Go Back   TTORA Forum > Local Forums by State > State Forums > Indiana > Events
Thread Tools Display Modes
Old 02-24-2008, 09:40 PM   #1
Bear
H-O-L-Y-------S-H-I-T-H-H-A-A
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Default Wrench A Thon March 29th
As decided at the meeting, we are going to have a wrench a thon on March 29th 08.
It is going to be at Jeep Crasher's "gravel pit" He'll chime in (hopefully) closer to the event date with directions or how to get them from him.
If you have work to do on your rig. this will be the time to get some help in doing it. Welders and other major tools will be available.
Post on this thread what work you may need or want to do.
BEAR
OVERKILL IS AN UNDERRATED ACHIEVEMENT
Originally Posted by abbott
… remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
GO SPURS GO!!!!
Bear is offline   Reply With Quote
Old 02-25-2008, 06:14 AM   #2
brinner
Brian
brinner's Avatar
Default
balance beads in ma LTB's, CB install, diff fluid change and maybe by that time motor oil change(and if i dont get it out sooner.....elocker removal or install)
brinner is offline   Reply With Quote
Old 02-25-2008, 07:32 AM   #3
Bear
Bear's Avatar
Default
I didn't even get into my list of things to do at the meeting.
Install new muffler
change gear oil in rear diff
swap on new seats (yea baby!)
install remote starter
install subwoofer (if not already done by then will also need to install head unit and amp as well as new CB
change fluids
possibly install air tank with automatic valving
Rear bumper fabbed up.
I don't expect to get it all done, but that is a list of things I am considering. I'll will be more available to help others as to do other work to my truck.
(muffler and/or seats will be my priority)
BEAR
GO SPURS GO!!!!
Old 02-25-2008, 07:26 PM   #4
jeep crasher
Moderator
jeep crasher's Avatar
My Rig: FJC and tube buggy
Default
I have i think all major power tools in the garage. air compressor, drill press, air tools, calipers and mics and indicators, wrenches sockets and etc. Any questions on a specialty tool just ask an i'll let you know. do have two 110welders and a torch setup. I only ask for a pitch in on the wire.i also have grinders and sawzalls.sorry no press but my local napa does and have let me use thiers for free.
pm for address
later
dave
jeep crasher is offline   Reply With Quote
Old 02-29-2008, 02:08 PM   #5
Bear
Bear's Avatar
Default
bumping to the top so we can get some better ideas on how many's and whats'
BEAR
GO SPURS GO!!!!
Old 03-03-2008, 09:18 AM   #6
Bear
Bear's Avatar
Default
Dave, I know you are well supplied, but I think I will be bringing my grinders as well as possibly anything else I can think of. Sawzall etc. extra jacks, jack stands (?)
do you think If I bring the H.F "kinker" with me, we could fab up that rear bumper design of yours for the taco? If so, can you get me a cut list or at least an estimate of tubing we are going to need?
Oh and that damn Bathroom stall divider is heavier than Chit! I thought it was going to knock over the greenie when I leaned the dividers against it! LOL
BEAR
GO SPURS GO!!!!
Old 03-03-2008, 09:49 AM   #7
brinner
Brian
brinner's Avatar
Default
ill bring everything i have
Old 03-14-2008, 08:31 PM   #8
DN1911
Default
is a Trans swap to big of a job to tackle? i can do most of it just need a hand or two getting in and out.
DN1911 is offline   Reply With Quote
Old 03-14-2008, 10:02 PM   #9
Bear
Bear's Avatar
Default
I have swapped out a clutch during a WAT in the past, I would say it just depends on what Dave says and what all everyone has to do. but since I am not hosting this particular one, it is best to let Dave decide.
I know I would be willing to help if I am able to.
I know I am needing to remove my front gears and change out some things with the locker.
I know we went through an "inventory" of what everyone needs to work on, but it might be a good idea to restate everyone's intending to work on.
BEAR
GO SPURS GO!!!!
