Built & Restored 1985 4Runner - TTORA Forum
post #1 of 72 (permalink) Old 10-29-2008, 09:54 AM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Arrow Built & Restored 1985 4Runner
Well, everybody I know has been buying old 1st gen 4Runners lately so I decided to jump on the band wagon. I'm going tomorrow to pick this one up in Dallas and drag it back here to Houston.
Figure I will throw a little money into this thing to make it a nice trail worthy rig.
Bone stock '85 4Runner 22RE automatic.
"The beatings shall continue until morale improves
~ The Captain
TOYMINATOR is offline
post #2 of 72 (permalink) Old 08-16-2009, 09:30 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Arrow 1985 4Runner lengthy Resto/Mod
Well, this thing has been sitting for almost a year as I collected parts. Time to get this project started.
Mods will include:
Dana 60 front, locked
14 bolt Corp rear, spooled
Marlin Trailflex 5" lift leaf springs front and rear
Full Hydro steer
Inchworm dual cases
Full internal roll cage
And most importantly...A/C !!!
Axles that will go under her: Dana 60 front and Corporate 14 Bolt rear
~ The Captain
post #3 of 72 (permalink) Old 08-17-2009, 07:19 AM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Engine overhaul gasket kit and new head bolts ordered.
~ The Captain
post #4 of 72 (permalink) Old 10-06-2009, 06:11 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Rear 14 bolt getting a makeover
Disc mounts
Front Dana 60 getting a Manicure:
Hydro steer mount
Front gears and locker
~ The Captain
post #5 of 72 (permalink) Old 10-25-2009, 07:44 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Gears and locker = DONE
Axle shafts and knuckles = DONE
Front cover and Ram mount = DONE
Bearings cleaned and greased = DONE
~ The Captain
post #6 of 72 (permalink) Old 12-20-2009, 07:42 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Parts are coming in,
Time to pick up the pace on this project
Getting the axle mounts cut off and mounting the axles.
With the cutting torch tip clogged up, and the welder out of wire, it was time to go home.
Got more done on it this weekend than I expected. Atleast it's starting to come together.
~ The Captain
post #7 of 72 (permalink) Old 01-04-2010, 11:15 AM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Cool
Well she's actually sitting on the ground on the roller wheels and tires.
~ The Captain
post #8 of 72 (permalink) Old 01-31-2010, 07:39 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Ok, made some more progress...
Shortened the front shackles 1" to improve pinion angle and having 6 degree shims made to keep angles happy.
Started on hydrosteer stuff...
Removed old steering system
Pump is in.
Mounting orbital valve:
~ The Captain
post #9 of 72 (permalink) Old 02-22-2010, 09:02 AM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Spent the Day out at The Ranch....
Tacoma brake booster and Chevy master cyl:
Fender trimming and shock hoops done:
Power steering reservoir mounted:
Might be able to raise the power steering reservoir if it clears the hood.
~ The Captain
post #10 of 72 (permalink) Old 03-08-2010, 08:26 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
This beast is itchin' to get out and eat some rocks soon....
Needs More Cowbell!!! And some big boy tires!
~ The Captain
post #11 of 72 (permalink) Old 03-21-2010, 06:23 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Test fitting the 39.5's and getting ready to cut some sheetmetal...
Next she's off to CEO for the cage work and my hydraulic slider design to be fabbed.
~ The Captain
post #12 of 72 (permalink) Old 06-13-2010, 09:28 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Well, she is back home after sitting over at CEO for over 2 months. Here are some pics I snapped of her today...
drivers side retractable slider in up position...
drivers side retractable slider in down position (half way down)...
Front ram mount...
Rear ram and joystick mount...
Bed portion of cage...
Cab portion of cage...
Passenger side slider...
Winch line attachment added to stinger...
Light tabs added to front bumper...
Rear bumper...
~ The Captain
post #13 of 72 (permalink) Old 06-13-2010, 10:08 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Here's a closeup of one of the mounts and one of the seats the slider retracts back into...
Next up on the list...Inchworm dual cases. Stay tuned!
~ The Captain
post #14 of 72 (permalink) Old 08-20-2010, 09:36 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Dual cases going in...
Rear driveline disconnect installed...
~ The Captain
post #15 of 72 (permalink) Old 11-12-2010, 06:37 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Hydraulic pump for the retractable driver side slider.
Well, this is what happens when you know nothing about fluid dynamics such as in my case. The power steering pump on the truck doesn't have a large enough reservoir to push the fluid to run the rams on the retractable slider. Thanks to the good people over at Surplus Supply Center, they got me setup with the electric hydro pump you see above. This will be mounted in a cradle behind the drivers seat.
The valve I had to control the slider is now being replaced by this push button control box...
~ The Captain
post #16 of 72 (permalink) Old 11-15-2010, 10:21 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Time to flex her out to clearance the fenders...
~ The Captain
post #17 of 72 (permalink) Old 11-21-2010, 08:52 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Can you say BONDO!
Bump stops tacked in place...
Front
Rear
Fenders being cut and rolled...
Front
Rear
Seats being fitted...
Drivers seat bracket
Driveshafts will be here tomorrow. I'll snap some photos of them when they arrive.
