Spare Tire Carrier Build - TTORA Forum
post #1 of 14 (permalink) Old 09-03-2011, 12:24 PM Thread Starter
I finally got tired of my spare tire just sitting in the bed of my truck. So I decided it was time to build a tire carrier. I did not like the idea of any of the ones I have seen online, so I decided to create something a little different. All of the weight rests on top of the bed rails. And there are 4 bolts that hold it into place using the trucks factory rail system. I didn't take many pictures of the build process. But here they are anyways.
This is the main portion of the tire carrier. This rotates around the rest of the carrier allowing the tire to be locked in the down position, up position, or at a 90 from the bed:
Here is a picture of it completed and in the down position:
In the up position:
And one with paint just because:
Let me know yalls opinions.
Tacoatoy is offline
post #2 of 14 (permalink) Old 09-03-2011, 01:20 PM
truck ~n~ tow
TacoDell's Avatar
that's awesome... like the idea of options
nice work
would be sweet if that rotates freely at the flanges...
and is locked in place with a pin/padlock
does it ? or do you have to unbolt the flanges to flip it ?
Oh and does it have a third position ?
Meaning: can it be stood up vertically against the back of the cab ?
thanks for posting...
I was planning on doing something similar
oh.. and can we get a closer view of the flanges ?
Truck...
Trailer...
Truck build --- Trailer build
TacoDell is offline
post #3 of 14 (permalink) Old 09-03-2011, 01:46 PM Thread Starter
nice work
It does rotate freely around the flanges. I put a pin in the drivers side flange and a padlock in the passenger side flange. The added benefit of this being when the tire is in the down position it cant be taken out without removing the padlock as the rim doesnt clear between the carrier and the bed.
Currently I have it designed to stand up in the middle of the bed. Meaning tire between the tailgate and the carrier. If you slid the whole unit towards the tailgate then you could stand it up near the cab also. Currently where I have it mounted in the bed, its not possible to put the tire in that location as it cant clear the front of the bed during spinning.
If you specify what you wanna see on the flanges then Ill go out there and take the pictures and get them posted.
Tacoatoy is offline
post #4 of 14 (permalink) Old 09-03-2011, 04:13 PM
truck ~n~ tow
TacoDell's Avatar
guess I just wanted to see how the two flanges were mated
specifically on their inner face(s)
do the flanges have some sort of cylindrical insert design...
and if so.. how far does that extend into it's mate ?
Truck...
Trailer...
TacoDell is offline
post #5 of 14 (permalink) Old 09-03-2011, 06:05 PM
RelentlessTaco's Avatar
Nice design. i like the adjustment options it offers. Props for coming up with something dfferent than everything else out there!
I'm Eric, Owner/fabricator Relentless off-road Fabrication
DD/wheeler Radiant red '03 xtra cab 2.7 5spd. 35's, armored front to back
1998 T4R SR5 3.4L 5spd. 2" lift, 34's, full armor coming soon!
2005 4Runner Limited V8 4x4 GF's ride. 3" lift, 35's, Front bumper, sliders coming soon
RelentlessTaco is offline
post #6 of 14 (permalink) Old 09-04-2011, 12:02 PM Thread Starter
Gotcha. Ill get you a picture today but I think I can explain it too.
The flanges are actually just 3/16" plate that I cut out in a circular shape and I welded 1 piece to each end of the main portion. Which just so happens to be 1.75" tube. I then inserted a piece of 1.5" tube all the way through that and made my bends on either end of the 1.5" to position it where I wanted it in the bed. Then I cut out 2 more flanges and welded them to the 1.5" right up against the flanges on the 1.75" unit. Then I drilled holes in positions that would work for each location I wanted the tire to stop in.
Ill snap a picture or two of that today while I'm working and get them up later.
Thanks Relentless.
Tacoatoy is offline
post #7 of 14 (permalink) Old 09-04-2011, 12:32 PM
truck ~n~ tow
TacoDell's Avatar
that explains it... thanks
pictures would still be a plus
Truck...
Trailer...
TacoDell is offline
post #8 of 14 (permalink) Old 09-05-2011, 08:10 AM
jmoss13's Avatar
i like this idea. if you want more bed space put it on top...for security put it facing down.
Can i see some pics from the side
2003 Tacoma Ext. Cab TRD 4X4
TC LT w/ King CO and bypass, Deavers, ALLPRO Sliders, Skid Row T-case Skid, BFG 33x10.5 Mud's on 15x7 Soft 8's
2006 Tundra Dbl Cab
Stock for now
jmoss13 is offline
post #9 of 14 (permalink) Old 09-05-2011, 10:42 AM
my04yotatacoma's Avatar
Nice. The up position would plenty of room for a draw system. Was thinking about doing something similar. Two bars so I could move my yakima basket down when I mount a roof top tent. Deciding to mount yakima spare tire mount on top of draws once built and leave basket at home.
04 4wd tac demello bar hid 500FF's uniden 520 s/c with 7th inject kit 2.2 URD s/c pulley uws box innovate LC-1 XD-16 wideband kit Alcan 8 pack 5100 Bilestien's TC UCA's Icons ext rear brake line Alcans 255/85/16 maxxis bighorns 2002 tundra 199mm brake w/ R1 rotors and ceramic pads all-pro boots badland winch bumper 8000 patriot w/wireless remote TRD boost gauge/pod Jardine exhaust dual odyssey batteries CO dual batt tray National Luna solenoid + controller ARB comp w/ hose kit
my04yotatacoma is offline
post #10 of 14 (permalink) Old 09-05-2011, 11:38 PM
truck ~n~ tow
TacoDell's Avatar
umm... what tube wall thickness ?
Truck...
Trailer...
TacoDell is offline
post #11 of 14 (permalink) Old 09-05-2011, 11:52 PM
Mr Tacomi's Avatar
umm... can you easily disconnect it from the factory rail system and remove (steal ) the entire thing?
+()X()=
Mr Tacomi is offline
post #12 of 14 (permalink) Old 09-07-2011, 08:33 AM Thread Starter
Ive been kind of busy lately. Ill try to get some more pictures today.
.120 for both
Its only held in with 4 bolts. So I guess it could be, but with the tire on there its a heavy bastard. And most thieves go for the easy steal anyways. They want something that will take them less than 30 seconds to get at.
Tacoatoy is offline
post #13 of 14 (permalink) Old 09-08-2011, 12:45 PM Thread Starter
More pics as promised.
Tacoatoy is offline
post #14 of 14 (permalink) Old 09-08-2011, 08:52 PM
Bmiller7's Avatar
+1 for doing the dew!!
2005 Taco-White-SR5-factory locking rear diff.
Suspension-Engage LT with Kings/Donahoe rear shocks w/resi..Deaver 10 pack
Performance-K&N 63 series-Flowmaster 40 series-Doug Thorley Long Tube Headers
Wheels/Tires-Eagle 186 17x9-35" muds
Extras-Hella lights-Glassworks Unlimited on all corners-Cobra CB radio-My own fabrication
Bmiller7 is offline
Spare tire carrier southerncalix951 Late Tacoma Tech 6 04-15-2014 02:33 AM
In bed spare tire carrier tacoma818 Parts/Electronics/Wheels/Tires 3 11-13-2009 12:01 PM
WTB - spare tire carrier SP!N4L T4P For Sale/WTB in CO 1 12-31-2007 12:01 AM
WTB: Spare tire carrier hurley994 Wanted 0 02-11-2007 02:33 PM
Spare Tire Carrier and Spare Wheel WickedTaco For Sale/WTB in AZ 9 09-05-2006 04:33 PM
