1991 Toyota V6 - TTORA Forum
post #1 of 9 (permalink) Old 01-27-2019, 05:04 PM Thread Starter
DETrOi529's Avatar
1991 Toyota V6
I going to change timing belt on my 1991 Toyota 4x4. I’m trying to loosen crankshaft pulley bolt, I tried with 1/2 air impact, but no go. Is there anyway to remove crankshaft pulley bolt? Toyota FSM on this truck mention some SST tool to hold pulley in place. Apparently left out some information, 5 spd manual trans.
1991 Toyota XCab 4x4, 3.0 V6, LCE Performance Cold Air Intake, Crane Cam Ignition System, NGK 6341 IridiumIX Spark Plugs, 5 Spd. Manual, with Marlin Crawler Short Throw Shifter, 5.29 Gears with Detroit Lockers. 35x12.5-15 BFG KM2s, ALCOA RIMs. My Daily Driver!
DETrOi529 is offline
post #2 of 9 (permalink) Old 01-28-2019, 10:52 AM
Lots of different options. You can wedge the flywheel, use a chain wrench on the pulley or the more popular route is to wedge a breaker bar on the frame and bump the starter.
post #3 of 9 (permalink) Old 01-28-2019, 12:18 PM Thread Starter
DETrOi529's Avatar
Thanks for reply. I'll try the more "popular route," apparently dangerous.😳
post #4 of 9 (permalink) Old 01-28-2019, 03:15 PM Thread Starter
DETrOi529's Avatar
Apologize. Apparently never get shirt together. I removed radiator. Now get plenty of room to work. Use whatever option there is.🙄
post #5 of 9 (permalink) Old 01-30-2019, 08:37 AM Thread Starter
DETrOi529's Avatar
Apparently, the “breaker bar on fame” trick did not work. I’m told the Toyota factory use Locktite on crank pulley bolt threads, and I know bolt is torqued to 181 ft-lbs. There is “jig” from OTC that is available on Amazon, I’ll try it out.
post #6 of 9 (permalink) Old 01-30-2019, 10:21 AM
There is not supposed to be loctite on that bolt, but they are often a real pain to crack loose. If the starter bump trick didn't work, you should be cautious that you might be risking snapping the bolt off in the crank.
post #7 of 9 (permalink) Old 01-30-2019, 12:24 PM Thread Starter
DETrOi529's Avatar
Apparently, a shop did waterpump and timing belt awhile back on my truck. I don't know if tech used Locktite.
post #8 of 9 (permalink) Old 01-30-2019, 06:22 PM
the_slug's Avatar
  • Rotate the engine a little past TDC on cylinder #1.
  • Remove the #1 spark plug.
  • Slowly feed a thin rope/cord into the cylinder. The idea is to "fill" the cylinder with the rope.
  • When you try to break the crankshaft bolt loose the piston will not be able to continue to travel up and therefore should break your bolt loose.
I saw this a couple years ago on the internet. I've successfully used it a couple of times since. The rope won't score the walls and won't be able to be compressed.
1988 4Runner
3.0 - old and tired and now removed
5 Speed
Walmart Special center console
the_slug is offline
post #9 of 9 (permalink) Old 02-03-2019, 10:45 AM Thread Starter
DETrOi529's Avatar
I used crankshaft pulley holder and long 3/4 drive ratchet, with adapter, I managed to loosen crankshaft pulley bolt. Bolt never had Locktite on threads. Iím putting things back together, try finish today.
Just bought 1991 Toyota Truck. What mods shoud I start with????????????? Chris Sparks Pickup/Early 4Runner Tech 9 10-23-2009 12:13 PM
Just bought 1991 Toyota Truck, Southlake, Texas Chris Sparks Tell us who you are 2 09-15-2009 07:36 AM
Parting out 1991 Toyota Pickup Crawler 05TuRDTACO Parts/Electronics/Wheels/Tires 14 09-02-2007 01:36 PM
Bucket Seats 4xtaco Early Tacoma Tech 6 09-25-2006 05:23 AM
FS: K&N Air Filter 33-2054 Stallion Parts/Electronics/Wheels/Tires 4 08-19-2005 09:37 AM
