Previously, I wasn't able to get enough brake pressure to stop my vehicle after almost complete my SAS on my 02 tacoma. I was told to check out this site: http://home.4x4wire.com/erik/4runner/brakes/. After doing more research, I purchased a 1/2 ton chevy MC (1 1/8") for my taco. Apparently, the newer tacomas master cylinders have a different bolt pattern than the older ones. On Eric's site, he used the adapter that had the 4 bolt pattern to mate the MC to the booster, but on the newer tacomas, there are only two bolts, exactly the same style has the way the chevy MC bolts on, expect for the fact that the center to center of the toyota bolt pattern is about 1/2" shorter than the c-t-c of the chevy MC, which really sucks. I have two questions: (1) If I purchase a booster from a T100, will it bolt right into my 02 tacoma like it does to the earlier tacomas and (2) will having the T100 booster make that much of a difference? If I have the T100 booster then I can make the adapter since I'll have the 4 bolt pattern. If the T100 booster doesn't fit in my 02 tacoma, then I won't be able to make an adapter because of the newer 2 bolt pattern that is just a bit smaller than the 2 bolt pattern on the chevy MC. Thanks.
