Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 04-28-2005, 08:59 AM   #1
WILLYCAD
Banned
Default Blinking Rear Diff Lock light....
I recently went through some water (deeper than normal), but not really deep, maybe 12-18". Now my Rear Diff Light will not stay lit, just blinks. I am not sure if the rear diff is locking or not - I assume not. Any ideas?
WILLYCAD is offline   Reply With Quote
Old 04-28-2005, 09:07 AM   #2
WILD YOTE
WILD YOTE's Avatar
Default
Try cleaning the connectors and everything readily accessible. If that doesnt work you might have to take the locker out and clean the inside of it.
WILD YOTE is offline   Reply With Quote
Old 04-28-2005, 09:13 AM   #3
WILLYCAD
Banned
Default
Now when you say "Take the locker out and clean the inside of it" - pardon my lack of technical knowledge about this but, what am I "taking out" exactly?
Old 04-28-2005, 09:49 AM   #4
atwinda
atwinda's Avatar
Default
There is a total of 3 or 4 bolts holding the locker motor onto the 3rd member. disconnect the wires going to the motor, remove the bolts and remove the locker motor. There is a threaded screw which will most likely be gunked up. clean what you can off it, and reassemble.
atwinda is offline   Reply With Quote
Old 04-28-2005, 09:51 AM   #5
WILD YOTE
WILD YOTE's Avatar
Default
Old 04-28-2005, 11:44 AM   #6
tanKoma
The Satanic Panic
tanKoma's Avatar
Send a message via AIM to tanKoma
Default
honestly i think toyota took these actuator motors off RC cars
i have too many damn car projects
99 x cab SOLD
02 trans am ws6
1953 bel air rat rod
1950 chevy 3800
tanKoma is offline   Reply With Quote
Old 04-28-2005, 11:49 AM   #7
Dick Foster
Numba 2 Ho
Dick Foster's Avatar
Default
You do realize that there is a certian procedure that has to be followed to reinstall the actuator don't you? If not done correctly, it will almost never work unless removed and re installed properly.
I admit to being Crazy but I'm not Stupid
Dick Foster is offline   Reply With Quote
Old 04-28-2005, 11:50 AM   #8
WILLYCAD
Banned
Default
OK, so what is the procedure?
Old 04-28-2005, 11:55 AM   #9
Dick Foster
Numba 2 Ho
Default
I don't think either of you guys have ever taken one totally apart or know how it really works. The way it's designed. the motor doesn't have to be very large because it's geared down twice. The motor has a worm gear that drives a much larger spur gear which in turn turns a tiny little pinion gear that then drives the rack gear which is attached to the shift fork. All it has to do is slide a splined cylinder about an inch or so.
You may not post new threads
You may not post replies
Forum Jump
Sponsored Ad
Privacy Policy
Links monetized by VigLink
