3.75 BS on 32X11.5" rims? - TTORA Forum
Go Back   TTORA Forum > General Tech > Tires/Wheels
Thread Tools Display Modes
Old 04-27-2005, 10:56 PM   #1
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
My Rig: SAS'd 01 Tacoma
Send a message via AIM to NorcalPR
Question 3.75 BS on 32X11.5" rims?
Hey guys. Sorry if this has been covered and I did a search, but couldn't find exactly what I needed.
I'm lifting my 99 Taco Prerunner this month. 3" lift in the front and rear should do the job.
At my friends house today, I took the rims off of his Blazer and stood them against my truck after putting a jack under the front and lifting it 3". He has the Pro-Comp Xtreme Alloys, 15X8" rim with 32X11.5 Dunlop MT on it and it looked awesome.
I decided to get those rims over the centerlines with 32" instead of 33" tires. They filled up the well pretty good and I think 33's would be overboard on a 3" lift.
Anyways, the Xtreme Alloys only come in a 3.75 BS for a 15X8" rim. What I am looking for is the tire to stick out from the fender a bit. Will a 3.75" BS do the job? What would be even better is if someone could shoot me a picture of thier truck with the size tires I want, and any rim with the same backspacing.
My main question is, is will 3.75" BS make the tire stick out from the truck a bit? This is what I want and if it does, I'd rather go with these rims since they are cheap and look awesome.
BTW, I should clear these rims as the stock rims on my Prerunn Taco are 15" rim, so I shouldn't hit the caliper.
Thanks guys.
-Phill
Hi, my name is Phill, above are things I say
W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today!
NorcalPR is offline   Reply With Quote
Old 04-27-2005, 11:01 PM   #2
Zackattak
norcal n00b
Zackattak's Avatar
Send a message via AIM to Zackattak
Default
The less backspacing, the farther the tire sticks out. That should be a good combo. Also, make sure they do clear the calipers cause it sucks if they dont!!
-Zack
CA4WDMember#9373
Zackattak is offline   Reply With Quote
Old 04-27-2005, 11:12 PM   #3
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
Awesome. Looks like I'll be going with those rims.
Even though my rims are 15" and its a pre 01, the calipers can still rub?
W6FTW
Old 04-27-2005, 11:37 PM   #4
Zackattak
norcal n00b
Zackattak's Avatar
Default
No I think your fine.....just wasn't sure if you started with 16's or 15's, but you were with 15's so your set.
-Zack
CA4WDMember#9373
Old 04-28-2005, 06:54 AM   #5
YoTRacer158
YoTRacer158's Avatar
Send a message via AIM to YoTRacer158 Send a message via Yahoo to YoTRacer158
Default
you should be fine with 15's on your truck...mine has 32x11.5 muds on 15's w/ 3.75" backspacing...there are some pics in the link in my signature if you want to see how it looks
2004 V6 5spd 4x4: TRD Charger, URD Fuel Mods/AFR/Unlimiter/2.1" Pulley/Crank Pulley/Short Throw, Supra MAF, TrueFlow Filter, JBA Ti Ceramic Headers, SpinTech Exhaust, SPEC Stage 3+ Clutch, BentUp Front Bumper, Chaos LT/Kings, 62" Deavers/18" Kings/, Glassworks Supercharger Hood/Fenders/Bedsides, 15x8 Black Steelies, 33x12.5 Claws, 4.56's, RR Solid Motor Mounts
youtube.com/YoTRacer158
YoTRacer158 is offline   Reply With Quote
Old 04-28-2005, 08:09 AM   #6
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
Default
Thanks yota. Do the tires stick out about half a lug? It looks like it does. You even have the TRD fenders and I have the little chrome strip so Mine may stick out a lug. Definately looks like I'll be going with the Pro Comp Xtremes!
Thanks Zack and Yota. You guys made my decision a lot easier to make, and believe me, it's been a hard one. Floppin back and forth, 33, hmmm, 32, 33, wait, these rims, those rims, ahhhhh, too many to choose from!
W6FTW
Old 05-03-2005, 01:27 AM   #7
YoTRacer158
Default
they stick out just a tad past the flares
You may not post new threads
You may not post replies
Forum Jump
