1 - 11 of 11 Posts
I'm looking at getting some 7089 pro comp wheels and will they rum on the 07's calipers? I've heard b0th stories? what is my stock bs, how much would these wheels stick out thanks
Just take a grinder to your calipers... you shouldn't need to take too much material off to get those rims to fit. I barely had to grind the calipers on my old 03 Taco... Didn't have any problems afterwards.
Yea but I think the BS on the older taco's are different that the new ones? Does anyone know if they are or what? I thought the stock Bs on of 04- were 4.5?
Discussion Starter · #7 ·
sweet finally a usefull personn aroung this flaming place :mad: ... Thanks MXracer atleast there is someone helpfull... ;)
But I still am not sure about the calipers rubbing though on that rim?
Plan on getting the 7089's in 17"; discount tire said the 17" wheels will fit but sure most 17" wheels do....Don't know about the 16" but they have a 4.5 BS so caliber grinding would be minimal I would guess
Back spacing has little to do with caliper rub. The configuration of the spoke or center portion of the wheel is what you need to look at. Generally if the center is completely flat it will rub.
1 - 11 of 11 Posts
