The engine light came on in my moms '02 Rav4. Showing 2 codes, P0420 and P0430 (Catalyst System Efficiency Below Threshold). Guy at autozone said that if it shows both O2 sensors at once it could actually be the cat. converter. We just replaced an O2 sensor last year. How can I tell if it is the cat. con., because the cat is still under the emissions warranty. Thanks
My Tacoma threw the same code (catalyst system below effeciency) like you said and I replaced the cat as I had previously done just the first O2 sensor for something else. After replaced the cat...all was good more or less.
go to a dealership....there is a TSB for p0420 and 430 that involves reflashing the ecu and replacing any or all of the sensors, if they *ahem* "happen to become siezed upon removal" covered until 90,000 miles
