1 - 9 of 9 Posts
My latest addition: I removed the access cab rear seats since I can never use them because they are always covered in tools or other gear.
Rear Quad drawers (2 per side) with center cubby hole
20" depth full extension, 100 pound rating.
Mounting points:
One on each side connected to the rear seat latch and one in the center connected to the drivers seat using a child seat anchor
Awesome, thinking about doing the same thing.
Do you have plans you could share?
Best
Dave
Sent from my iPad using Tapatalk 2
Best
Dave
I could draw up some basic prints and measurements this weekend and post it.
I have not forgotten about the plans. I'm still going to post them.
It was a lot of measure, cut, build, test fit, measure, test fit, cut, build, test fit, measure, build, test fit, test fit, measure, build and test fit agian.
This is the basic build. You may need to make small adjustments for the exact fit to your truck. The drawers are based on a 1/2 inch thick drawer slide per side and an 1/8 inch gap around the face. You may need to adjust the gap based on the finish paint you use.
***I think I ended up with a 1/4 inch gap around the drawer face to allow for the thickness of the line-X finish.
Here is a link to the drawer slides I used:
http://www.leevalley.com/en/hardware/page.aspx?p=46576&cat=3,43614,43616
Nice set-up. Looks clean and useful.
STITCH - Come and Take it!
When I first saw the pics, I was thinking what is so custom, boy was I wrong....that is one sweet setup and design.
Great job!
1 - 9 of 9 Posts
