JWaldz '99 4Runner Build - TTORA Forum
post #1 of 67 (permalink) Old 07-05-2011, 10:46 PM Thread Starter
JWaldz's Avatar
Finally slapped one together. I posted it up on another site and figured I'd bring it over here as well. I know it's a little past due for it, but oh well.
1999 LTD Toyota 4Runner, V6, Auto
Suspension & Lift
  • Front 2.5 650lb Extended Length SAW Coilovers
  • Rear 3" OME 891s
  • Bilstein 5125 ext. length rear shocks
  • ToyTec Diff Drop
  • ToyTec Panhard Drop
  • 2" 4Crawler Body Lift
Tires, Wheels, & Brakes
  • 315/75R16 Mickey Thomspon MTZ's
  • 16" '94 Lexus LX450 Wheels
  • 2006 Tundra 231mm Brake Swap
  • All-Pro Offroad 1.25" Hub-Centric Spacers
Offroad, Trail, & Lighting
  • '97 4Runner E-Locker (full axle swap) w/ Retrofit Wiring
  • ARB RD-90 Front AirLocker
  • ARB CKMA12 High Output On-Board Air
  • Nitro Fr/Rr 4.88 Gears
  • B.A.M.F. Kickout Sliders
  • Skid-Row Front Skid
  • Tacoma ARB Bumper (modified to fit 2" body lift)
  • 1st Gen 4Runner Roll Bar
  • 48" Hi-Lift Jack
  • Rage Products Rack & Fairing
  • 30" Totron SR LED Bar
  • Retro-Solutions 55W 8K Bixenon HIDs
  • Altezza Style Rear Tailights
  • Clear corners
  • LED Interior/Exterior Lighting
Electronics, Audio, & Performance
  • Kenwood KDC-X794
  • Cobra 18 WX-ST II CB Radio & 4' Firestick Antenna
  • 2 10" Rockford Fosgate P2 Subs
  • ScanGaugeII
  • Rockford Fosgate Punch 900w monoblock amp
  • DieHard Platinum P-5
  • Blue Sea Fuse Block
  • Bussman 100amp Breaker
  • TRD Trans. Cooler
  • 18" Magnaflow
  • Fog Mod (pre arb)
  • Full Time Outlet Mod
  • Deckplate Mod
  • Rear Diff Breather Extended
  • Antenna On/Off Select Mod
  • Scion Rockers (Blanks & w/ LED)
Other Aesthetics
  • Front & Rear Wet Okoles
  • Paracord Steering Wheel Wrap
  • Black Pearl Badges
  • Black Pearl Grille
Future Mods
  • External Trans. Cooler (done)
  • Tundra Brakes (done)
  • 4.88 Gears (done)
  • Front ARB Locker (done)
  • On-board Air (done)
  • Winch
  • Rear Plate Bumper
  • Interior Lighting (done-ish?)
  • Whatever other deals I come across
Most Current Pics
Stock (after putting tires on)
Short Pic Timeline
'99 Toyota 4Runner LTD
Dual Locked.. Geared.. Lifted.. 35s.. & Armored
My Ride - CarDomain & TTORA
JWaldz is offline
post #2 of 67 (permalink) Old 07-15-2011, 08:09 AM Thread Starter
JWaldz's Avatar
Poser shots
JWaldz is offline
post #3 of 67 (permalink) Old 09-05-2011, 08:21 PM Thread Starter
JWaldz's Avatar
Man, I've been neglecting this! I've been getting pretty crappy mpg, so I decided to change my plugs and wires. Bought some NGKs and with the help of a friend, it all went swiftly. Next will be doing a seafoam cleansing as well as a few other things. I'm really hoping to get enough saved up for the tundra brake swap before SCC.
I bought a TRD trans cooler from a guy on T4R. Unpackaged but not used. This will keep me away from the 'ol "strawberry milkshake" problem.