Old 03-15-2008, 11:11 AM   #10
brinner
Brian
brinner's Avatar
Default
so far:
balance beads in tires
paint remainder of sliders
diff fluid change
sound insulate cab (basically stuff sound deadening foam into "hollow" spots)
work on dents with dent puller
re-spool winch
help with anybody elses stuff.
Old 03-16-2008, 11:21 PM   #11
Bear
Bear's Avatar
Default
So you purchased the dynobeads? I didn't know that, you should have talked to me before ordering. I run them and have discovered some hidden tricks that might come in handy for you.
Did you also order the special valves? if not I definitely recommend them, I also have some extras in case you failed to order them I could lend them to you if need be.
Speaking of the beads, I need to finish putting them in two of my tires. When I bought my last tires I only put them into two of the four.
Which sound material did you purchase? I went yesterday to pick up some and left it in the store...They wanted too damn much for it!
BEAR
GO SPURS GO!!!!
Old 03-16-2008, 11:23 PM   #12
Bear
Bear's Avatar
Default
Dustin, I spoke to Dave tonight over some other stuff, and I mentioned your tranny swap for the WAT.
If you just need some "hired hands" to lift the tranny (as Dave put it) That shouldn't be a problem, but regarding using brain power, you might be S.O.L
But if you want to do a transplant and just need the extra hands, bring it on!
BEAR
GO SPURS GO!!!!
Old 03-16-2008, 11:32 PM   #13
Bear
Bear's Avatar
Default W.A.T update.
Okay, here is the latest on our first wrench-a-thon, being held by Jeep Crasher (A.K.A Dave or vise versa)
We are still scheduled for the same date. But Dave mentioned burning some burgers I mean grilling them. He is going to provide the cow, you provide your drinks and possibly a side dish or bag of chips type of thing.
as for the work we are going to attempt that day.
BEAR
to be replacing my seal housing on my front ARB as well as checking the specs on my front gears.
With luck will also be installing new seats (if they arrive in time)
installing tranfer case skidplate, if I get the trans brake installed prior. Otherwise, I might be installing transbrake instead.
Finishing trap door in bed.
JEEP CRASHER
Major project will be building roll cage for rig. Probably will have other smaller projects.
brinner
diff fluid change
re-spool winch
DN1911
by the sound of his earlier post has a transmission to replace
Who else and what else???
Remember you don't need to actually have work to do to participate, come hang out and lend a hand or just laugh at the wrenching going on.
BEAR
GO SPURS GO!!!!
Old 03-17-2008, 04:48 AM   #14
jason6746
inttora
jason6746's Avatar
Default
i think i will be down and lend some help to whoever needs it.
i may need to drill the heads of some my skid plate bolts but thats about all.
2001 tacoma 2.7 5sp.
with some
amsoil dealer
jason6746 is offline   Reply With Quote
Old 03-17-2008, 09:55 AM   #15
brinner
Brian
brinner's Avatar
Default
....no no, i went cheap and did 8 oz. of steel shot for each tire. (you see, when you dont actually drive on the tires all that much you can afford to use these cheap tricks.)
Old 03-17-2008, 10:24 AM   #16
Bear
Bear's Avatar
Default
you mean like using water/antifreeze in tires instead of steel shot?
I know cheap…boy do I know cheap!
I would still suggest getting the filtered valve stems though. as you are airing down, the steel beads can be sucked up into the valve, and if the stem is in place the steel shot can actually clog the valve seed and effectively stop air from passing.
BEAR
GO SPURS GO!!!!
Old 03-17-2008, 11:38 AM   #17
DN1911
Default
unfortunately i won't be able to make, new schedule posted and the boss can't let me off. even though this new position is supposed to be Mon-Fri. so i guess i'm out of luck, if you guys need anything (i.e. Parts) let me know and maybe Brian can bring them down with him. i can also supply Fluids and filters and whatever else you need.
Old 03-17-2008, 11:45 AM   #18
Bear
Bear's Avatar
Default
Well that bites! sorry you won't make it. and I actually finally got those decals in and was going to take them for you!
If you can though, look up an install kit for a Front Dana 44 out of an 86 Grand waganeer for me. I might need one for my front axle work.
BEAR
GO SPURS GO!!!!
