6 Speed Quick Shifter question - TTORA Forum
post #1 of 7 (permalink) Old 06-02-2012, 12:39 PM Thread Starter
Next week my new 2012 Tacoma 6 speed V6 TRD Off Road will arrive and I will take delivery. Woohoo!
Anyways, question, I'm looking at having the Toyota Quick Shifter installed.
Anyone here have experience with using this shifter? OR have an opinion on them?
"TRD Tacoma Quickshifter for 4WD 4.0L V6 with 6-speed manual transmission. TRD Quickshifters deliver, faster, positive shifting. Repositioned pivot points provides a 30% shorter shift throw."
Thanks,
Badger12 is offline
post #2 of 7 (permalink) Old 06-03-2012, 02:48 PM Thread Starter
Badger12 is offline
post #3 of 7 (permalink) Old 06-03-2012, 03:05 PM
Ask Teryx. He has one I think. He is also very knowledgable and will give you good info, not just "I like it."
I have thought about the URD model for my 5 speed and wouldn't buy any other. Would it void your warranty though?
If you search there are some threads on this.
2000 Tacoma
3.4 TRD
ICON C/O
Marlin Clutch.....Totaled in Flash flood
2005 Tacoma
4.0 L
King ext. C/O
T/C UCAs...Totaled in ANOTHER Flash Flood
2012 Tacoma
4.0 TRD
stock still
Wainiha is online now
post #4 of 7 (permalink) Old 06-03-2012, 09:11 PM
adam83's Avatar
I have had URD's short shift kit in my 07 6 speed for 75k miles now and I wouldn't have it any other way. It gives a nice feel and reduces the throw to what i feel is a perfect amount. Also took out some of the notchiness of the 2-3 shift. The only downfall I can think of is the increased effort to shift into reverse, but after a week or two of getting used to it I was able to pull it into reverse as easy as the stock shifter.
New ride: 2015 4Runner Trail
Stock as hell
Old ride: '07 Tacoma 4x4 DC TRD sport 6sp.
Toytec 3" lift OME 885 and CS047R 5100s
Eagle alloys 285/70/17 Duratracs
Shrockworks sliders
adam83 is offline
post #5 of 7 (permalink) Old 05-09-2019, 10:13 AM
Has anyone received the TRD quickshifter with the locating rings at the opposite diagonal on the shifter spacer as shown in photo? I am curious how easy it would be to pull out the rings on the transmission without causing too much damage.
fourangrysquirrels is offline
post #6 of 7 (permalink) Old 05-09-2019, 11:02 AM
The guide dowel? It should be able to be tapped out from the shifter housing. What do you want to remove it? They help reduce the torque stress on the housing.
http://www.gadgetonline.com/shifter.pdf
post #7 of 7 (permalink) Old 05-10-2019, 09:59 AM
It was somewhat of a dumb question before I really cracked into it haha. The locator rings come out very easily on transmission. I had to remove to make way for the new spacer plate. Then you can put the removed locator rings on top of the spacer plate. Locator pin Toyota part number is 90253-11021 if anybody needs new ones.
WTB: V6/Turbo 5 Speed Shifter 87TurboSR5 Parts/Electronics/Wheels/Tires 0 05-03-2012 01:16 PM
quick question on 5 speed swap dntsdad Early Tacoma Tech 12 07-23-2010 11:11 AM
O5 6 Speed Shifter Failure And Fix Oily Late Tacoma Tech 3 04-14-2010 01:44 PM
URD short shifter 05 - 07 six speed new! jroffroad Parts/Electronics/Wheels/Tires 2 04-24-2008 05:24 AM
FJ Cruiser TRD Quick Shifter XRUNNER05 Vendor Deals 0 10-30-2006 12:54 PM