I re-routed a couple switches and replaced them with ones from Scions that fit in the OEM spots. If you're looking for some here are the links.
Lighted: http://www.oznium.com/scion-switch-led
Non-Lighted: http://www.oznium.com/gsw-45
JWaldz is offline
post #4 of 67 (permalink) Old 10-01-2011, 09:00 AM Thread Starter
JWaldz's Avatar
Got a few items recently
Ended up getting a good deal through my buddy that works at an auto store. After I return the cores I will only be spending $260, which isn't bad at all. I'll eventually upgrade rotors. I really want some Brembo cross-drilled rotors.
A few weeks ago I got a good deal on some center caps, finally . They make it look great. They aren't in perfect condition, but they still have all the clips. Just a little paint faded.
Also, a while back I purchased a TRD Trans Cooler. If I have time after the brake install I will put it on. Not excited about having to drop my skid-row skid, not only does it weigh a ton but it's a bi#@$ to line up cus it's so torqued from all the rock hits lol.
09/29/2011 Tundra 231mm Brake Swap
Went pretty straight forward. For as major of an upgrade it is, it's very easy. They wont fit the lc80 wheels so either grinding or a spacer is required. Not wanting to grind, I chose to buy wheel spacers. Also after thinking about it, I realized if I ever have a blow out on the front, my spare wont clear! That would be a big problem. I highly advise those that change their front brakes to go ahead and do a full fr/rr brake bleed. Starting the farthest from the MBC and working towards it.
JWaldz is offline
post #5 of 67 (permalink) Old 10-16-2011, 06:17 PM Thread Starter
JWaldz's Avatar
I need a new rear bumper.. shall we start a donation?!
Also took a lot of the stickers off both sides and added a new one on the back.. Gettin excited bout opening duck season, right around the corner!
JWaldz is offline
post #6 of 67 (permalink) Old 02-25-2012, 12:08 AM Thread Starter
JWaldz's Avatar
Man I've slacked on this. Since my last update I've added some 1/4 front spacers to pick up the front a little and found a good deal on some Lx450 wheels. I think that's about it.
Update coming though. I just bout an ARB CKMA12 High output air compressor and an ARB compressor hose kit from a guy on YT for $200 shipped. That should push the new front 7.5 3rd I just ordered from ECGS with 4.88 gears and ARB locker pretty well. No more gettin stuck in ravines
Will be hooking up the rear with some 4.88s as well then find some 35s to slap on. Eventually get me some limit traps for the front and extended bump stops for the rear to keep from tearing up too much.
Still wanting a rear bumper w/ swing out. I don't like not having a spare tire on board. They just cost too freakin much. Waldo needs a new rear bumper fund anyone?!
Here's a couple pics just for S's&G's
JWaldz is offline
post #7 of 67 (permalink) Old 02-25-2012, 03:35 PM
79coyotefrg's Avatar
now THAT is sexy
AR-TTORA founder/current President, www.ar-ttora.com
22R bored .060 over, LCEngineeing stage II race cam, 3236 weber,
entire drivetrain from www.Marlincrawler.com 1200 NON ceramic clutch, L52HD 5 speed + dual transfer case. Driveline E-brake, front suspension and hi-steer from www.allprooffroad.com
79coyotefrg is offline
post #8 of 67 (permalink) Old 02-29-2012, 08:20 PM Thread Starter
JWaldz's Avatar
Got the compressor in today. Tested it and it works great. Did some internal wiring and it's ready to be mounted and wired under the hood. No news from ECGS. I don't know when they'll have the diff ready. I hope soon.
Something is missing here!!!
JWaldz is offline
post #9 of 67 (permalink) Old 03-05-2012, 05:30 PM Thread Starter
JWaldz's Avatar
Got a call from ECGS today saying my diff should be here this week, FINALLY! Hope to get it and the compressor installed before or by this weekend.
Ordered new bushings from Wheelers for the steering rack and front sway bar. They should be coming in soon as well.
