Highsteer Dana 44 under taco tie rod interference - TTORA Forum
post #1 of 10 (permalink) Old 08-13-2016, 08:46 PM Thread Starter
Fit up my tie rod today for highsteer on a 79 f250 Dana 44 with arms that I bought with axle. Tie rod needs to come up 3/8" to clear springs without any weight on them and brand new. I know weight will flatten them and tie rod will clear but I am concerned that at full droop leafs will hit tie rod. I might get a spacer and longer knuckle studs but am complete noob, before ordering do you all think current setup will work or that I will need a spacer or taller arms? I might just try it but thought someone might have some insight to share.
Harmonytaco is offline
post #2 of 10 (permalink) Old 08-15-2016, 10:46 AM
post #3 of 10 (permalink) Old 08-15-2016, 11:24 AM Thread Starter
I would rather go with a taller arm like you suggested than putting a spacer in and having to buy longer studs and spacer. I will look at the sky arms you linked thanks.
I realize there are a ton of factors involved in suspension cycle but when one side is stuffed to bump and the other side droops completely out I am worried that even a 1" taller arm will allow tierod to hit leafs, not sure if under this circumstance the leafs actually arch more than how they sit now with no weight. Maybe limiting droops the answer. I may just hold off and flex everything out before final welding tie rod or spending more money on parts I am not sure will work.
post #4 of 10 (permalink) Old 08-15-2016, 04:16 PM
I'll let some of the SAS guys chime in with their experiences, but I've seen the tall arms installed on several SAS rigs over the years.
post #5 of 10 (permalink) Old 08-22-2016, 07:09 PM
Dick Foster's Avatar
My answer is to get rid of the wanky leaf spring setup and go with some links and coilovers but that's just me.
Dick Foster is offline
post #6 of 10 (permalink) Old 08-23-2016, 05:28 AM
countryboyAL's Avatar
Or go low steer.
Sent from my iPhone using Tapatalk
89 Pickup
AO front winch bumper, taylor fab sliders and skids, trailmaster lift in front, stock duals, 36x13.50 Irok, 4.88 gears, lockrite in the rear, 63" Chevy leafs
Originally Posted by TacoDell View Post
~ off road thought, for the day ~
" if ya wheel like an idiot... it probably shows "
Originally Posted by cztheman64 View Post
yeah but you wheel like Tim Cameron
countryboyAL is offline
post #7 of 10 (permalink) Old 08-24-2016, 10:33 AM Thread Starter
I will go low steer if I can't get high steer to work. I am not smart enuff to do links
post #8 of 10 (permalink) Old 08-26-2016, 12:30 AM
shorter steering arms would help
post #9 of 10 (permalink) Old 09-21-2016, 05:55 PM
ZUK
Harmony-
You might not even have an issue there once you have the leafpacks clamped DOWN tight(u-bolts tightened up).
gearinstalls.com
2001 Taco xtra-cab 3.4L auto TRD white
SAS'd with FJ60axle and flipped.
Frontal shackles.
Allpro front/rear 5" leaf packs
35" KO2 tires
rear 8" G2 488 gears
front 9.5" 488 Nitro gears
ZUK is offline
post #10 of 10 (permalink) Old 09-22-2016, 03:10 PM Thread Starter
I hope so. Started tearing the IFS off and started a new thread in the SAS section.
First gen taco inner tie rod ends 98taco3 For Sale/WTB in CO 0 02-23-2009 08:16 PM
04 taco tie rod end Tunataco Newbie Tech 2 11-26-2008 11:12 PM
2004 toyota tacoma v6 interference or non interference stryk3 Tell us who you are 1 03-22-2008 06:07 AM
taco inner tie-rod ends BOVADS Long-Travel Suspension Tech 2 10-17-2007 11:29 PM
taco inner tie rod ends BOVADS Tech/Tricks 3 10-17-2007 09:01 PM
