Sponsored Ad
Go Back   TTORA Forum > General Tech > Cheap Tricks
Thread Tools Display Modes
Old 04-17-2008, 04:20 PM   #1
Switch
Switch's Avatar
Default Better bed storage in 2006 Taco
This has a cheap part and an expensive part. The expensive part was the custom wrap arround bumper. Once that was in, I realized I could use the space on the sides for storage. I just needed to remove the plastic cubby and make a new cover. I used adhesive magnetic strip to hold the cover in place.
Step one: remove the plastic cubby
Step two: make cover out of 3/8" ABS plastic
Step 3: attach magnetic adhesive strip. This figure shows two layers of magnets. The first layer is stuck to the new door, the second layer is stuck to the first layer magnetically. This allows marking the position of the holes using the old cubby. The holes are needed because the bolts for the old cubby are not flush with the bed. This way I get a good dust proof seal.
Step 4: attach the magnetic strip to the bed. This is done by pealing the adhesive strip off the magnet and carefully placing the new door into position. You can't just stick the magnets to the bed because the magnetic strips only stick to each other if the rows of magnetic polarity are alligned. That is why step 3 is necessary.
Once the magnetic strip adhears to the bed, the door can be removed for access. It pops snugly into place when you put it back.
The new storage space is big enough for everything that I used to keep in a large ammo can, plus a plastic tarp, ARB tire repair kit, and a small bag of bungie cords. I never used the 120V outlet so I just secured it inside the space with some zip ties.
2006 Tacoma
CA4WDC #11593
*****Don't believe everything you think*****
Last edited by Switch; 04-17-2008 at 11:59 PM. Reason: wife is anal about spelling
Switch is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
2006 4WD TRD Taco Front Coil Overs on a 1997 4WD Taco supra88 Suspension 5 03-30-2008 02:24 PM
2006 Taco TRD Access Cab CurlyFries Rigs/Trailers For Sale 1 03-03-2008 04:35 PM
2006 Taco parts 3jooom Parts/Electronics/Wheels & Tires For Sale 5 03-10-2007 11:07 PM
New 2006 or used 2005 Taco? TrpD345 Late Tacoma Tech 11 06-14-2006 08:50 PM
New 2006 Taco Advice cvajs Late Tacoma Tech 8 04-16-2006 10:57 AM
Sponsored Ad
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