Old 03-18-2008, 09:26 AM   #19
94wagsyota
Default
Well i am new to the off-road scene and i just got my first toyota... it's not perfect but it does the job and i would like to bring it to see if you guys (which im sure you do) have any pointers or see anything that i need to change or make...thanks and let me know...
93 Toyota Pickup 22RE
3 inch body lift
15x8 m/t wheels
33X12.5 mud terrains
94wagsyota is offline   Reply With Quote
Old 03-18-2008, 09:48 AM   #20
Bear
Bear's Avatar
Default
I posted up to you on the main (national) board.
You are welcome to come and join the fun. Just expect to get dirty as well as have your learning cap on.
If you have never fabbed anything before, Jeep crasher is a talented teacher if you stay on his good side . and the others have a wealth of mechanical knowledge as well.
make sure and read threw this thread (as I am sure you already have) Let me know here if you have any specific work that needs to be done. i.e your deck plate mod would be good to do at this time or if you just want to join us to hang out with.
Bring your own beverages and sides for the burger melting and you will be "good to go!"
BEAR
GO SPURS GO!!!!
Old 03-18-2008, 09:50 AM   #21
Bear
Bear's Avatar
Default
Hey Brin…
you want me to bring along that radio shack cb for you? I have it out of the truck currently if you are wanting it.
BEAR
GO SPURS GO!!!!
Old 03-18-2008, 09:58 AM   #22
brinner
Brian
brinner's Avatar
Default
yeah bring it, i may get ambitious and mount it up.
Old 03-18-2008, 10:04 AM   #23
Bear
Bear's Avatar
Default
ambitious? three wires that are probably already in your truck and you are finished, and here I thought I was having motivational issues.
BEAR
GO SPURS GO!!!!
Old 03-20-2008, 12:13 PM   #24
brinner
Brian
brinner's Avatar
Default
just out of curiosity....does anyone have a set of leafs that i can drive around on for about 5 days? remember i have an 05+..........
Old 03-20-2008, 12:19 PM   #25
Bear
Bear's Avatar
Default
not a full set, not even sure if what I have would work for you.
Are you rebuilding or waiting on an order?
BEAR
GO SPURS GO!!!!
Old 03-20-2008, 02:56 PM   #26
brinner
Brian
brinner's Avatar
Default
i talked to scott at deaver today and he said he could re-arch and rebuild by 10-pack into a 12-pack for the 3.0 lift for a couple hundred and turn around would be a matter of days. But ill probably just get-er done the week following the WAT
Old 03-20-2008, 03:51 PM   #27
jeep crasher
Moderator
Default
hey not sure if these would work but i do have a set of 4" lift cj springs front and rear with 1.5" lift shackles. they would get you moving in the right direction to convert that thing into a jeep.
JC
Old 03-20-2008, 03:52 PM   #28
Bear
Bear's Avatar
Default
sorry, wish I could come up with a solution for you. I guess we could measure and see if any of the springs on the FJ would work, but I highly doubt it.
But it is a thought take some measurements!
BEAR
GO SPURS GO!!!!
Old 03-20-2008, 05:12 PM   #29
brinner
Brian
brinner's Avatar
Default
51.5" eye to eye if my memory serves me correctly
Old 03-21-2008, 01:02 AM   #30
Bear
Bear's Avatar
Default
I'll be in the garage tomorrow, I'll measure both the fronts and the back. I thinik they are not the same length.
BEAR
GO SPURS GO!!!!
You may not post new threads
You may not post replies
Forum Jump
Old Chinaman Gulch: End Of March, Tentative March 29th AxleIke Plan a Trail Run 158 06-01-2008 08:31 AM
Wrench A Thon wisehybred Central Region 32 12-09-2007 10:33 PM
Wrench-a-thon, Feb 3rd or 4th 99TanTaco Events 53 02-07-2007 06:15 AM
wrench a-thon padlinout76 Northern Region 7 08-30-2006 02:21 PM
Wrench-O-Thon ohio03trdtaco Events 150 08-28-2006 10:35 AM
Privacy Policy
Links monetized by VigLink