Man, there's lots to do lol.
Oh, I also got a hell of a deal on a AnzoUSA 10" LED light bar so I snagged it
Another update to follow... (with pics of course)
JWaldz is offline
post #10 of 67 (permalink) Old 03-11-2012, 03:14 AM Thread Starter
JWaldz's Avatar
Man what a pita swapping a front diff is. The rear was so much easier. The hardest part was getting the diff out. All in all everything went well and no busted knuckles which was a plus lol Thanks Josh for all the help!
Then it was on to installing the compressor. With absolutely no place to put it, I decided next to th battery was the only solution. So I bought a metal plate to go from under the battery and extend out in the open area. Put an L bracket to extend the support, painted and bolted it all down. Works very well. Glad to be have this project done. Next will be 4.88s for the rear.
JWaldz is offline
post #11 of 67 (permalink) Old 03-11-2012, 10:58 AM
YotaJosh's Avatar
'87 FJ60 Land Cruiser
'04 4Runner V8 Sport 4x2
YotaJosh is offline
post #12 of 67 (permalink) Old 03-11-2012, 10:50 PM
Good work, Waldo!
AR-TTORA Memphis Sub-Chapter TEAM Leader
Jordan7118 is offline
post #13 of 67 (permalink) Old 03-17-2012, 05:06 PM Thread Starter
JWaldz's Avatar
Lighting up the night
JWaldz is offline
post #14 of 67 (permalink) Old 03-19-2012, 07:03 AM Thread Starter
JWaldz's Avatar
I don't think I'll fit in the garage anymore..
315/75-16 ProComp XTerrains
JWaldz is offline
post #15 of 67 (permalink) Old 03-19-2012, 10:05 AM
YotaJosh's Avatar
Would the light bar mount on the bottom of that top bar, between your other lights?
YotaJosh is offline
post #16 of 67 (permalink) Old 03-19-2012, 10:46 AM Thread Starter
JWaldz's Avatar
I tried but it's too wide. That and there's no way of mounting it centered up. So, even if I moved the Hellas up top there still wouldn't be a place to mount it. Is this your way of saying it looks funny/dumb lol.
JWaldz is offline
post #17 of 67 (permalink) Old 03-19-2012, 10:46 AM
Arky Tacoma's Avatar
x2 on Josh's comment. Looks kinda bad on top of the bar. Just my
With those tires and locker in the front, I hope you have saved some money for some spare CV's. Ask me how I know
Arkansas TTORA
www.ar-ttora.com
2002 Tacoma Xtra Cab V-6 4wd
Dana 44 Front Axle/ARB Locker/Rear LockRight
4.88's
ARB Bumper/Warn M8000/Amsteel Line
4xInnovations Sliders
Torch Worx Fab Rear Bumper
37x12.50/17 Cooper STT's/Black Steelies
Viair 450c OBA System
Uniden Pro520xl CB w/ 5 ft. Hustler whip
Arky Tacoma is offline
post #18 of 67 (permalink) Old 03-19-2012, 11:09 AM Thread Starter
JWaldz's Avatar
I don't know where else to put it really.. It would look equally as goofy with the Hellas up top.
Advanced Auto lifetime warranty lol.. I got two spares already. I only plan to use the front locker if I have to, that's the benefit of having a selectable.
JWaldz is offline
post #19 of 67 (permalink) Old 03-19-2012, 11:38 AM
Haha! Well, "only when you have to" will be most of the time
Not sure the quality on the Advance CV's, but if they are anything like the crap O'Reilly has, then stay away! I had the best luck with OEM's, and they are around if you look around the various boards...
Arkansas TTORA
www.ar-ttora.com
4.88's
post #20 of 67 (permalink) Old 03-19-2012, 01:36 PM
LDT98's Avatar
Send a message via AIM to LDT98
Looks good man. Drill some holes a little farther out to mount your hellas and then build a mount if need be to flip that light bar over like josh was saying. It'll keep it from getting knocked off and I think it'll look pretty slick. And seriously would you paint those freaking sliders black already haha.
