT."
IF YOU DO NOT WANT THEM TO COME ON UNLESS YOU TELL THEM TO
then you must start at the cab with both lines one from stock wire just after stock reverse switch to your switch and the other from batt line to another switch other wise the stock reverse lights will come on every time you use your custom lights
hope this helps
Old 02-01-2008, 10:37 AM   #8
elliot_irwin
elliot_irwin's Avatar
Default
wont the diode stop the factory lights from coming on when running the lights with the switch?
95 taco 2.7 ex.
CUCK FANCER
elliot_irwin is offline   Reply With Quote
Old 02-01-2008, 11:16 AM   #9
Merkaba55
Default
READ THIS LINK!
http://www.ttora.com/forum/showthread.php?t=21166
these pics are from a 97 tacoma, my connecter location was the same as wroosters article, but where the wire sat in the connector was different. same color- red/w black tracer.
I dont know if its similar for an 06
tapping into this wire found under the drivers seat will show voltage when in reverse and no voltage when its not. hook this up to a 3 way switch on one side (auto) and send the other end to your relay, then for the other side (on) just find a 12 volt acc or constant wire. when the switch is flipped in the on position it will trigger the relay, when in the auto position it will trigger the relay only when in reverse...middle position is off. I didnt use a diode...unless it was built into the relay?
1997 Tacoma 2.7 4x4
Merkaba55 is offline   Reply With Quote
Old 02-01-2008, 12:13 PM   #10
Switch
Switch's Avatar
Default
Yes, the purpose of the diode is to prevent power from the manual switch from getting to the OEM reverse lights. I don't think powering lights though a switch is a good idea. Plus I'm only tapping into the wire on one side. I've got two 55w Aux reverse lights now, so I don't care about being able to manually switch the OEM reverse lights.
2006 Tacoma
CA4WDC #11593
Old 02-01-2008, 12:20 PM   #11
Switch
Switch's Avatar
Default
[quote=Merkaba55;1134885]READ THIS LINK!
Yea, I read that plus several others on this forum, yotatech, and toyota nation.
I was just going to tap the power wire to the reverse light and locate the relay in the tail light assembly. Is there an advantage to tapping into the wire under the seat instead?
2006 Tacoma
CA4WDC #11593
Old 02-01-2008, 01:19 PM   #12
Merkaba55
Default
[quote=arott;1134964]
Originally Posted by Merkaba55 View Post
READ THIS LINK!
No, other than convienence...I tapped from there cause its somewhat close to the dash switch. My relays are in the cubby hole behind the drivers seat.
1997 Tacoma 2.7 4x4
Old 02-01-2008, 04:57 PM   #13
pinhead4914
Default constant hot???
do you want a constant hot where are you getting power ???
if the truck is off none of those wires back there are hot.
full functionality is the key right.
do you want to have your running lights on to use your aux lights?
if not you need to run a hot line, if you dont mind then hook off of your running for hot acc line.
if you put your switch on the ground what is the fault?
if it is on the hot side you will burn your switch
Old 02-01-2008, 07:09 PM   #14
Switch
Switch's Avatar
Default
Two goals:
1) I want to have OEM reverse lights plus aux reverse lights come on when I put in reverse when the engine is running. Basically the way the OEM reverse lights work now.
2) A switch that lights up the Aux reverse lights when key is not in ignition.
2006 Tacoma
CA4WDC #11593
Old 02-01-2008, 07:33 PM   #15
Merkaba55
Default
Originally Posted by arott View Post
Two goals:
its in that link you "read" from wrooster.
1997 Tacoma 2.7 4x4
Old 02-01-2008, 08:23 PM   #16
Switch
Switch's Avatar
Default
OK you got me. I obviously did not read post #64
That will work obviously. Thanks for your patience.
2006 Tacoma
CA4WDC #11593
Old 02-01-2008, 09:51 PM   #17
Merkaba55
Default
no problem!
enjoy your new backup lights.
1997 Tacoma 2.7 4x4
Old 02-02-2008, 10:00 PM   #18
LittleRed97
Default
im interested in doing something like this in the future. i understand all of the wring but, where do you find a switch like this?
1997 Single Cab
Old 02-02-2008, 11:47 PM   #19
Switch
Switch's Avatar
Default
I've been using Cole Hersee Contra Switches from West Marine for my aux switch panel.
In general, I trust marine supliers over autoparts stores because the coast guard charges more for a tow than AAA.
That said, I was hoping to use OEM Fog Light Switches for this particular circuit, because I was going to locate the switch in one of the blank OEM switch locations. From what I've read, to use OEM Fog light switches you would need:
Toyota Tacoma Fog Light Switch (84160-04010)
Toyota Connector Housing (90980-11090)
Termainal Wires for Connector (82998-12340 4)
(search these part numbers on yotatech or toyotanation to get more info)
At present, I've decided to test the diode circuit, which would allow me to use the OEM Fog Light Switch (84160-04010, AKA SPST) for aux reverse instead of an aftermarket SPDT switch. All of the aux switch panel locations in my rig are spoken for...
[EDIT 02/18/08: Installed using OEM fog light switch and two diodes, works great].
2006 Tacoma
CA4WDC #11593
You may not post new threads
You may not post replies
Forum Jump
light bar light switch question The Boy Interior/Electrical/Electronics 9 12-11-2007 02:01 PM
Add A Circuit djslik Newbie Tech 3 11-23-2007 04:48 PM
I must be an idiot... reverse light bulbs? LostSol Newbie Tech 17 12-23-2006 10:49 AM
reverse light wiring swank501 Interior/Electrical/Electronics 1 06-22-2006 06:13 PM
Wiring Reverse Lights, Hitch Connection or Reverse Switch? Beave Interior/Electrical/Electronics 15 04-01-2006 10:37 PM
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
