Removing carbon filter above air filter - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > Late Tacoma Tech
Thread Tools Display Modes
Old 02-27-2008, 05:50 PM   #1
GMAK
GMAK's Avatar
Default Removing carbon filter above air filter
After reading lots of pages about this on yotanation, i decided to yank that carbon filter out. its held in place with a couple plastic do-dads.
did notice a slight mpg increase, and it wont hurt the motor. very very slight intake roar after 3500rpm, but not noticeable at all.
this is a pic of the v6 one, not my pic.
go niners
GMAK is offline   Reply With Quote
Old 02-27-2008, 05:58 PM   #2
MTtaco
Lucky Man
MTtaco's Avatar
My Rig: Tacoma Dbl Cab 4x4
Default
MPG increase. Cool I'll have to pull out mine too. Anything helps.
KEEP WORKING
MILLIONS ON WELFARE
DEPEND ON YOU!!!
06 DBL CAB OR, SAW 2.0's, Edelbrock extreme travel, Timbrens, TSB & Wheeler's 3 AAL rear,
255/85R16 Cooper ST's, Shrockworks Sliders, Light Racing UCA's, TJM Bull Bar
MTtaco is offline   Reply With Quote
Old 02-27-2008, 06:58 PM   #3
SoCalTaco805
Default
This is exactly why most aftermarket air intakes are not CARB legal in CA. I see you're in CA too. I would not get caught with out that and if they notice its not there at smog inspection for some reason you will not pass. The carbon filter is there to stop fuel gases from flowing out of the intake and into the atmosphere.
http://www.scionlife.com/forums/viewtopic.php?t=210180
theres more on the net if you read
SoCalTaco805 is offline   Reply With Quote
Old 02-27-2008, 07:15 PM   #4
GMAK
GMAK's Avatar
Default
so your trying to say this thin piece of carbon will stop ones truck from passing a smog test, uh no? the carbons will wear out after a couple years anyways...
go niners
Old 02-27-2008, 07:28 PM   #5
chris4x4
chris4x4's Avatar
Default
Gadget has alot of info on this. For one, It does not make a difference in power or MPG with it removed. Second, IT WILL not pass a smog inspection if it is removed.
'07 Quad cab Pre runner v-6, TSB rear leafs w/ AAL and Icon 2.5" remote resi's, Icon Ext. 2.5" Co's and TC UCA's, 32" Cooper Zeon LTZ A/T's.
chris4x4 is offline   Reply With Quote
Old 02-27-2008, 07:29 PM   #6
jptiger
Default
GMAK is right, the carbon is only capable of holding so much before it becomes saturated.
JTiger
2005 Tacoma 4.0, 4X4
jptiger is offline   Reply With Quote
Old 02-27-2008, 07:47 PM   #7
GMAK
GMAK's Avatar
Default
smog ''inspection''... no smog stations do inspections for carbon filter presense. im not telling you to do it, but i noticed a slight mpg difference.
go niners
You may not post new threads
You may not post replies
Forum Jump
K & N air filter over stock air filter? trd offroad Early Tacoma Tech 15 04-05-2007 04:02 PM
Amsoil Air Filter and Airraid intake/filter setup Bones Parts/Electronics/Wheels/Tires 17 12-04-2006 08:59 PM
Amsoil Air Filter or True Flow Air Filter Toydad Performance/Engine/Exhaust 7 06-28-2006 04:51 PM
Interior Air Filter/ Cab Filter BLOWNYOTA Interior/Electrical/Electronics 1 05-11-2005 11:30 PM
UNI Foam Filter wrap on K&N FIPK Filter 03trdblack Early Tacoma Tech 16 12-14-2004 07:11 PM
