1 - 17 of 17 Posts
So I've scrolled through numerous threads before taking on the challenge of the 2001 - 2004 Double Cab Sub extravaganza. I can only thank all of those who posted their setups. So much good information I learned. So, to hopefully return the favor to someone down the road, I thought I would post up my stereo installation and sub setup.
What I set out to do differently in my truck was to keep some of the area behind the seat for storage. I found the miracle life saver of a sub, the Pioneer Premier 8" shallow mount TS-SW841D, and this thing has a crazy mounting depth of just 2½ inches! Plus, it sounds so good! I am 100% satisfied with the result. So here it is:
Here is the Pioneer DEH3800MP Head Unit mounted up to the new pocket:
http://www.jconti.net/Tacoma/stereo/01_DEH3800MP.JPG
Wiring harness soldered up and taped:
http://www.jconti.net/Tacoma/stereo/02_Harness.JPG
Here's where I placed the amp being used for the sub. It fit very nicely. And yes, I used 10 AWG power wire. It's rated for up to 30 amps and I have a 20 amp fuse on it. It is MORE than enough for this amp. Also notice I sanded the paint off of where I will be mounting the ground (where the seat bolts in):
http://www.jconti.net/Tacoma/stereo/03_Amp.JPG
Here is just a comparison of stock speakers to some budget Pioneer $59.99/pair 6x8 replacements. Man, these things really took me by surprise:
http://www.jconti.net/Tacoma/stereo/04_Speakers.JPG
Just a shot of one of the rear doors with a speaker installed:
http://www.jconti.net/Tacoma/stereo/05_SpkInstld.JPG
On the front doors, I am running the factory tweeters along with these replacements.
And a picture of the sub box in the making. Now since I am only driving an 8 and because I need all of the room I can get, I am using only ½" MDF. It should be more than enough with how small of an enclosure this. Of course the box has been glued and brad nailed (1¼") as well as sealed with silicone.
http://www.jconti.net/Tacoma/stereo/06_SubBox.JPG
Showing you the OUTER dimensions on my box 3 x 4½ x 10 x 10 1/8 x 24:
http://www.jconti.net/Tacoma/stereo/07_BxDmnsns.JPG
A good shot of the Pioneer Sub fitting NICELY in its shallow little home:
http://www.jconti.net/Tacoma/stereo/08_DpthView.JPG
So with this being my 2nd sub build for behind the rear seat of this truck, I had already experienced the effect of how the rear seat will completely smother the sub from making any sound. The space is SO limited back there, even with this shallow box I have built, there still isn’t enough room for the excursion of a sub. You certainly don't want the sub to start hitting up against the metal of that seat! So I crafted up the box to mimic Pioneer's own design of the boxes they promote for these woofers. I just placed some panels of 3/4" MDF on the sides of the woofer and then used some aluminum pipe across that as a grill. So now when I smash the seats back into position, the resistance is not on the speaker at all. The speaker has all of the room it needs to reach its XMAX.
http://www.jconti.net/Tacoma/stereo/09_SubCmplt.JPG
And here is a picture of the TINY amount of modification needed to the rear of the cab! All I had to so was cut out a 24" section of the rear wall carpet so the box would snugly fit under the channel. Then I removed two of the hooks. And finally, just cut the flap of carpet over the two center-most seat bolts. None of this is seen when the seats are up so who really cares! Plus it is SO MUCH less modification than many of the other setups I have seen out. And there is still room for storage of your jack and other stuff.
http://www.jconti.net/Tacoma/stereo/10_RearCab.JPG
And here is a test fit of the sub installed. The best part, I didn't have to remove the seat backs to place the sub in. It just slipped right in. Now I did have to remove the entire seat to run wire. But, that is SO much less of a hassle than trying to remove the seat backs (or at least getting them back on):
http://www.jconti.net/Tacoma/stereo/11_SubInstld.JPG
(I just re-read this and wanted to mention I am not talking about the plastic covers on the back of the seats. Yes, those are removed, but that is easy. I meant, the 60/40 back-rests did not have to be removed in order to wedge the box in. They did on the last box I made for a standard 8" sub, but this box is a tad bit smaller.)
Finally, a couple of shots of the clearance so you can see just what I mean about how the seat would have just smashed up against the sub if the grill wasn't there. The pictures show the seat back into position but the sub is protected and allowed to move freely.
http://www.jconti.net/Tacoma/stereo/12_Clrnce.JPG
http://www.jconti.net/Tacoma/stereo/13_Clrnce2.JPG
I am extremely pleased with the setup. I went out on a limb and paid what I considered a premium price for a sub at $149. But in the end I knew my options were limited. So I went for it and I am glad I did. The entire system, although built very budget conscious, sounds so very well balanced and clear. I am completely satisfied with everything and have nothing I wish to change.
So I hope my write up helps someone out there using the search function like I did so many times. I was ALWAYS searching "Double Cab Sub" "Dbl Sub" or "DC Sub".
Also, all fo this can be seen here: http://www.jconti.net/Tacoma/stereo/Stereo.htm
There is also a PDF on that page I have made with plans for building this exact same box.
-Jeff
good write up man, set-up looks real clean.
Good job.
Thanks. I appreciate the compliment. I need them after annoying my wife for spending two days in the garage away from her and my little girl. I felt bad about spending my weekend out there, and it got kind of old. But, I am happy it is over with and I can just enjoy it at this point.
-Jeff
I gotta say that looks pretty damm good. I have the same truck as your and was just about to start making the box with the shallow mounts as well. Thanks for the write up on it since I had a few questions that needed some answers, and well you did that for me. :D
STITCH - Come and Take it!
2019 4RUNNER TRD Off-Road
Nice job there! Clean install.
Question...how come you did not post the photos on your thread, why hyperlink it???? :confused:
Then it would show the photo on your thread.
Not to shabby! God i love doing Car Audio in Tacomas And Runners, Everything comes apart so easy!
good writeup, wish you had an extended cab you were going to do next :)
Stroonzo, do those Pioneer 6x8 speakers fit both front and rear doors? Do they need any modification to fit properly? Got a model number for them? I just wanna upgrade my factory speakers and get a new head unit in my 2003 double cab...
Discussion Starter · #14 ·
The Pioneer TS-G6841R 6x8s were purchased from Crutchfield at $59.99 a pair. The installation is a no brainer. Very minimal dremel trimming of the factory brackets will be needed because the magnets are slightly larger. Nothing a cutting wheel won't fix. You'll literally spend one minute trimming it.
They 6x8s fit in the front and rear doors. If your looking for a decent replacement, these are pretty good for the price. I can't comment on the low end performance since I'm running a sub for that. I have my head unit's High Pass Filter assigned to these speakers at 80 or 100 Hz.
Thanks,
Jeff
Discussion Starter · #17 ·
u think 149 is an expensive sub
Was that a statement or a question? If you're asking, then yes. I'm cheap. I'm not all about that back-pocket money. Like my write up says, "...and paid what I considered a premium price for a sub at $149". For me, that's a bit much for an eight, but that's the price one pays for specialized.
Anything else? :rolleyes:
1 - 17 of 17 Posts