~ The Captain
post #18 of 72 (permalink) Old 12-13-2010, 09:14 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
A little more progress...
~ The Captain
post #19 of 72 (permalink) Old 12-16-2010, 09:01 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Just say no to BONDO...
Rear quarter panel replaced with the donor
This came in the mail today, a Winters gate shifter from Art Carr
New seat mounts just about done
~ The Captain
post #20 of 72 (permalink) Old 12-21-2010, 08:10 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
More clearance, passenger side
Driver side buttoned up
Driver seat slides all the way back now
Shifters mounted
As you can see from the photo above, the lever for the gate shifter almost touches where the radio goes. What I'm thinking is to make a "wedge" to place under the shifter to pitch the entire console upward at the lever end. This will give more clearance between the lever and the radio ultimately.
~ The Captain
post #21 of 72 (permalink) Old 12-27-2010, 05:49 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
I've figured out how to keep people from asking to ride in your back seat.
Put a fuel cell in it's place!
~ The Captain
post #22 of 72 (permalink) Old 04-01-2011, 10:13 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Fuel door added to drivers side:
Need to fix leaking hydro steer hose:
Shifter mocked up:
Fuel cell and Slider hydro pump mounted:
~ The Captain
post #23 of 72 (permalink) Old 07-05-2011, 10:57 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
She's rollin on her own power...........
Now we have to see what it will take to get it reliable and road worthy.
~ The Captain
post #24 of 72 (permalink) Old 08-11-2011, 11:44 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Couldn't stand the brown trim interior, so switched it of for the gray...
Sprayed the entire floor pan and bed with Raptor Liner.
And got the CB installed...
Will be heading for paint and body work soon.
~ The Captain
post #25 of 72 (permalink) Old 08-19-2011, 07:42 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Project: TOYMINATOR
Cleaning my garage yesterday I came across these...
A set of BCS F1 "gyromation" beverage holders. I had won these as a raffle prize several years ago. At the time, I still had my Tacoma and it had perfectly working factory cup holders in it. So I threw these things in a box and figured I could maybe use them one day. Well that day was today.
I figured I'd mount them to my cage, but the mounting bracket they came with was kind of a dog legged shaped, flat bracket. Not really something that would mount directly to tubing. Then I remembered I had a set of these...
About a month ago I had ordered a mount for my CB and for my Maglite from FOURTREKS. Backordered parts delayed my order so they threw in a set of their basic clamps (pictured above) for my troubles.
The good thing about their clamps is that they have a flat spot on one side, which made a perfect spot to mount the bracket that came with these beverage holders...that is, after a little cutting and trimming to make just a simple tab out of it...
Now the driver and passenger have their own blingin beverage holder...
The FOURTREKS clamps worked great and look really clean. But I do have to admit had it not been for the fact that I got all this stuff free of charge that I would have never spent that much money on a couple of beverage holders. Just a price break down, you can figure $50 bucks for a pair of the BCS F1's and $55 bucks for the FOURTREKS clamps. But I figured since I wasn't out no money on this that it was some pretty cool bling!
~ The Captain
post #26 of 72 (permalink) Old 08-25-2011, 07:54 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Well, since I did not have an overhead cabin light, not to mention that it would be covered up by the cage if I had one anyways, I decided to rig up something of my own.
I went down to the local big rig chrome shop and picked up a 12" LED strip light to recess into the roll cage padding. I basically cut the padding to fit perfectly around the LED strip...
I installed a rocker switch in the padding as well which was tied back into the factory overhead cabin light wiring to control the LED's...
Worked just like I wanted it to! Throws off plenty of light at night, as you can see, and since it's recessed into the padding there is nothing hanging down to possibly hit your head on, which is what I wanted!
Heading off to the shop for paint and bodywork next week!
~ The Captain
post #27 of 72 (permalink) Old 01-23-2012, 08:29 AM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Project: TOYMINATOR
Well, she's home from getting the new paint. I gotta paint the top still but that won't be much of a problem.
Playin around before heading home...
Loaded up, ready to come home...
~ The Captain
post #28 of 72 (permalink) Old 02-01-2012, 04:50 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Okay, so lets recap!
Some before and after pics...
October 2008
January 2012
~ The Captain
post #29 of 72 (permalink) Old 02-02-2012, 03:16 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Some LED lighting for the headlights.
~ The Captain
post #30 of 72 (permalink) Old 03-04-2012, 02:26 PM Thread Starter
Hoist The Colors!
TOYMINATOR's Avatar
Latest additions.
New custom interior diamond plate aluminum panels...
Half Top installed...
~ The Captain
Built 1985 FJ60 freds40 Vehicles/Trailers 0 12-23-2011 11:33 PM
Built & Restored 1985 4Runner trollcruiser Vehicles/Trailers 20 07-21-2010 10:32 PM
Built, 1985 Toyota 4Runner $6000 obo Northern California Burglar Vehicles/Trailers 12 02-28-2009 09:29 PM
Rolled, built-up 1985 Toyota 4Runner in Phoenix for $3000 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxakc1955 Vehicles/Trailers 9 11-27-2005 09:28 PM
1985 4runner for sale, built for trail & street jdfilms Vehicles/Trailers 1 03-20-2005 06:13 PM
