Rear build - Page 7 - TTORA Forum
 1Likes
post #181 of 193 (permalink) Old 06-30-2007, 07:15 AM
Rusty's Avatar
I got the valve but now I'm trying to figure out how to adapt from metric brake lines to the proportioning valve. Did you cut and flare your hard line with a new fitting?
Rusty is offline
post #182 of 193 (permalink) Old 06-30-2007, 08:24 AM
Trunks Only's Avatar
front range off road sells an adapter....comes with the valve if you purchase it as a kit-- I'm sure they'd let it go separate tho....can't be that expensive. Just a word to the wise as well: If you decide to ditch the ABS system all together, that controller under the hood sells for a little over a GRAND from the dealer. Helps to fund other parts of the build......
Na Kamali'i o Kaua'i
Trunks Only is offline
post #183 of 193 (permalink) Old 06-30-2007, 11:13 AM Thread Starter
TRDtacoma1985's Avatar
Send a message via AIM to TRDtacoma1985
Its only wrong if you get caught
03 Prerunner v6 TRD ext cab
Total chaos long travel
16" Fox bypasses with 62's
Fuel safe
TRDtacoma1985 is offline
post #184 of 193 (permalink) Old 07-23-2007, 01:23 PM
what size plate did you use to box the frame?
7sx_Tacoma is offline
post #185 of 193 (permalink) Old 02-10-2008, 02:24 PM
Mtn. Prerunner's Avatar
Did you just cycle the leafs and use the fully extended shock measurment while the leaf was fully drooped then use the compressed measurment with the leaf bumped to get the two arches? Does that make sense??
Mtn. Prerunner is offline
post #186 of 193 (permalink) Old 02-11-2008, 04:08 PM
CentralCoastTaco99's Avatar
Check this out, I don't think it could be explained any better. Its designed around a Ranger, but it will work for any vehicle. there is also a sweet video showing you how to do it.
1999 Tacoma 4x4 TRD ext cab V6 5spd:
Long Travel, Tires, Fenders... the usual
CentralCoastTaco99 is offline
post #187 of 193 (permalink) Old 02-11-2008, 05:35 PM
That is perfect exactly what I was thinking thanks centralcoasttaco.
post #188 of 193 (permalink) Old 05-12-2008, 08:48 AM
usaf_taco's Avatar
this truck is up for sale on racedezert in the offroad truck section. sad to see someone work so hard and spend so much $ to turn around and sell it.
No more truck, now i play with sumo's
usaf_taco is offline
post #189 of 193 (permalink) Old 05-12-2008, 10:03 AM
shorty2305's Avatar
Hopefully he gets what he is asking for it, cause this thing is CLEAN!
2001 tacoma, equipped with all types of ill shit
shorty2305 is offline
post #190 of 193 (permalink) Old 05-12-2008, 10:09 AM
TimF's Avatar
too bad he was lazy with the cell install and it won't pass emmisions.
TimF is offline
post #191 of 193 (permalink) Old 05-12-2008, 10:32 AM
usaf_taco's Avatar
emissions suck, i am about to register my truck up in northen arizona so i won't have to worry about emission testing
post #192 of 193 (permalink) Old 05-13-2008, 01:54 AM
TimF's Avatar
Hurry, the laws are changing soon. I don't have some emmsions related equipment but I pass!
TimF is offline
post #193 of 193 (permalink) Old 01-29-2017, 07:43 PM
How did you end up plumbing the fuel cell? THREAD REVIVAL!
redtaco.taco is offline
FROR Rear disk / full floater kit arrived today!!! dstrbdone Early Tacoma Tech 68 01-02-2007 02:16 PM
Rear leaf springs on 03' Taco 3" lift recommendations! Rock-N-Ruin Suspension 9 07-27-2006 08:34 AM
Finnished the rear shock hoops. 14's! Wgasa84 Fabrication/Tools 26 06-25-2006 03:30 PM
Started my Build ratherBwheel'n Rock Buggy/Truggy Builds 15 10-18-2005 01:25 PM