LDT98 is offline
post #21 of 67 (permalink) Old 03-19-2012, 02:27 PM
Waldo bringin' the lights!
This cracked me up
Exterior Aesthetics
post #22 of 67 (permalink) Old 03-19-2012, 02:45 PM Thread Starter
JWaldz's Avatar
All suggestions noted. No, O'Reilly cv's just truly suck. People have suggested getting anything but them.
Sliders are coming off, they're just way too long and there's no fixing them. I'm getting new ones and yes, they will be black
JWaldz is offline
post #23 of 67 (permalink) Old 03-19-2012, 02:47 PM
Sliders are coming off, they hit and I'm getting new ones.
What you talkin' 'bout, Willis?
post #24 of 67 (permalink) Old 03-19-2012, 03:07 PM Thread Starter
JWaldz's Avatar
Responded to text
JWaldz is offline
post #25 of 67 (permalink) Old 03-21-2012, 09:46 AM
LittleRock80's Avatar
Waldo, I'm likin' the ARB's and 315's! Did I miss it--did you say what make/size your light bar is? Rigid/Vision X/other?
Rig is looking great. Your RED sliders make you easily identifiable on I-430 at 70mph!
Jwp
'97 FZJ80 w/ Factory FF/RR Lockers, White, OME 850/860/CC, Bilsteins, 315 KM2's , Slee SS brake lines and Head Light harness, JDM Aux Fan, Marlin sliders, WARN XD9000i on modified WARN Classic (Retro)Winch Bumper
LittleRock80 is offline
post #26 of 67 (permalink) Old 03-21-2012, 11:46 AM Thread Starter
JWaldz's Avatar
Jwp
Thanks man. It's an 10" AnzoUSA. Got it for $135 new. Well it's gonna be more difficult now, cus I took them off haha. I'll get some new ones up sooner or later, but they won't be red I need to get my rear gears before I get anything else.
Bye bye sliders..
JWaldz is offline
post #27 of 67 (permalink) Old 03-22-2012, 08:52 AM
tchughes's Avatar
In Little Rock I think we can still identify his Runner by the 35's, not many here. Glad to hear the new rock sliders will be black. Great looking Runner.
tchughes is offline
post #28 of 67 (permalink) Old 03-22-2012, 05:20 PM Thread Starter
JWaldz's Avatar
I've only seen/met one other guy with 35's in Little Rock. He also has LX450 wheels, but it's silver and he has stock bumpers. He's probably in his late 30s.
JWaldz is offline
post #29 of 67 (permalink) Old 03-22-2012, 07:14 PM
tchughes's Avatar
Some how I never see many built Runners in the Rock and you say late 30's like its a bad thing.
tchughes is offline
post #30 of 67 (permalink) Old 03-22-2012, 08:28 PM Thread Starter
JWaldz's Avatar
There was a guy that lived in Bryant with a maroon one who I saw almost every morning on I30 cus he worked in Little Rock. Good guy, he helped with my body lift. I have a good friend with an '02 with shrockworks bumper and some lift. There are a few but they're around. I get looks from high school kids in 3rd gens every day pretty much lol. A lot of mean muggin'
30's isn't SO bad... haha jk
JWaldz is offline
85 4Runner Build DangerRanger Tech 125 05-27-2014 08:24 AM
07 4Runner Build Josh220 Late 4Runner Tech 48 05-13-2011 01:32 AM
87 4Runner build (SAS) fourx4sr4me Pickup/Early 4Runner Tech 15 12-09-2009 06:33 PM
4runner build Snorkie Pickup/Early 4Runner Tech 1 05-11-2009 09:36 PM
My 4Runner Build: DixieOverGeorgia Tech 83 01-11-2009 06:24 PM
