98 3rz with 95.5-97 3rz HELP!! - TTORA Forum
post #1 of 6 (permalink) Old 05-10-2019, 01:56 PM Thread Starter
Hey guys and gals, new to the Tacoma world.
My dilemma is I picked up a 98 Tacoma 2.7 3rz manual 5 speed. Engine got swapped out by previous owner and come to find out they used the early 3rz with a distributor. But kept the 98 harness. I got camshaft sensor codes because this one doesn’t have the camshaft sensor in the cylinder head, instead they spliced the old harness and ran 2 wires from the distributor plug to the cam sensor plug.
The truck idles and starts fine, but seems to jerk when under load or going up hills.
My question is I know the old distributor style got a camshaft signal from the distributor. Is there a way to wire or send the correct signal from the distributor to the 98 ecu to see the camshaft signal it wants so it doesn’t throw codes??? It gives me code p0340 cam position A sensor circuit fault.
Appreciate any and all info guys
Tacosupreme98 is offline
post #2 of 6 (permalink) Old 05-11-2019, 01:12 PM
First thing to know is whether both sensors are VR sensors or hall sensors. The distributor is a single pickup per RPM, not sure about the cam sensor.
post #3 of 6 (permalink) Old 05-11-2019, 01:12 PM
Scuba's Avatar
Iím not much help. Here is the wiring diagram from 1999.
Scuba is offline
post #4 of 6 (permalink) Old 05-11-2019, 09:18 PM
Scuba's Avatar
We literally posted at the same time.
Not sure thatís happened to anyone on here in years...
Scuba is offline
post #5 of 6 (permalink) Old 05-13-2019, 10:53 AM
I think everybody moved to the FB/IG world. I'm using that more these days to communicate with our members.
post #6 of 6 (permalink) Old 05-13-2019, 07:19 PM
Jblong's Avatar
Is it a Toyota group because couldn't find group that's like this one.
Jblong is offline
3RZ Supercharger Supra TT Early Tacoma Tech 2 07-25-2013 02:51 PM
2jz vs 3rz injectors MooseBit Performance/Engine/Exhaust 1 03-06-2010 10:09 AM
Supercharge or LC Engeneering a 3RZ wngrog Performance/Engine/Exhaust 9 05-09-2007 10:41 PM
late model 95.5 ? jwtacoma Newbie Tech 3 04-22-2007 06:16 AM
3rz items plus a few more. Buffstaco Parts/Electronics/Wheels/Tires 5 11-28-2006 11:44 AM
